Home » Archived » BIRT » Complie BIRT 2_0_1 error BUILD FAILED
Complie BIRT 2_0_1 error BUILD FAILED [message #167069] |
Fri, 02 June 2006 10:29  |
Hello People,
I tried downloading BIRT 2_0_1 Release and following the instructions given
at http://www.eclipse.org/birt/phoenix/build/buildInstructions. php
However, when I try to build (compile) the project as per these
instructions, the build process fails with the following error:
BUILD FAILED
C:\eclipse\workspace\org.eclipse.birt.report.viewer\BuildVie wer.xml:263: The
following error occurred while executing this line:
C:\eclipse\workspace\org.eclipse.birt.data.oda.adapter.dtp\B uildDtpOdaAdapter.xml:83:
C:\eclipse\workspace\org.eclipse.birt.report.viewer\plugins not found.
Can anybody tell me where I am going wrong?
Thanks in advance,
Girish
Re: Complie BIRT 2_0_1 error BUILD FAILED [message #175068 is a reply to message #174886] |
Tue, 04 July 2006 05:56   |
Originally posted by: emina.karic.dsek.lth.se
BUILD FAILED
C:\Documents and
Settings\EEMIKAR\workspace\org.eclipse.birt.report.viewer\Bu ildViewer.xml:26
3: The following error occurred while executing this line:
C:\Documents and
Settings\EEMIKAR\workspace\org.eclipse.birt.data.oda.adapter .dtp\BuildDtpOda
Adapter.xml:83: C:\Documents and
Settings\EEMIKAR\workspace\org.eclipse.birt.report.viewer\pl ugins not found.
Total time: 16 seconds
"Jason Weathersby" <jweathersby@actuate.com> wrote in message
news:e8ba0f$q1u$1@utils.eclipse.org...
> Can you post a screenshot of where you are setting the home and
> also post the error message?
> Jason
> "Emina Karic" <emina.karic@dsek.lth.se> wrote in message
> news:e8amfa$hcd$1@utils.eclipse.org...
> > Yeah, that's the one I've been following. I have the same exact problem
> > except that setting the eclipse.home didn't fix the problem.
> > Any clues?
> > Thanks in advance
> > Emina
> > news:e89obj$opk$1@utils.eclipse.org...
> >> Take a look here:
> >> http://www.eclipse.org/birt/phoenix/build/buildInstructions. php#viewer
> >> Jason
> >> news:e832rq$rnd$1@utils.eclipse.org...
> >> >I have this exact problem when building BIRT 2.0.1. I thought I had
set
> > the
> >> > eclipse.home variable, but I still get the same error. I'm guessing I
> >> > didn't
> >> > do it quite right. What is the correct way to set it?
> >> > Thanks in advance
> >> > Emina
> >> > "Girish" <girisha@cybage.com> wrote in message
> >> > news:e63boh$sq1$1@utils.eclipse.org...
> >> >> I had forgot to add that one, thanks a lot for it Jason, it works
fine
> >> > now!
> >> >> news:e61bk3$erl$1@utils.eclipse.org...
> >> >> > Did you add the eclipse.home variable?
> >> >> > Jason
> >> >> > news:e5pi43$o2l$1@utils.eclipse.org...
> >> >> >> Hello People,
> > instructions
> >> >> >> given at
> >> >> >> BUILD FAILED
> >> > r.xml:83:
> > found.
> >> >> >> Thanks in advance,
> >> >> >> Girish
Attachment: scr.jpg
(Size: 61.09KB, Downloaded 106 times)
Re: Complie BIRT 2_0_1 error BUILD FAILED [message #176174 is a reply to message #175725] |
Mon, 10 July 2006 04:32  |
> Do you have a plugins directory below Test-Eclipse-3.1?
> If the directory is Test-Eclipse-3.1/eclipse/plugins then change your
entry
> to
> Test-Eclipse-3.1/eclipse.
> I dont have quotes around the name or the value BTW.
> I am not certain if this matters.
Yes, the plugin directory is directly below Test-Eclipse-3.1. As far as the
quotes go, I've tried both with and without. Doesn't really matter, it
seems.
> Also is you using 2.1 look at the Build Web Viewer instructions that are
> downloaded as part of the source.
> Jason
I'm actually trying to build BIRT 2.0.1. So I'm following the instructions
on:
I really can't figure out where it goes wrong. Thanks in advance.
Emina
Current Time: Sun Jul 20 06:01:34 EDT 2025
Powered by FUDForum. Page generated in 0.04987 seconds
