Home » Language IDEs » AspectJ » AJDT on Neon
AJDT on Neon [message #1715918] Fri, 27 November 2015 12:03 Go to next message
Is there any version of AJDT which works on the latest version of Neon?
Thanks!
-Kaj Smile
Re: AJDT on Neon [message #1728034 is a reply to message #1715918] Wed, 30 March 2016 09:09 Go to previous messageGo to next message
I also want this to know.
Frank
Re: AJDT on Neon [message #1729917 is a reply to message #1728034] Wed, 20 April 2016 05:22 Go to previous messageGo to next message
Try adding this site:
http://download.eclipse.org/tools/ajdt/46/dev/update
Re: AJDT on Neon [message #1734495 is a reply to message #1729917] Wed, 08 June 2016 15:54 Go to previous messageGo to next message
Hi Bartlomiej
thanks, that worked.
First I had to properly uninstall the earlier AJDT, then it worked.
It would be good if this link can be found on the page.
Frank
Re: AJDT on Neon [message #1748269 is a reply to message #1734495] Mon, 21 November 2016 11:32 Go to previous messageGo to next message
I have added this on my Eclipse Neon (v4.6.1). But i cannot create aspects, or aspect projects. I do not see any aspect oriented features whatsoever.
I also have Spring Tool Suite, Maven, Ant etc. I haven't configured Spring (i don't believe this is needed thought to get AOP capabilities).
Also i was told that this website http://download.eclipse.org/tools/ajdt/neon/update/ is the one i'm looking for. However it doesn't have any content.
The only thing i've managed to do is to get the aspectj annotation syntax by downloading the library from here: https://eclipse.org/aspectj/downloads.php . I just downloaded the latest version
But i'd rather work with Eclipse, if that is possible. What AJDT do i have to download to integrate the aspectj language, as well as creating aspects / aspect projects on Eclipse Neon (4.6), Windows x86_64 ?
Thanks in advance.
Re: AJDT on Neon [message #1764567 is a reply to message #1715918] Wed, 31 May 2017 06:19 Go to previous message
Same proble here....
Is any way to use AspectJ plugin in eclipse Neon? is that project dead?
Previous Topic:AspectJ Logger under existing project.
Next Topic:Plug-in org.eclipse.jdt.ui was unable to load class org.eclipse.jdt.internal.ui.javaeditor.Compilati
Current Time: Sun Jul 20 23:21:23 EDT 2025
Powered by FUDForum. Page generated in 0.26439 seconds
