Home » Language IDEs » Java Development Tools (JDT) » Eclipse unstable in Mac OS
Eclipse unstable in Mac OS [message #17162] Thu, 08 May 2003 07:41 Go to next message
Originally posted by: j.dieckmann.psi-bt.de
Eclipse 2.1 is really a great IDE. I only have 2 complaints when running
Eclipse under Mac OS 10.2.6:
- Eclipse is very slow. I very much hope the performance will be better in
one of the next releases. Are there some informations about optimizations
for mac os?
- Eclipse crashes (about 3 times per hour). The version is stable and "rock
solid" under NT, and XP. I never had a crash when running Eclipse under
these systems. I can't give an exact error report. The situation differs and
the crash is not reproducable. But it chrashes often when I start an ant
task and the console window is not open. Has anyone else made these
observation? Is there something in the settings which could be wrong?
regards
Jan Dieckmann
Re: Eclipse unstable in Mac OS [message #17776 is a reply to message #17162] Thu, 08 May 2003 13:17 Go to previous messageGo to next message
Originally posted by: pchen3.jhmi.edu
Dear Jan,
I use Eclipse with my OS X 10.2.5 and XP box. I have the same performance
problem you have.
My Windows box (PIII 933 MHz / 512 MB RAM) runs Eclipse 2.1 noticeably
faster than my Eclipse
running on my OS X box (G4 1 GHz / 1 GB RAM). The GUI is much more
responsive on my
Windows box. I'm surmising that this performance difference may be
partially due to the OS X
implementation of SWT. Obviously, there are many performance factors to
consider since we are
kind of comparing apples with oranges. But, the performance degradation
of Eclipse on my OS X
is such that it is a problem (I mean code assist takes longer than me
typing in things myself!).
As for the stability of Eclipse on OS X, I've had it crash on me a few
times, but certainly not as
much as you have experienced. I don't use Ant though. Make sure you have
the latest JVM
(1.4.1) for OS X. Eclipse crashes no more often than other OS X apps. OS
X as a whole feels a bit
like Win98 in terms of stability.
On the whole though, I'm glad we have Eclipse as an option. You're right,
it is a great IDE. The
standard Swing widgets look like ass and it's great to see better looking
interfaces with SWT.
Peter
> for mac os?
> regards
> Jan Dieckmann
Re: Eclipse unstable in Mac OS [message #19092 is a reply to message #17162] Fri, 09 May 2003 20:05 Go to previous messageGo to next message
> for mac os?
I heard the SWT team is working hard to cleanup MacOSX since it became a
primary platform for the Eclipse 2.2 plan.
> observation?
I could make Eclipse 2.1 on macosx 10.2.5 and Java 1.4 crash by closing
a long tree in a java left pane when many jars were present (say, around
50 of them).
The problem is drastically reduced when I moved back to Java 1.3
Apple's version of Java 1.4 is not so solid as they paint it to be. I'm
sure they will come up with a bugfix release soon.
Also, the carbon port of SWT is, well, alpha quality, I would say, for
2.1. The good news is that the SWT team is fully aware of this and they
are focusing on making it better. I think Eclipse on mach-o can only get
better, it's just a matter of time or getting our hands dirty and help
the SWT fix thingg :-)
Oh, did I mention I love eclipse? :-)
If only wasn't this slow on macs :-(
but I just downloaded the lastest integration build and I'll try it out
right after this.
Stefano.
Re: Eclipse unstable in Mac OS [message #19095 is a reply to message #19092] Fri, 09 May 2003 20:58 Go to previous messageGo to next message
Originally posted by: bob.objfac.com
"Stefano Mazzocchi" <stefano@apache.org> wrote in message
news:b9hfo9$f24$1@rogue.oti.com...
I'm really hoping that's still true, now that it doesn't look like there
will be an Eclipse 2.2.
No, but now that you mention it, me too! ;-}
Bob
Re: Eclipse unstable in Mac OS [message #20836 is a reply to message #19092] Tue, 13 May 2003 06:14 Go to previous message
> right after this.
Thank you for your answer. I will go back to Java 1.3. Would you please
report to this newsgroup if the integration build runs better on mac os X?
best regards Jan Dieckmann
Previous Topic:Eclipse crashes when changing perspectives
Next Topic:Capturing output from an ant task
Current Time: Thu Nov 13 22:37:47 EST 2025
Powered by FUDForum. Page generated in 0.04137 seconds
