Home » Modeling » M2T (model-to-text transformation) » [JET2] - Is there a way to check if a variable has been defined
[JET2] - Is there a way to check if a variable has been defined [message #18233] Mon, 28 May 2007 11:54 Go to next message
Originally posted by: evaandoli.dodo.com.au
Im looking through the JET docs and Xpath spec and I can't find how to check
if a variable has been defined or not.
I'd like to use it in a <c:if test="isDefined($aVar)"> type idea.
Stu
Re: [JET2] - Is there a way to check if a variable has been defined [message #18284 is a reply to message #18233] Thu, 31 May 2007 09:05 Go to previous messageGo to next message
Stu:
Sadly, there is no predefined function. You have a number of choices:
1) Write the following Java scriptlet:
<% if(context.hasVariable("...name without $...")) { %>
2) Write a isDefined XPath function.
a) Create a plug-in, add a depencency on org.eclipse.jet. Create an
extension on org.eclipse.jet.xpathFunctions
b) Define your function in the extension: it would have min/max arguments of
1
c) In the function class, add an
org.eclipse.jet.xpath.XPathFunctionWithContext - this creates a method
setContext() with delivers the current XPath context object (from which you
can extract variables). Save the passed context to an instance variable
d) In the function class's evaluate method, write something like:
String varName = XPathUtil.xpathString(args.get(0));
return context.getVariableResolver().resolveVariable(varName) != null;
Of course, if you write such a function, why not submit a bugzilla
enhancement, and contribute it back to JET :-)
Paul
Re: [JET2] - Is there a way to check if a variable has been defined [message #18336 is a reply to message #18284] Fri, 01 June 2007 09:55 Go to previous messageGo to next message
I had a go at creating the new function wit the extention point but I'm
getting the following when I launch to test:-
Plug-in "Jet.Custom" was unable to instantiate class
"jetcustom.IsDefinedFunction".
The following is my MANIFEST.MF, Plugin.xml and Buld.properties:-
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Custom Plug-in
Bundle-SymbolicName: Jet.Custom;singleton:=true
Bundle-Version: 1.0.0
Require-Bundle: org.eclipse.jet
Export-Package: jetcustom;uses:="org.eclipse.jet.xpath"
Eclipse-LazyStart: false
Plugin.xml
<?eclipse version="3.2"?>
<plugin>
<extension
point="org.eclipse.jet.xpathFunctions">
<function
implementation="jetcustom.IsDefinedFunction"
maxArgs="1"
minArgs="1"
name="isDefined">
</function>
</extension>
</plugin>
build.properties
source.. = src/
output.. = bin/
bin.includes = META-INF/,\
plugin.xml
Java Class:-
package jetcustom;
import java.util.List;
import org.eclipse.jet.xpath.Context;
import org.eclipse.jet.xpath.XPathFunction;
import org.eclipse.jet.xpath.XPathFunctionMetaData;
import org.eclipse.jet.xpath.XPathFunctionWithContext;
import org.eclipse.jet.xpath.XPathUtil;
public class IsDefinedFunction implements XPathFunctionWithContext {
public static final XPathFunctionMetaData FUNCTION_META_DATA = new
XPathFunctionMetaData(
"isDefined", null, (XPathFunction) new IsDefinedFunction(), 1, 1);
//$NON-NLS-1$
public IsDefinedFunction() {
super();
* (non-Javadoc)
* @see org.eclipse.jet.xpath.XPathFunction#evaluate(java.util.List)
@SuppressWarnings("unchecked")
public boolean evaluate(List args) {
return currentContext.getVariableResolver().resolveVariable(varName ) !=
null;
Context currentContext;
public void setContext(Context aContext) {
currentContext = aContext;
"Paul Elder" <pelder@ca.ibm.com> wrote in message
news:f3mh7r$es2$1@build.eclipse.org...
> Stu:
> of 1
> you can extract variables). Save the passed context to an instance
> variable
> Paul
Re: [JET2] - Is there a way to check if a variable has been defined [message #18353 is a reply to message #18336] Fri, 01 June 2007 11:25 Go to previous messageGo to next message
Stu:
The message is coming from IConfigurationElement.createExecutableExtension
So, the good news is Eclise/OSGi has loaded your plug-in. In fact, it was
able to load your class, too. The error is happening when it
Class.newInstance is called. Unfortunately, the Eclipse code suppresses the
reason for the failure.
There are a couple of suggestions:
1) implement XPathFunction as well as XPathFunctionWithContext. Whether this
is the source of your problem or not, you'll need it.
(XPathFunctionWithContext is not a subinterface of XPathFunction - I can't
remember whether that was be design or not).
2) You don't need to declare the FUNCTION_META_DATA field. JET uses this on
standard XPath functions so that it can configure the XPath engine without
relying on Eclipse and extension points. (It is a little known fact that the
XPath engine is independent of Eclipse).
If all else fails, I suggest creating a JUnit plug-in (i.e, add a dependency
on JUnit), the then add a JUnit that simply does:
new IsDefinedFunction();
Whatever exeception is being thrown will be become clear.
Paul
Re: [JET2] - Is there a way to check if a variable has been defined [message #18415 is a reply to message #18353] Sat, 02 June 2007 01:30 Go to previous messageGo to next message
You were right you need to implement XPathFunction as well.
I will try and submit the enhausement if you like.
To package this do you just export a jar ?
Haven't tried just asking.
Stu
news:f3pdr7$8mr$1@build.eclipse.org...
> Stu:
> the reason for the failure.
> this is the source of your problem or not, you'll need it.
> on standard XPath functions so that it can configure the XPath engine
> without relying on Eclipse and extension points. (It is a little known
> fact that the XPath engine is independent of Eclipse).
> dependency on JUnit), the then add a JUnit that simply does:
> Paul
Re: [JET2] - Is there a way to check if a variable has been defined [message #19277 is a reply to message #18415] Sat, 02 June 2007 10:02 Go to previous messageGo to next message
Submitted an enhausement and included the code / definitions used.
#190650
"Stu" <evaandoli@dodo.com.au> wrote in message
news:f3qv96$uas$1@build.eclipse.org...
> Stu
>> Stu:
>> can't remember whether that was be design or not).
>> Paul
Re: [JET2] - Is there a way to check if a variable has been defined [message #19321 is a reply to message #18415] Sat, 02 June 2007 10:16 Go to previous messageGo to next message
Ok to answer my own question - yes just export as plugin and its works fine
Shame the export function remembers the "last" exported plugin and not
settings for the project you have selected.
Is there a way to do this ?
Maybe not a question for here.
Stu
> Stu
>> Stu:
>> Paul
Re: [JET2] - Is there a way to check if a variable has been defined [message #24311 is a reply to message #19277] Thu, 28 June 2007 07:05 Go to previous messageGo to next message
where can I get this enhancement ?
Tex.
Re: [JET2] - Is there a way to check if a variable has been defined [message #24392 is a reply to message #24311] Thu, 28 June 2007 09:58 Go to previous messageGo to next message
Tex:
JET 0.8.0 is in the final moments of shut down. I am just now starting to
the plan the next release.
In the meantime, the enhancement request is recorded in bugzilla 190650
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=190650), complete with a
proposed implementation.
Paul
"Tex Twil" <chaljan@hotmail.com> wrote in message
news:c6c9dcd5d447f981213f3a98af862c33$1@www.eclipse.org...
> Tex.
Re: [JET2] - Is there a way to check if a variable has been defined [message #24596 is a reply to message #24392] Fri, 29 June 2007 10:55 Go to previous messageGo to next message
you mean that this "isDefined" function will be included with the 0.8.0
version ?
Paul Elder wrote:
> Tex:
> Paul
>> Hi,
>> Tex.
Re: [JET2] - Is there a way to check if a variable has been defined [message #24826 is a reply to message #24596] Tue, 03 July 2007 06:42 Go to previous messageGo to next message
Sorry to ask again but is this function supposed to be included in the
last release ?
thx,
Tex.
Tex Twil wrote:
> version ?
> Paul Elder wrote:
>> Tex:
>> to the plan the next release.
>> 190650 (https://bugs.eclipse.org/bugs/show_bug.cgi?id=190650),
>> complete with a proposed implementation.
>> Paul
>>> Hi,
>>> Tex.
Re: [JET2] - Is there a way to check if a variable has been defined [message #24860 is a reply to message #24392] Wed, 04 July 2007 04:42 Go to previous messageGo to next message
I added an extension point as explained in this enhancement i.e.
- define the class IsVarDefinedFunction in the JET project
- add the extension to the plugin.xml referencing this class
Everything seems ok, but JET keeps saying "Error: Unknown function name:
isVarDefined " during execution. What did I do wrong ?
Tex.
Paul Elder wrote:
> Tex:
> Paul
>> Hi,
>> Tex.
Re: [JET2] - Is there a way to check if a variable has been defined [message #24913 is a reply to message #24826] Wed, 04 July 2007 10:59 Go to previous messageGo to next message
Tex:
No isDefined is not yet included in any JET version.
Paul
news:f6d96v$t0c$1@build.eclipse.org...
> last release ?
> thx,
> Tex.
> Tex Twil wrote:
>> Hi,
>> version ?
>> Paul Elder wrote:
>>> Tex:
>>> Paul
>>>> Hi,
>>>> Tex.
Re: [JET2] - Is there a way to check if a variable has been defined [message #25003 is a reply to message #24860] Wed, 04 July 2007 11:14 Go to previous messageGo to next message
Tex:
I can image two possibilities:
1) You added the XPath function to JET transformation plug-in.
Unfortunately, this appears to be a bug in the dynamic loading of JET
transformation projects from the workspace:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=195397
Possible work arounds:
a) Define the function in a separate plug-in, and install it into your
development workbench
b) Test the JET transformation from a runtime workbench in which the JET
transformation is included.
2) You already have defined the Xpath function is a separate plug-in
project, but that project is in your workspace. JET will load a JET
transformation plug-in from the workspace, but it will not load any
dependent plug-ins. In this case, you could use either of the above work
arounds.
Paul
news:f6fmi8$u5k$1@build.eclipse.org...
> Tex.
> Paul Elder wrote:
>> Tex:
>> Paul
>>> Hi,
>>> Tex.
Re: [JET2] - Is there a way to check if a variable has been defined [message #25044 is a reply to message #25003] Wed, 04 July 2007 11:34 Go to previous message
Ok, thank you, I will try.
Paul Elder wrote:
> Tex:
> arounds.
> Paul
>> Hi,
>> Tex.
>> Paul Elder wrote:
>>> Tex:
>>> Paul
>>>> Hi,
>>>> Tex.
Previous Topic:Re: invoke template from java with string return?
Next Topic:User of infant JET
Current Time: Sat Nov 08 18:03:25 EST 2025
Powered by FUDForum. Page generated in 0.06032 seconds
