Home » Modeling » EMF » How to transform a xmi file to atl file?(The xmi file is taken from AtlParser)
How to transform a xmi file to atl file? [message #1829121] Thu, 25 June 2020 08:16 Go to next message
Hello!
I want to get an atl file with traceadder in java program. Firstly, I use the AtlParer to get the xmi format from the transformation in .atl format,then I use java to run Traceadder.atl to get the transformation with trace in .xmi format.And now ,I want to get the atl file from the xmi file.But the AtlPaser can only get the .xmi file from .atl file, is there an idea to transform the xmi to atl?
Thank you for any research direction!
Re: How to transform a xmi file to atl file? [message #1829154 is a reply to message #1829121] Fri, 26 June 2020 00:52 Go to previous messageGo to next message
The ATL support page https://www.eclipse.org/atl/support/ suggests to use this forum for questions about ATL:
http://www.eclipse.org/forums/eclipse.atl
Re: How to transform a xmi file to atl file? [message #1829159 is a reply to message #1829154] Fri, 26 June 2020 02:56 Go to previous message
OK. Thank you!
Previous Topic:Save disabled
Next Topic:[CDO] Store multiple large files concurrently
Current Time: Mon Jul 21 09:15:31 EDT 2025
Powered by FUDForum. Page generated in 0.03893 seconds
