Unable to Preference Synchronizer due to invalid password [message #1740021] |
Mon, 08 August 2016 05:53  |
I'm using Eclipse Preference Synchronizer to synchronize the settings on the new Eclipse installation. Unfortunately I have entered an incorrect password and now I'm unable to synchronize nor change the password to the correct one. I can see in the Error Log view that the password is incorrect
org.eclipse.userstorage.util.ProtocolException: POST https://api.eclipse.org/api/user/login HTTP/1.1 403 : The username has not been activated or is blocked.
at org.eclipse.userstorage.internal.Session$RequestTemplate.getStatusCode(Session.java:656)
at org.eclipse.userstorage.internal.Session$RequestTemplate.authenticate(Session.java:471)
at org.eclipse.userstorage.internal.Session$RequestTemplate.send(Session.java:396)
at org.eclipse.userstorage.internal.Session.retrieveBlob(Session.java:226)
at org.eclipse.userstorage.internal.StorageService.retrieveBlob(StorageService.java:273)
at org.eclipse.userstorage.internal.Storage.retrieveBlob(Storage.java:369)
at org.eclipse.userstorage.internal.Blob.getContents(Blob.java:108)
at org.eclipse.oomph.setup.internal.sync.RemoteDataProvider.retrieve(RemoteDataProvider.java:89)
at org.eclipse.oomph.setup.internal.sync.Snapshot.createWorkingCopy(Snapshot.java:110)
at org.eclipse.oomph.setup.internal.sync.Synchronization.createWorkingCopy(Synchronization.java:152)
at org.eclipse.oomph.setup.internal.sync.Synchronization.<init>(Synchronization.java:92)
at org.eclipse.oomph.setup.internal.sync.Synchronizer.createSynchronization(Synchronizer.java:126)
at org.eclipse.oomph.setup.internal.sync.Synchronizer.synchronize(Synchronizer.java:103)
at org.eclipse.oomph.setup.internal.sync.SynchronizerJob.run(SynchronizerJob.java:144)
Is there a way to change the password somehow?
FUDForum. Page generated in 0.03531 seconds
