Home » Newcomers » Newcomers » Error When I going to Run Eclipse(Error When I going to Run Eclipse)
Error When I going to Run Eclipse [message #1774927] Sat, 21 October 2017 05:18 Go to next message
!SESSION 2017-10-21 14:31:18.303 -----------------------------------------------
eclipse.buildId=M20120208-0800
java.version=9.0.1
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_IN
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.jee.product
!ENTRY org.eclipse.equinox.simpleconfigurator 4 0 2017-10-21 14:31:18.944
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: The bundle "org.eclipse.equinox.simpleconfigurator_1.0.200.v20110815-1438 [2]" could not be resolved. Reason: Missing Constraint: Bundle-RequiredExecutionEnvironment: CDC-1.1/Foundation-1.1,J2SE-1.4
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.java:1327)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolutionFailureException(AbstractBundle.java:1311)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:323)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:389)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1131)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.osgi 4 0 2017-10-21 14:31:18.959
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.simpleconfigurator_1.0.200.v20110815-1438.jar/ was not resolved.
!ENTRY org.eclipse.osgi 2 0 2017-10-21 14:31:18.959
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2017-10-21 14:31:18.959
!MESSAGE Bundle javax.transaction_1.1.1.v201105210645 [1] was not resolved.
!SUBENTRY 2 javax.transaction 2 0 2017-10-21 14:31:18.959
!MESSAGE Missing Constraint: Bundle-RequiredExecutionEnvironment: J2SE-1.5
!MESSAGE Bundle org.eclipse.equinox.simpleconfigurator_1.0.200.v20110815-1438 [2] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.simpleconfigurator 2 0 2017-10-21 14:31:18.959
!MESSAGE Missing Constraint: Bundle-RequiredExecutionEnvironment: CDC-1.1/Foundation-1.1,J2SE-1.4
!ENTRY org.eclipse.osgi 4 0 2017-10-21 14:31:18.975
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:74)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.base/java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
Re: Error When I going to Run Eclipse [message #1774940 is a reply to message #1774927] Sun, 22 October 2017 00:53 Go to previous message
You are trying to use JDK 9 with a version of Eclipse that predates it by several years. You need to download the latest Eclipse release, Oxygen.1a, or modify the release you have using the guidance from https://wiki.eclipse.org/Configure_Eclipse_for_Java_9 .
Previous Topic:Eclipse wont start, fresh install, OSX Sierra
Next Topic:host/guest PDT
Current Time: Wed Nov 05 15:22:41 EST 2025
Powered by FUDForum. Page generated in 0.10187 seconds
