Home » Archived » Jubula » Selenium Webdriver(Unable to locate element)
Selenium Webdriver [message #1368561] Tue, 20 May 2014 03:15 Go to next message
Hi @all,
I'm absolute newbiew related to JAVA.
I have a question, please.
I record a test in Selenium IDE. It runs fine under Selenium IDE. After that I export that testcase as Webdriver for JUnit and import that into my eclipse.
I did it with other test cases, too and it runs well in my eclipse.
But to this last test case it does not work.
Suddenly eclipse said that soemthing is wrong with "Unable to locate element" ?
The first step is (expected) it should click on the link below "Daten einfuegen",
but it does not happen !!!
(see my attachment)
What should I do or what is the solution for that ?
Thank you in advance.
Cheers
Loren
Re: Selenium Webdriver [message #1369278 is a reply to message #1368561] Tue, 20 May 2014 10:03 Go to previous messageGo to next message
I think this is the wrong Forum for this Kind of question Sad
Re: Selenium Webdriver [message #1831605 is a reply to message #1368561] Mon, 24 August 2020 15:31 Go to previous message
Try locating elements through various locators like ID, Name, ClassName, XPath etc. and see if it is working
Previous Topic:How to press any key by Jubula's Java API
Next Topic:External Command Ubuntu
Current Time: Fri Jul 18 11:59:49 EDT 2025
Powered by FUDForum. Page generated in 0.05728 seconds
