Home » Polarsys » Requirements Addon » Parse string requirement ID when importing .reqIF(Problem while importing requirements that contain a string in ID field )
Parse string requirement ID when importing .reqIF [message #1823866] Fri, 03 April 2020 05:08 Go to next message
Hello.
I am trying to import a .reqIF file into Capella.
Requirements have a string as identification, for example MYREQ001, MYREQ002, etc.
It seems that Capella tries to parse the identification as an integer so the import action fails.
index.php/fa/37738/0/
The same requirements work if I change the identification to 1, 2, etc.
If I try to import the same file into other tools like ReqIF Studio or DOORS they import the ID as ForeignID field and they keep the string without problems.
Would it be possible to parse that kind of ID in Capella?
Thanks.
Re: Parse string requirement ID when importing .reqIF [message #1823881 is a reply to message #1823866] Fri, 03 April 2020 08:45 Go to previous messageGo to next message
If the issue is related to the ForeignID attribute, maye this post can help you: https://polarsys.org/forums/index.php/t/911/
Which tool are you using to export the ReqIF file?
Hope it helps,
Re: Parse string requirement ID when importing .reqIF [message #1824021 is a reply to message #1823881] Mon, 06 April 2020 11:09 Go to previous message
That was exactly the problem, thank you (sorry for not finding that thread before posting).
By removing the ForeignID import option from Preferences (Capella -> Requirements -> Importer) the requirements were properly imported.
Since I am using a notation in which the ID is the same as the Name, it is not a big problem.
I used Cameo Systems Modeler to export to ReqIF. By default it uses an integer for the ID, but it can be manually changed to a string value.
Previous Topic:Requirement internal relation
Next Topic:Manage and describe Requirements
Current Time: Thu Jun 12 00:01:20 EDT 2025
Powered by FUDForum. Page generated in 0.06906 seconds
