Home » Eclipse Projects » Oomph » Eclipse Update asking for workspace.location on startup
Eclipse Update asking for workspace.location on startup [message #1824416] Wed, 15 April 2020 01:41 Go to next message
I often use the oomph expert mode to deploy a fresh Eclipse instance (eg IDE for Eclipse Committers). When I am not selecting any project to be provisioned, I end up with problems with the workspace.location variable. No matter what I set there, Eclipse will nag me to fill out this variable on each IDE startup showing the Eclipse Updater popup.
Is there a way to fill out this variable properly?
Re: Eclipse Update asking for workspace.location on startup [message #1824443 is a reply to message #1824416] Wed, 15 April 2020 07:35 Go to previous messageGo to next message
The workspace.location variable comes from (is induced from) a Workspace task which has ID workspace and only the Project Catalogs have a Workspace task. If you have tasks that are not in Project setup, it will be better to use ${osgi.instance.area} because that value is always defined by the Equinox runtime.
Re: Eclipse Update asking for workspace.location on startup [message #1824481 is a reply to message #1824443] Wed, 15 April 2020 23:30 Go to previous message
Note also the following:
1) ${osgi.instance.area} expands to a URI, typically a file: URI. Use ${osgi.instance.area|file} to convert it to a file system path.
2) At BOOTSTAP trigger the ${osgi.instance.area} points to the instance area of the installer itself, i.e., its configuration folder.
Previous Topic:Do not install optional p2 dependencies of requirements
Next Topic:Task list view error on first startup
Current Time: Tue Jun 17 07:45:33 EDT 2025
Powered by FUDForum. Page generated in 0.84992 seconds
