Eclipse Titan - Editing changes not saved [message #1759014] |
Wed, 05 April 2017 05:15 |
I am facing some problems when it comes to saving some changes in Eclipse Titan. After every save even though the .ttcn file was changed, in the log files there seem to still persist the unchanged version of the code. All in all the changes do not take effect. I am using Windows 7.
My makefile looks as follows:
# This Makefile was generated by the TITAN Designer eclipse plug-in
# of the TTCN-3 Test executor version CRL 113 200/5 R5B
# for (ljti@W4DEUMSY9001696) on Wed Apr 05 10:47:03 CEST 2017
# Copyright (c) 2000-2015 Ericsson Telecom AB
# The following make commands are available:
# - make, make all Builds the executable test suite.
# - make archive Archives all source files.
# - make check Checks the semantics of TTCN-3 and ASN.1 modules.
# - make clean Removes all generated files.
# - make port Generates port skeletons.
# - make compile Translates TTCN-3 and ASN.1 modules to C++.
# - make dep Creates/updates dependency list.
# - make executable Builds the executable test suite.
# - make library Builds the library archive: '/cygdrive/c/Users/ljti/workspace/SMGWAdminCommunication/bin/SMGWAdminCommunication.a'.
# - make objects Builds the object files without linking the executable.
# WARNING! This Makefile can be used with GNU make only.
# Other versions of make may report syntax errors in it.
# Do NOT touch this line...
.PHONY: all executable library objects check port clean dep archive
.SUFFIXES: .d
# Set these variables...
# The path of your TTCN-3 Test Executor installation:
# Uncomment this line to override the environment variable.
# TTCN3_DIR =
# Your platform: (SOLARIS, SOLARIS8, LINUX, FREEBSD or WIN32)
PLATFORM = WIN32
# Your C++ compiler:
# (if you change the platform, you may need to change the compiler)
CXX = g++
# Flags for dependency generation
CXXDEPFLAGS := -MM
# Flags for the C++ preprocessor (and makedepend as well):
CPPFLAGS = -D$(PLATFORM) -I. -I$(TTCN3_DIR)/include -I. -I../src
# Flags for the C++ compiler:
CXXFLAGS = -Wall -O2
# Flags for the linker:
LDFLAGS =
ifeq ($(PLATFORM), WIN32)
# Silence linker warnings.
LDFLAGS += -Wl,--enable-auto-import,--enable-runtime-pseudo-reloc
endif
# Utility to create library files
AR = ar
ARFLAGS =
# Flags for the TTCN-3 and ASN.1 compiler:
COMPILER_FLAGS = -lL
# Execution mode: (either ttcn3 or ttcn3-parallel)
TTCN3_LIB = ttcn3-parallel
# The path of your OpenSSL installation:
# If you do not have your own one, leave it unchanged.
OPENSSL_DIR = $(TTCN3_DIR)
# The path of your libxml2 installation:
XMLDIR = $(TTCN3_DIR)
# Directory to store the archived source files:
ARCHIVE_DIR = backup
# You may change these variables. Add your files if necessary...
# TTCN-3 modules of this project:
TTCN3_MODULES = ../src/MyModule.ttcn
# ASN.1 modules of this project:
ASN1_MODULES =
# C++ source & header files generated from the TTCN-3 & ASN.1 modules of
# this project:
GENERATED_SOURCES = MyModule.cc
GENERATED_HEADERS = $(GENERATED_SOURCES:.cc=.hh)
# C/C++ Source & header files of Test Ports, external functions and
# other modules:
USER_SOURCES = ../src/GWAdminInputPort.cc ../src/MyModule.cc ../src/SMGWOutputPort.cc
USER_HEADERS = ../src/GWAdminInputPort.hh ../src/MyModule.hh ../src/SMGWOutputPort.hh
# Object files of this project that are needed for the executable test suite:
OBJECTS = $(GENERATED_OBJECTS) $(USER_OBJECTS)
GENERATED_OBJECTS = $(GENERATED_SOURCES:.cc=.o)
USER_OBJECTS = GWAdminInputPort.o MyModule.o SMGWOutputPort.o
# Dependency files of this project that are needed for the executable test suite:
DEPFILES = $(USER_OBJECTS:.o=.d) $(GENERATED_OBJECTS:.o=.d)
# Other files of the project (Makefile, configuration files, etc.)
# that will be added to the archived source files:
OTHER_FILES = Makefile ../src/MyModule.cfg
# The name of the executable test suite:
EXECUTABLE = /cygdrive/c/Users/ljti/workspace/SMGWAdminCommunication/bin/SMGWAdminCommunication.exe
LIBRARY = /cygdrive/c/Users/ljti/workspace/SMGWAdminCommunication/bin/SMGWAdminCommunication.a
TARGET = $(EXECUTABLE)
# Do not modify these unless you know what you are doing...
# Platform specific additional libraries:
SOLARIS_LIBS = -lsocket -lnsl -lxml2 -lresolv
SOLARIS8_LIBS = -lsocket -lnsl -lxml2 -lresolv
LINUX_LIBS = -lxml2 -lpthread -lrt
FREEBSD_LIBS = -lxml2
WIN32_LIBS = -lxml2
# Rules for building the executable...
all: $(TARGET) ;
executable: $(EXECUTABLE) ;
library: $(LIBRARY) ;
objects: $(OBJECTS) compile;
$(EXECUTABLE): $(OBJECTS)
$(CXX) $(LDFLAGS) -o $@ $^ \
-L$(TTCN3_DIR)/lib -L$(OPENSSL_DIR)/lib -L$(XMLDIR)/lib \
-l$(TTCN3_LIB) -lcrypto \
$($(PLATFORM)_LIBS) \
|| if [ -f $(TTCN3_DIR)/bin/titanver ]; then $(TTCN3_DIR)/bin/titanver $^; else : ; fi
$(LIBRARY): $(OBJECTS)
$(AR) -r $(ARFLAGS) $(LIBRARY) $(OBJECTS)
GWAdminInputPort.o : ../src/GWAdminInputPort.cc
$(CXX) -c $(CPPFLAGS) $(CXXFLAGS) -o $@ $<
MyModule.o : ../src/MyModule.cc
SMGWOutputPort.o : ../src/SMGWOutputPort.cc
.cc.o .c.o:
GWAdminInputPort.d : ../src/GWAdminInputPort.cc
@echo Creating dependency file for '$<'; set -e; \
$(CXX) $(CXXDEPFLAGS) $(CPPFLAGS) $(CXXFLAGS) $< \
| sed 's/\($*\)\.o[ :]*/\1.o $@ : /g' > $@; \
[ -s $@ ] || rm -f $@
MyModule.d : ../src/MyModule.cc
SMGWOutputPort.d : ../src/SMGWOutputPort.cc
.cc.d .c.d:
$(GENERATED_SOURCES) $(GENERATED_HEADERS): compile
@if [ ! -f $@ ]; then $(RM) compile; $(MAKE) compile; fi
check: $(TTCN3_MODULES) $(ASN1_MODULES)
$(TTCN3_DIR)/bin/compiler -s $(COMPILER_FLAGS) $^
port: $(TTCN3_MODULES)
$(TTCN3_DIR)/bin/compiler -t $(COMPILER_FLAGS) $^
compile: $(TTCN3_MODULES) $(ASN1_MODULES)
$(TTCN3_DIR)/bin/compiler $(COMPILER_FLAGS) $^ - $?
touch $@
browserdata.dat: $(TTCN3_MODULES) $(ASN1_MODULES)
$(TTCN3_DIR)/bin/compiler -B -s $(COMPILER_FLAGS) $^
clean:
-$(RM) $(EXECUTABLE) $(OBJECTS) $(LIBRARY) $(GENERATED_HEADERS) $(DEPFILES) \
$(GENERATED_SOURCES) compile \
browserdata.dat tags *.log $(DEPFILES)
dep: $(GENERATED_SOURCES) $(USER_SOURCES) $(DEPFILES) ;
ifeq ($(filter clean check port compile archive,$(MAKECMDGOALS)),)
-include $(DEPFILES)
endif
archive:
mkdir -p $(ARCHIVE_DIR)
tar -cvhf - $(TTCN3_MODULES) $(ASN1_MODULES) \
$(USER_HEADERS) $(USER_SOURCES) $(OTHER_FILES) \
| gzip >$(ARCHIVE_DIR)/`basename $(TARGET) .exe`-`date '+%y%m%d-%H%M'`.tgz
diag:
$(TTCN3_DIR)/bin/compiler -v 2>&1
$(TTCN3_DIR)/bin/mctr_cli -v 2>&1
$(CXX) -v 2>&1
$(AR) -V 2>&1
@echo TTCN3_DIR=$(TTCN3_DIR)
@echo OPENSSL_DIR=$(OPENSSL_DIR)
@echo XMLDIR=$(XMLDIR)
@echo PLATFORM=$(PLATFORM)
# Add your rules here if necessary...
Ljupka
FUDForum. Page generated in 0.04164 seconds
