ERROR IN SETUP MAC OS X 10.15.2 [message #1818601] |
Fri, 20 December 2019 06:59  |
When I try to install Eclipse 2019-12 on MAC OS X 10.15.2 I obtain next message " The JVM shared library "/Library/Java/JavaVirtualMachines/jdk-13.0.1.jdk/Contents/Home/bin/../lib/server/libjvm.dylib"
does not contain the JNI_CreateJavaVM symbol."
Anybody knows what's going on?.
Thanks.
Re: ERROR IN SETUP MAC OS X 10.15.2 [message #1818654 is a reply to message #1818651] |
Sun, 22 December 2019 01:17   |
To run on the latest MacOS, the downloaded *.dmg now must be not only be signed but also notarized. Perhaps notarization locks it somehow? I imagine though that if you copied it somewhere, it should no longer be locked. Or are you talking about modifying the Info.plist of the Java installation?
But again, the same comment applies as before. Please try to download a package from here:
The "Eclipse IDE for Java Developers" will have support for Java 13 (as will any other package that contains Java). These downloaded *.dmg are also signed and notarized, and I suspect they'll have the same launch problem as the Eclipse Installer (both being Eclipse applications).
But if no one answers that question, we won't be able to help anyone. :-(
As far as I can tell, the IDE has been tested on MacOS, but I'm not sure which version of the OS, and it appears tested only for Java 8:
https://download.eclipse.org/eclipse/downloads/drops4/R-4.14-201912100610/testResults.php
These instructions explain how you can tell Eclipse to use a specific JVM:
https://wiki.eclipse.org/Eclipse.ini
In the installer, this file is called eclipse-inst.ini.
It would be good to understand if this works for Java 8 but not for Java 13.
And note that an IDE running on Java 8 can still support any version of Java up to and including Java 13. The Preferences pages allow you to configure multiple JREs and use any of them...
Re: ERROR IN SETUP MAC OS X 10.15.2 [message #1847893 is a reply to message #1847890] |
Thu, 11 November 2021 12:17  |
Now I have the problem with Papyrus RCP I do the installation and shows me the same error, now I have installed the Java 11, any idea??
I include the error in the image below
[Updated on: Thu, 11 November 2021 12:18] by Moderator
FUDForum. Page generated in 0.09054 seconds
