Error with Image generating for PDF report [message #1842556] |
Wed, 23 June 2021 11:40  |
When I use image item into my report, I have very strange behavior:
1. I have a dataset containing a field with all the URL access to the images (google drive links).
2. I create an image into a table which call the row["XXXX"] field as an "URI" OR with script by using "this.URL"... into the onRender, onCreate (I have tried lot of way to call the image link).
3. If I generate the pdf report like that it works perfectly. But as soon as I modify the width (directly into the layout property OR using the script this.width into the onPrepare), the pdf generating does not work properly (sometimes every image are replaced by the sentence "Error with Image generating for PDF report", sometimes only few images, sometimes it works but at the next generating it does not works).
Do you have any idea of the reason?
Example of URL (not working, just an example): https://drive.google.com/uc?export=view&id=1Ts_GlbF8bsAXozsfMIXz57cBfiOWi38I
[Updated on: Wed, 23 June 2021 11:42] by Moderator
FUDForum. Page generated in 0.36302 seconds
