Home » Newcomers » Newcomers » Updated Java now Eclipse oxygen won't run.(Updated Java now Eclipse oxygen won't run.)
Updated Java now Eclipse oxygen won't run. [message #1769097] Wed, 26 July 2017 10:01 Go to next message
Help!!! Apologies if this has been done previously!! I am new to Java and currently learning.....slowly!! This morning my PC prompted me that I have an update for Java, I updated accordingly. Then when I go to open my Eclipse Oxygen I get the following message.
A Java Runtime Environment (JRE) or Java Development Kit (JDK) must be available in order to run eclipse. No Java virtual machine was found after searching the following locations .......
I did a google search and found a link on youtube that runs me though cutting a pasting into my environment variables which I followed to the letter but still no joy.... Can anyone advise or assist me in anyway?
Many thanks
Mike
Re: Updated Java now Eclipse oxygen won't run. [message #1769110 is a reply to message #1769097] Wed, 26 July 2017 11:08 Go to previous messageGo to next message
Look in the eclipse.ini. Does it have a -vm option like this:
-vm
C:\Program Files\Java\jdk1.8.0_121\bin
Look in the C:\Program Files\Java folder and find the newest version that exists there and replace it with that.
Re: Updated Java now Eclipse oxygen won't run. [message #1769113 is a reply to message #1769110] Wed, 26 July 2017 11:30 Go to previous messageGo to next message
Ed Merks - Thank you so much!!! I did what you said and it is now working!!!!
Thanks again!!!
Re: Updated Java now Eclipse oxygen won't run. [message #1769118 is a reply to message #1769113] Wed, 26 July 2017 13:24 Go to previous messageGo to next message
Yes, I wish the Java installer didn't insist on deleting older installations, or at least it would be good if it asked if that's what you wanted. Of course there might be things referencing to the older version that you don't want to have broken...
Re: Updated Java now Eclipse oxygen won't run. [message #1805579 is a reply to message #1769118] Wed, 17 April 2019 12:14 Go to previous message
Maybe there is some way of hiding the old java files from the updating process, get the latest JRE, and then put the old one back where you got it. I haven't tried this.
Previous Topic: The installer the eclipse!
Next Topic:IDE GIT throws an exception when I try to import certain repos
Current Time: Tue Oct 14 15:05:22 EDT 2025
Powered by FUDForum. Page generated in 0.09095 seconds
