Problem with Java model to source code transformation [message #1804022] |
Fri, 15 March 2019 18:36  |
I have a problem with Java source code generation of Modisco java model.
I used this guide below in Modisco Documentation :
https://help.eclipse.org/2018-12/topic/org.eclipse.modisco.java.doc/mediawiki/java_generation/user.html?cp=67_0_1_1_2
firstly, I imported the plugin org.eclipse.gmt.modisco.java.generation in the workspace
then I added a class in src folder like this :
import java.io.File;
import java.io.IOException;
import java.util.*;
import org.eclipse.emf.common.util.URI;
import org.eclipse.gmt.modisco.java.generation.files.GenerateJavaExtended;
public class Generation {
public static void main(String[] args) throws IOException {
GenerateJavaExtended javaGenerator = new GenerateJavaExtended(URI.createFileURI("./mymodel.xmi"),
new File("./myOutputFolder"), new ArrayList<Object>());
javaGenerator.doGenerate(null);
But When I run this code as Java Application, I get this error :
Exception in thread "main" java.lang.IndexOutOfBoundsException: Index: 67, Size: 1
at java.util.ArrayList.rangeCheck(Unknown Source)
at java.util.ArrayList.get(Unknown Source)
at org.eclipse.emf.ecore.impl.EPackageImpl.eObjectForURIFragmentNameSegment(EPackageImpl.java:1970)
at org.eclipse.emf.ecore.impl.EModelElementImpl.eObjectForURIFragmentSegment(EModelElementImpl.java:473)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObject(ResourceImpl.java:811)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.getEObject(ResourceImpl.java:787)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setValueFromId(XMLHandler.java:2868)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.setAttribValue(XMLHandler.java:2773)
at org.eclipse.emf.ecore.xmi.impl.SAXXMIHandler.handleObjectAttribs(SAXXMIHandler.java:79)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFactory(XMLHandler.java:2247)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromTypeName(XMLHandler.java:2150)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObject(XMLHandler.java:2085)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.createObject(XMIHandler.java:151)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLHandler.java:1868)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1048)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMIHandler.java:82)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:1026)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:720)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHandler.java:190)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:261)
at org.eclipse.acceleo.model.mtl.resource.EMtlResourceImpl.doLoad(EMtlResourceImpl.java:93)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1563)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1342)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
at org.eclipse.acceleo.common.utils.ModelUtils.load(ModelUtils.java:391)
at org.eclipse.acceleo.common.utils.ModelUtils.load(ModelUtils.java:356)
at org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator.initialize(AbstractAcceleoGenerator.java:485)
at org.eclipse.gmt.modisco.java.generation.files.GenerateJava.<init>(GenerateJava.java:92)
at org.eclipse.gmt.modisco.java.generation.files.GenerateJavaExtended.<init>(GenerateJavaExtended.java:39)
at Generation.main(Generation.java:13)
How can I transform my java model back into the original Java source code?
My used tools:
- Eclipse Modeling tools 2018-12 (4.10.0)
- MoDisco SDK (1.2.0)
- JRE 1.8.0_202
FUDForum. Page generated in 0.51454 seconds
