Home » Eclipse Projects » GEF » keyboard navigation across containers
keyboard navigation across containers [message #181649] Wed, 18 May 2005 12:06 Go to next message
I am unable to navigate (with the arrow keys) between a node in one
container to a node in another container (the containers share the same
parent and are physically next to each other). I can navigate between
nodes in the same container just fine...it just when I need to make the
"jump" to the next container's nodes the it doesn't work.
BTW (in case this matters), I have disabled selection requests for the
containers (I actually return the root edit part for the container
selection requests). This is because I want them to appear as part of the
root container (they are in essence swimlanes).
What piece of code is responsible for the arrow key navigation? What will
I need to do (roughly) to get cross container navigation?
- Jason
Re: keyboard navigation across containers [message #181812 is a reply to message #181649] Thu, 19 May 2005 11:42 Go to previous message
I haven't looked at the keyboard handler in a while, but I think there is a
navigation siblings method which rounds up all of the things which you want
to consider as at the same navigation level.
You know about ALT+UP and DOWN I assume?
"Jason Woods" <javajaws@excite.com> wrote in message
news:2e65099be37e1b819b69d8b4e2347cab$1@www.eclipse.org...
> - Jason
Previous Topic:Draw2d and SWT working together
Next Topic:BendConnectionRouter example request
Current Time: Tue Jul 22 04:55:54 EDT 2025
Powered by FUDForum. Page generated in 0.10332 seconds
