Home » Eclipse Projects » GEF » Difficuty installing GEF DOT in Eclipse
Difficuty installing GEF DOT in Eclipse [message #1831809] Sun, 30 August 2020 14:23 Go to next message
I'm hoping to use GEF to edit and preview DOT files within Eclipse.
I followed the instructions here: https://github.com/eclipse/gef/blob/master/README.md#eclipse-graphical-editing-framework-gef
Namely, installed GEF DOT End-User Tools and GEF Cloudio End-User Tools.
The GEF editor opens a DOT file, does syntax highlighting.
However, other features don't seem to work:
- toolbar buttons missing
- option for output file type does not show file types (see image).
- nothing displayed in GEF image window
Any help much appreciated!
Best Regards, Dave
Using NXP's MCUXpresso (Eclipse) development package.
Eclipse Platform:
Version: 4.14.0.v20191210-0610
Build id: I20191210-0610
http://www.nadler.com/backups/DOT_missing_output_file_types.PNG
Re: Difficuty installing GEF DOT in Eclipse [message #1831811 is a reply to message #1831809] Sun, 30 August 2020 23:39 Go to previous messageGo to next message
Hello Dave,
It is possible that GEF DOT is not yet compatible with Graphviz 2.44.1
I have just tested it with Graphviz 2.38 and it is fully working on my machine.
Could you please give it a try with Graphviz 2.38 and give feedback if it is working?
Hope that helps.
Tamás
Re: Difficulty installing GEF DOT in Eclipse [message #1831837 is a reply to message #1831811] Mon, 31 August 2020 10:57 Go to previous messageGo to next message
Version 2.38 shows file types.
index.php/fa/38836/0/
Even displayed the graph though unfortunately title is missing.
index.php/fa/38835/0/
Best Regards, Dave
[Updated on: Mon, 31 August 2020 10:58] by Moderator
Re: Difficulty installing GEF DOT in Eclipse [message #1831866 is a reply to message #1831837] Tue, 01 September 2020 06:32 Go to previous messageGo to next message
Hello Dave,
Thanks for your feedback!
Based on the attached screenshot, the GEF DOT Plugin with Graphviz 2.38 is working as currently designed.
If you are missing any functionality or have suggestions for improvements, please open a corresponding Eclipse GEF Bugzilla on the GEF DOT component:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=GEF
Tamás
Re: Difficulty installing GEF DOT in Eclipse [message #1831868 is a reply to message #1831866] Tue, 01 September 2020 08:03 Go to previous messageGo to next message
Tamas Miklossy wrote on Tue, 01 September 2020 10:32
Hello Dave,
...If you are missing any functionality or have suggestions for improvements, please open a corresponding Eclipse GEF Bugzilla on the GEF DOT component...
Have you already entered a bug report that GEF fails with 2.44?
Or found it impossible to work around the incompatibility,
and entered a bug report on dot itself?
Thanks!
Best Regards, Dave
Re: Difficulty installing GEF DOT in Eclipse [message #1831873 is a reply to message #1831868] Tue, 01 September 2020 10:05 Go to previous messageGo to next message
Hello Dave,
No, I have not yet created such a Bugzilla issue. Would be awesome if you could create one and describe the problem details (with screenshots) as much as possible.
Tamás
Re: Difficulty installing GEF DOT in Eclipse [message #1832739 is a reply to message #1831873] Thu, 24 September 2020 02:13 Go to previous message
Hello Dave,
Thanks for creating the bug report under https://bugs.eclipse.org/bugs/show_bug.cgi?id=567253
Tamás
Previous Topic:Similar UI to Yakindu Model Viewer
Next Topic:Placing Child Elements inside Nodes in GEF5
Current Time: Sun Jul 20 23:59:02 EDT 2025
Powered by FUDForum. Page generated in 0.35023 seconds
