Home » Modeling » GMF (Graphical Modeling Framework) » [Sample Ecore Editor] Edit operation parameters
[Sample Ecore Editor] Edit operation parameters [message #173715] Fri, 22 February 2008 09:24 Go to next message
Originally posted by: stefan.bley.saxsys.de
some months ago I already pointed out that it is not possible to set the
parameters of EOperation in the GMF Sample Ecore Editor.
Since I hope this will get fixed sooner or later, I would like to
reference to Topcased's Ecore Editor that provides this feature. Maybe
there could be some kind of knowledge transfer.
http://topcased-mm.gforge.enseeiht.fr/website/modeling/ecore /
Regards, Stevy
Re: [Sample Ecore Editor] Edit operation parameters [message #173735 is a reply to message #173715] Fri, 22 February 2008 09:31 Go to previous messageGo to next message
--------------060302060409070109050403
Stefan,
Have you tried the graphical editor provided by the Ecore Tools
component of EMFT?
http://www.eclipse.org/modeling/emft/?project=ecoretools
It's being developed by the same folks who did the Topcased one. I think
there might be problems if you install the GMF one and the Ecore Tools
one together, so best to delete/disable the GMF one...
Stefan Bley wrote:
> the parameters of EOperation in the GMF Sample Ecore Editor.
> Regards, Stevy
<html>
<head>
http-equiv="Content-Type">
</head>
Stefan,<br>
<br>
component of EMFT?<br>
<blockquote><a
href="http://www.eclipse.org/modeling/emft/?project=ecoretools">http://www.eclipse.org/modeling/emft/?project=ecoretools</a><br>
</blockquote>
think there might be problems if you install the GMF one and the Ecore
Tools one together, so best to delete/disable the GMF one...<br>
<br>
Stefan Bley wrote:
<blockquote cite="mid:fpmlul$1v6$1@build.eclipse.org" type="cite">Hi,
<br>
<br>
<br>
<br>
<br>
<a class="moz-txt-link-freetext" href=" http://topcased-mm.gforge.enseeiht.fr/website/modeling/ecore /"> http://topcased-mm.gforge.enseeiht.fr/website/modeling/ecore /</a>
<br>
<br>
Regards, Stevy
<br>
</blockquote>
<br>
</body>
</html>
--------------060302060409070109050403--
Re: [Sample Ecore Editor] Edit operation parameters [message #173742 is a reply to message #173735] Fri, 22 February 2008 09:54 Go to previous messageGo to next message
Ed,
You do not need to disable the GMF one as we fixed the problem we got
previously when both Ecore Tools and GMF Sample Ecore editor were
activated. See https://bugs.eclipse.org/bugs/show_bug.cgi?id=214113
Ed Merks a écrit :
> Stefan,
> component of EMFT?
> Stefan Bley wrote:
>> Hi,
>> Regards, Stevy
Re: [Sample Ecore Editor] Edit operation parameters [message #173779 is a reply to message #173735] Fri, 22 February 2008 10:29 Go to previous messageGo to next message
> component of EMFT?
Unlike Topcased's version, the Ecore editor from EMFT makes my Eclipse
instance hang up. Is it compatible to Europa compliant plugins or do I
need newer ones (e.g. EMF)?
What I would like to do is to re-use the editor/edit parts of Ecore in
my own editor. E.g. I want to provide a meta element "Operation" and
re-use the edit/editor parts of EOperation. Especially the new
"Parameters" tab in EOperation's properties view.
Stefan
Re: [Sample Ecore Editor] Edit operation parameters [message #173803 is a reply to message #173779] Fri, 22 February 2008 11:48 Go to previous message
Yes, Ecore Tools is not compliant with Eclipse Europa version. As we
started a few months ago, and that we highly depends on the new features
developed as part of GMF, we are targeting the Ganymede release only for
the moment, so you need to install the corresponding 3.4 milestone version.
>> component of EMFT?
> Stefan
Previous Topic:GMF and MultiPageEditorPart
Next Topic:Dependency to EMF.edit plug-in
Current Time: Sun Jun 15 20:04:26 EDT 2025
Powered by FUDForum. Page generated in 0.33882 seconds
