Home » Eclipse Projects » GEF » Zest5: getting the model node from the displayed node
Zest5: getting the model node from the displayed node [message #1783560] Wed, 14 March 2018 03:15 Go to next message
My graph model is implemented as an IGraphContentProvider, it is displayed with Zest (Oxygen release version).
I want to know which node is selected (the node given by my provider, I call it modelNode), I was thinking that it is a common use case, but I didn't find an easy way to do it.
There was a IFXOnClickPolicy in Gef4, I don't see it anymore in current version.
Here is my current design:
I follow the advice given in this forum, that is: I create a new MyModule class that extends ZestFxModule and override the #bindNodePartAdapters() method to attach my handler.
In my handler, The #click(MouseEvent e) give me access to the org.eclipse.gef.zest.fx.parts.NodePart object with getHost()
The NodePart is created by ZestFxContentPartFactory.createContentPart() when the content is a graphNode, an instance of org.eclipse.gef.graph.Node (no links is kept between the NodePart and the graphNode, but we could have it by subclassing the Factory)
The graphNode itself is created by ZestContentViewer.createNode() who has access to my modelNode (given by my IGraphContentProvider) but if the ZestContentViewer maintains a map (called contentNodeMap) from modelNode to graphNode, I need the reverse; Again, I need to subclass to viewer to keep this needed link.
So my question is: is there a simple way to get from the mouse click to my modelNode ?
Dominique
Re: Zest5: getting the model node from the displayed node [message #1783948 is a reply to message #1783560] Tue, 20 March 2018 11:43 Go to previous messageGo to next message
I have simplified my design, here is it for anyone interested.
There is already an attached handler (FocusAndSelectOnClickHandler), we can benefit from it because y using Viewer.addSelectionChangedListener().
The graphNode is set as the primary content of the contentPart, so the above is not needed. Moreover, the registered listener receives directly the graphNode in the selection (it get it of course with the primary content, that's how I discover this).
I didn't find a better way, so I have added a nodeContentMap in my viewer subclass.
Dominique
Re: Zest5: getting the model node from the displayed node [message #1785835 is a reply to message #1783948] Fri, 20 April 2018 07:59 Go to previous message
Hi Dominique,
you are right w.r.t. the node-content-map. Subclassing ZestContentViewer is an adequate solution. I created https://bugs.eclipse.org/bugs/show_bug.cgi?id=533870 to keep track of the issue.
The IFXOnClickHander interface was simply renamed to IOnClickHandler. You can still register custom handlers via the module. However, as you figured already, the selection can be reused.
regards,
Matthias
Previous Topic:how to test view in GEF MVC
Next Topic:[GEF5] Hover Feedback parts and zoom
Current Time: Sat Jul 19 20:49:50 EDT 2025
Powered by FUDForum. Page generated in 0.04648 seconds
