Home » Eclipse Projects » SWTBot » Run SWTBot test in Headless mode. RCP application is not started
Run SWTBot test in Headless mode. RCP application is not started [message #1782656] Tue, 27 February 2018 07:28 Go to next message
Сolleagues
I observe an issue when I try to run SWTBot test suite from command line.
As started info I use this page : https://wiki.eclipse.org/SWTBot/Automate_test_execution#With_Ant_or_Command-Line
My ant script is
<project name="testsuite" default="run-swtbot-test" basedir=".">
	<property file="${basedir}/build.properties"/>
	<property name="temp.workspace" value="${basedir}"/>
	<property name="plugin.name" value="org.eclipsecon.swtbot.flexprod.rcpgui.automation"/>
	<property name="os" value="win32"/>
	<property name="ws" value="win32"/>
        <property name="arch" value="x86"/>
        <property name="eclipse-home" value="${rcp.gui.home}"/>
        <property name="jvmOption" value="-Djava.util.Arrays.useLegacyMergeSort=true -Duser.language=en -Duser.country=EN -Duser.variant=DE -cp ${rcp.gui.home}/plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar org.eclipse.core.launcher.Main -wsurl https://xxxx.xxxx.xxxx:XXXXX/guisrv/services/ -uurl http://xxxx.xxxxx.xxxx/" />
	<property name="library.file" value="${basedir}/library.xml"/>
	<target name="init-suite">
		<tstamp/>
		<delete>
			<fileset dir="${rcp.gui.home}" includes="org*.xml"/>
		</delete>
	</target>
	<target name="run-swtbot-test" depends="init-suite">
		<ant target="swtbot-test" antfile="${library.file}" dir="${rcp.gui.home}">
			<property name="testApplication" value="com.tsystems.ths.flexprod.rcp.application"/>
			<property name="data-dir" value="${temp.workspace}"/>
			<property name="plugin-name" value="${plugin.name}"/>
			<property name="classname" value="org.eclipsecon.swtbot.flexprod.rcpgui.automation.administration.Create2TemplatesWithuniqueMatno" />
			<property name="vmargs" value=" -Xms512M -Xmx512M -XX:MaxPermSize=256M ${jvmOption}" />
		</ant>
	</target>
	<target name="cleanup"/>
</project>
The issue is :
- the script started ,
- the initiating of eclipse platform started,
but
RCP application, that should be tested, not started. The following error message is saved in log
!ENTRY org.eclipse.osgi 4 0 2018-02-22 19:31:06.741
!MESSAGE Anwendungsfehler
!STACK 1
java.lang.RuntimeException: Die Anwendung {0} konnte nicht in der Registry gefunden werden. The verfügbaren Anwendungen sind: com.tsystems.ths.flexprod.rcp.application, org.eclipse.ant.core.antRunner, org.eclipse.equinox.app.error, org.eclipse.help.base.infocenterApplication, org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool, org.eclipse.update.core.standaloneUpdate, org.eclipse.update.core.siteOptimizer, com.tsystems.ths.administration.application, Com.tsystems.ths.exporter.application, com.tsystems.ths.flexprod.rdqs.application, com.tsystems.ths.imp.application, com.tsystems.ths.ipp.application, com.tsystems.ths.mdac.application, com.tsystems.ths.monitoring.application, com.tsystems.ths.productionmonitoring.application, com.tsystems.ths.tasklist.application
	at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:248)
	at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
	at org.eclipse.core.launcher.Main.main(Main.java:34)
As I understood this message. Build cannot find Application ID of Application that should be started. Actually the application with id com.tsystems.ths.flexprod.rcp.application should be run. This ID is passed by script but not found by eclipse platform. We can see this application id in list of possible application id.
Could you please help me to resolve this issue?
Also second question is : on page that mentioned above I found that SWTBot headless test execution is not tested under Windows. Is this piece of information correct right now, or not ?
[Updated on: Tue, 27 February 2018 07:57] by Moderator
Re: Run SWTBot test in Headless mode. RCP application is not started [message #1782750 is a reply to message #1782656] Wed, 28 February 2018 17:18 Go to previous messageGo to next message
Hi Alex,
I'm not familiar with running SWTBot with ant, but about the application id, it appears that the error message string was not translated properly in German, the binding {0} was probably single-quoted as '{0}' which escapes the binding, it should be double-quoted as ''{0}'' or "{0}", or not quoted at all.
Try removing the user.variant=DE to see if you can get the correct missing application id?
Patrick
Re: Run SWTBot test in Headless mode. RCP application is not started [message #1797589 is a reply to message #1782750] Fri, 02 November 2018 07:43 Go to previous message
Hello All
For running SWTBot test we use the following technic.
We have a set of properties that are loaded by ant before test
Where
formatter - is a class that responsible for creating updating test report
testPluginName is name of plugin where test cases and framework are located.
bundle.name=xx.xxx.xxxx.pluginName
application.root - path to application under testing location
cmd.ws=${application.root}/config/workspace
cmd.app=org.eclipse.swtbot.eclipse.junit.headless.swtbottestapplication
cmd.common=-Xms512m -Xmx512m -Djava.util.Arrays.useLegacyMergeSort=true -DPLUGIN_PATH= -cp ${application.root}/plugins/org.eclipse.equinox.launcher_1.2.0.v20110502.jar org.eclipse.core.launcher.Main  -application ${cmd.app} -testPluginName ${bundle.name} formatter=${cmd.formatter1} formatter=${cmd.formatter2} -testApplication ${bundle.name} -data ${cmd.ws} -os win32 -ws win32 -arch x86_64 -consoleLog -debug -clean -console localhost:8811
we run suite via
cmd.run.suite.admin=java ${cmd.common} -className ${cmd.suite.core}
so in ant we have
<exec spawn="false" executable="cmd">
            <arg value="/c"/>
            <arg value="${cmd.run.suite.admin}"/>
        </exec>
Where cmd.suite.core - name of JUnit testsuite class
Main idea is we don't start application under testing itself. We start special SWTBot application. (${cmd.app}
[Updated on: Fri, 02 November 2018 07:44] by Moderator
Previous Topic:Unable to read SWTBotBrowser text content < Photon
Next Topic:SWTBot in headless mode and java.lang.ExceptionInInitializerError
Current Time: Fri Jul 25 18:21:55 EDT 2025
Powered by FUDForum. Page generated in 0.24439 seconds
