error in if condition [message #1754501] |
Sun, 19 February 2017 01:52  |
If I write the below ATL code, I have the error "org.eclipse.m2m.atl.engine.emfvm.VMException: Feature method does not exist on PropertyCallExpression".
helper context MM_ETL!Expression def : collectWithFeatureFollowing() : Boolean =
if ((self.oclIsTypeOf(MM_ETL!PropertyCallExpression) or thisModule.isAHelper(self)) and not self.oclIsKindOf(MM_ETL!FOLMethodCallExpression).oclIsUndefined())
then if (self.method.name = 'collect')
if I change the code to the below code, I have the error "org.eclipse.m2m.atl.engine.emfvm.VMException: java.lang.Boolean does not have properties".
if (self.oclIsKindOf(MM_ETL!FOLMethodCallExpression).method.name = 'collect')
what can I do to access method?
[Updated on: Sun, 05 March 2017 15:45] by Moderator
FUDForum. Page generated in 0.10063 seconds
