Home » Eclipse Projects » NatTable » update/refresh NatTable after updating the POJO
update/refresh NatTable after updating the POJO [message #1250608] Wed, 19 February 2014 07:01 Go to next message
Hello everyone!
I used the Code from the Tutorial at:
http://eclipse.org/nattable/documentation.php?page=articles
Here is the code of my NatTable. It works and displays the desired data.
A ListDataProvider over my POJO "Fault":
	// IRowDataProvider for Fault
	public IRowDataProvider<Fault> getFaultRowDataProvider () {
		return	new ListDataProvider<Fault>(faultList,
				new ReflectiveColumnPropertyAccessor<Fault> (Fault.getPropertyNames().clone()));
A NatTable based on the tutorial:
public  class FaultNatTable{
	private BodyLayerStack bodyLayer;
	public NatTable createNatTable (Composite parent, IDataProvider dataProvider) {
//a data Provider based on POJO
		bodyLayer = new BodyLayerStack (dataProvider);
//does this Handler even work?
		bodyLayer.registerCommandHandler(new StructuralRefreshCommandHandler());
		DefaultColumnHeaderDataProvider colHeaderDataProvider =  new  DefaultColumnHeaderDataProvider (Fault.getPropertyNames().clone());
		DefaultRowHeaderDataProvider rowHeaderDataProvider =  new  DefaultRowHeaderDataProvider (dataProvider);
		ColumnHeaderLayerStack columnHeaderLayer =  new  ColumnHeaderLayerStack (colHeaderDataProvider);
		RowHeaderLayerStack rowHeaderLayer =  new  RowHeaderLayerStack (rowHeaderDataProvider);
		DefaultCornerDataProvider cornerDataProvider =  new  DefaultCornerDataProvider (colHeaderDataProvider,
		CornerLayer cornerLayer =  new  CornerLayer ( new  DataLayer (cornerDataProvider), rowHeaderLayer,
				columnHeaderLayer);
		GridLayer gridLayer =  new  GridLayer (bodyLayer, columnHeaderLayer, rowHeaderLayer, cornerLayer);
		NatTable natTable =  new  NatTable (parent, gridLayer, false);
		gridLayer.registerCommandHandler(new StructuralRefreshCommandHandler());
		// Configuration of the NatTable
		natTable.addConfiguration(new DefaultNatTableStyleConfiguration());
		natTable.addConfiguration(new DefaultFreezeGridBindings());
		// Creation of the dialogue of choice of columns
		/*		DisplayColumnChooserCommandHandler columnChooserCommandHandler =  new  DisplayColumnChooserCommandHandler (
			bodyLayer.getSelectionLayer(),
			bodyLayer.getColumnHideShowLayer(),
			columnHeaderLayer,
		compositeFreezeLayer.registerCommandHandler (columnChooserCommandHandler);*/
		natTable. addConfiguration ( new  HeaderMenuConfiguration (natTable) {
			@ Override
			protected PopupMenuBuilder createColumnHeaderMenu (NatTable natTable) {
				return  super . createColumnHeaderMenu (natTable). withColumnChooserMenuItem ();
		natTable.configure();
		return natTable;
	 *  The  stack  of  layers  for  the  party  central  of  the  NatTable
	 *  @ author  A .  BERNARD
	public  class BodyLayerStack extends AbstractLayerTransform {
		private SelectionLayer selectionLayer;
		public  BodyLayerStack (IDataProvider dataProvider) {
			DataLayer bodyDataLayer =  new  DataLayer (dataProvider);
			selectionLayer =  new SelectionLayer (bodyDataLayer);
			ViewportLayer viewportLayer =  new  ViewportLayer (selectionLayer);
			setUnderlyingLayer (viewportLayer);
		 *  Returns  the  layer  of  selection
		 *  @ return
		public SelectionLayer getSelectionLayer () {
			return selectionLayer;
	 *  The  stack  of  layers  for  the  in - heads  of  column
	public  class ColumnHeaderLayerStack extends AbstractLayerTransform {
		public  ColumnHeaderLayerStack (IDataProvider dataProvider) {
			DataLayer DataLayer =  new  DataLayer (dataProvider);
			ColumnHeaderLayer colHeaderLayer =  new  ColumnHeaderLayer (DataLayer,
					bodyLayer, bodyLayer.getSelectionLayer ());
			setUnderlyingLayer (colHeaderLayer);
	 *  The  stack  of  layers  for  the  in - heads  of  lines
	public class RowHeaderLayerStack extends AbstractLayerTransform {
		public  RowHeaderLayerStack (IDataProvider dataProvider) {
			DataLayer DataLayer =  new  DataLayer (dataProvider, 50 , 20 );
			RowHeaderLayer rowHeaderLayer =  new  RowHeaderLayer (DataLayer,
					bodyLayer, bodyLayer.getSelectionLayer());
			setUnderlyingLayer (rowHeaderLayer);
	public String getExampleTitle () {
		return  " Basic  Example " ;
But if I update the List<POJO> nothing happens when I trigger a refresh, like:
myTableInstance.refresh();
My Question is, what do I have to do to update the displayed data?
Thanks for your help,
Edgar
Re: update/refresh NatTable after updating the POJO [message #1250721 is a reply to message #1250608] Wed, 19 February 2014 09:27 Go to previous messageGo to next message
Where do you update the data? The NatTable only knows about the values in the list.
Are you trying to exchange the list? This might not work because of several references. In that case you simply should operate on the list instead of exchanging it.
Re: update/refresh NatTable after updating the POJO [message #1250841 is a reply to message #1250721] Wed, 19 February 2014 11:58 Go to previous messageGo to next message
Yes, I try to exchange the whole list. A model class holds the list in one of its fields.
All values are changing at that point of the application. Even the size of the List<POJO> can change.
In which way should I use the NatTable to cover this condition? Is there maybe an example doing something similar?
Re: update/refresh NatTable after updating the POJO [message #1250942 is a reply to message #1250841] Wed, 19 February 2014 14:05 Go to previous messageGo to next message
No there is no such example, as I already said that you should try to operate on the list you put into the NatTable.
You can try to either replace the list in the data provider you are using or try to replace the data provider set to the data layer. Not sure if this is working.
Typically I suggest in such cases to set a list to the NatTable and perform clear/add all operations when the underlying list changes. Of course in such cases list modifications wouldn't work.
Re: update/refresh NatTable after updating the POJO [message #1251812 is a reply to message #1250942] Thu, 20 February 2014 11:20 Go to previous messageGo to next message
I tried it the way you mentioned it. To conclude this thread quick I will give an example of my dirty solution. It is based on Bernard's tutorial and the replays in this thread. Thank you very much for those fast and kind replies!
It also worked on manipulating the List directly in the my model class. The important thing is that I broke the reference to my List<POJO> by exchanging it with a new one.
Simply clear the list and add the each element from a second List, which contains the new data, to the list to keep the reference.
I hope this helps other newbies to have a lot fun with the NatTables!
	List<Fault> lisFault = new LinkedList<Fault>();
	public NatTable createNatTable (Composite parent, List<Fault> lisFault) {
		addAllLisFault(lisFault);
		IDataProvider iDataProvider = new ListDataProvider<Fault>(this.lisFault,
		System.out.println("Column count: " + iDataProvider.getColumnCount());
		System.out.println("Row count: " + iDataProvider.getRowCount());
		bodyLayer = new BodyLayerStack (iDataProvider);
		DefaultRowHeaderDataProvider rowHeaderDataProvider =  new  DefaultRowHeaderDataProvider (iDataProvider);
				columnHeaderLayer);
		ColumnGroupLayerStack clst = new ColumnGroupLayerStack(iDataProvider);
		//Creation of the dialogue of choice of columns
				columnHeaderLayer.getColumnHeaderLayer(),
				bodyLayer.getDataLayer(),
				clst.getColumnGroupHeaderLayer(),
				clst.getColumnGroupModel()
		cornerLayer.registerCommandHandler (columnChooserCommandHandler);
			@ Override
		return natTable;
	public void clearLisFault(){
		while(this.lisFault.size()>0){
			lisFault.remove(lisFault.size()-1);
	public void addAllLisFault(List<Fault> lisFault) {
		for (int i = 0; i < lisFault.size(); i++) {
			this.lisFault.add(lisFault.get(i));
		private ColumnHideShowLayer columnHideShowLayer;
		private DataLayer bodyDataLayer;
			columnHideShowLayer = new ColumnHideShowLayer(viewportLayer);
			//setUnderlyingLayer (viewportLayer);
			setUnderlyingLayer (columnHideShowLayer);
		 *  @ return
		public ColumnHideShowLayer getColumnHideShowLayer () {
			return columnHideShowLayer;
		public DataLayer getDataLayer() {
			return bodyDataLayer;
		private ColumnHeaderLayer colHeaderLayer;
		public ColumnHeaderLayer getColumnHeaderLayer() {
			return colHeaderLayer;
	public class ColumnGroupLayerStack extends AbstractLayerTransform {
		ColumnGroupModel columnGroupModel;
		ColumnGroupHeaderLayer cgHeader;
		public  ColumnGroupLayerStack (IDataProvider dataProvider) {
			columnGroupModel = new ColumnGroupModel();
			cgHeader = new ColumnGroupHeaderLayer(
					DataLayer,
					columnGroupModel);
			setUnderlyingLayer (cgHeader);
		public ColumnGroupModel getColumnGroupModel(){
			return columnGroupModel;
		public ColumnGroupHeaderLayer getColumnGroupHeaderLayer(){
			return cgHeader;
To refresh the NatTable use:
Re: update/refresh NatTable after updating the POJO [message #1826254 is a reply to message #1251812] Wed, 22 April 2020 04:43 Go to previous messageGo to next message
Clearing the list and add new object to the list is not working.
only iterating the list and making changes in the object is reflecting.
Is there any other way updating the values as a list.
Re: update/refresh NatTable after updating the POJO [message #1826273 is a reply to message #1826254] Wed, 22 April 2020 10:35 Go to previous messageGo to next message
It should work as described here. And there are also some examples that show this.
Please have a look at our examples, e.g. https://github.com/eclipse/nebula.widgets.nattable/blob/master/org.eclipse.nebula.widgets.nattable.examples/src/org/eclipse/nebula/widgets/nattable/examples/_300_Data/_308_DataModificationExample.java where you can add or remove items dynamically by modifying the underlying list.
If it is not working for you, you are doing something wrong.
And please don't hijack old posts with new questions!
Re: update/refresh NatTable after updating the POJO [message #1826993 is a reply to message #1826273] Tue, 05 May 2020 16:43 Go to previous messageGo to next message
Thanks for the quick reply.Is their any example available how it can be done in the Nat Tree Table.
Also is there any example like if i pass a new list that should override the old one.
Because in my case every time there is change in value in the combo box, all the values in the table will change , on that occasion i have to delete each and every row and insert all the new rows one by one.
which is fine for small amount of data. but what if the there are lots of data, is that fine to delete all the rows one by one and insert one by one. or is there any other way.
Re: update/refresh NatTable after updating the POJO [message #1827000 is a reply to message #1826993] Wed, 06 May 2020 00:08 Go to previous messageGo to next message
Exchange the data provider https://github.com/eclipse/nebula.widgets.nattable/blob/master/org.eclipse.nebula.widgets.nattable.examples/src/org/eclipse/nebula/widgets/nattable/examples/_300_Data/_307_ChangeDataProviderExample.java
Re: update/refresh NatTable after updating the POJO [message #1827356 is a reply to message #1827000] Wed, 13 May 2020 12:23 Go to previous message
Hello Drik,
Thanks for the quick reply. I tried the above given example it worked like charm. Now i am able to update the table fast and easy.Thanks for example.
Previous Topic:How to detect, if underlying data has changed, when editing a cell
Next Topic:problem with column hide
Current Time: Sun Jun 15 23:59:40 EDT 2025
Powered by FUDForum. Page generated in 0.05730 seconds
