Home » Eclipse Projects » Oomph » Installation Error(Error while installing Eclipse)
Installation Error [message #1835791] Sat, 12 December 2020 21:26 Go to next message
An error was detected while performing the engine operation and the changes are being rolled back. See the log for details.
ERROR: org.eclipse.equinox.p2.engine code=4 An error occurred while installing the items
at org.eclipse.oomph.util.OomphPlugin.coreException(OomphPlugin.java:291)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl$3.commit(ProfileTransactionImpl.java:551)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl.commit(ProfileTransactionImpl.java:343)
at org.eclipse.oomph.setup.p2.impl.P2TaskImpl.perform(P2TaskImpl.java:899)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:3828)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:3756)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:3737)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:3630)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$9.run(ProgressPage.java:593)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$11$1.run(ProgressPage.java:720)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
ERROR: org.eclipse.equinox.p2.engine code=0 session context was:(profile=C__Users_ASUS_java-2020-09_eclipse, phase=org.eclipse.equinox.internal.p2.engine.phases.Install, operand=null --> [R]org.eclipse.platform.ide.executable.win32.win32.x86_64 4.17.0.I20200902-1800, action=org.eclipse.equinox.internal.p2.touchpoint.natives.actions.UnzipAction).
ERROR: org.eclipse.equinox.p2.touchpoint.natives code=0 The artifact for binary,org.eclipse.platform.ide.executable.win32.win32.x86_64,4.17.0.I20200902-1800 is not available.
How to fix this error
Re: Installation Error [message #1835796 is a reply to message #1835791] Sun, 13 December 2020 09:27 Go to previous message
The error suggests that your bundle pool is corrupted, either because a corrupt artifact was downloaded or your virus scanner block the moving of that file after it was downloaded.
Please refer to this page for how to repair the pool:
https://www.eclipse.org/setups/installer/question/
In particular this:
Use the eclipse installer's bundle pools... menu item to manage where this pool is physically located on disk; this location can become large. The bundle pool Management dialog supports garbage collecting of unused artifacts, i.e., if you delete an installation, the artifacts it uses can potentially be removed from disk. In addition, if some artifact becomes corrupted, or if a corrupted artifact is downloaded from some mirror site, this dialog can be used to detect the damage and to repair it.
Please let me know if that help fix the problem.
Previous Topic:Form-based authentication with gitlab 13.6.1 not working because of missing closing tag for "me
Next Topic:Installer fails
Current Time: Mon Jul 21 12:42:17 EDT 2025
Powered by FUDForum. Page generated in 0.05004 seconds
