Home » Modeling » GMF (Graphical Modeling Framework) » Modifying EObjects without transactions?
Modifying EObjects without transactions? [message #172874] Tue, 19 February 2008 02:39 Go to next message
Is there a way to modify semantic objects in the editor domain without a
transaction?
What I'm trying to is this: I have a GMF diagram editor that builds a
workflow. I'd like to build in a visual debugger where you can trigger
the workflow (from some external event on a separate thread) and step
through the workflow with some visual cue indicating the active workflow
step.
The problem I'm having is that because the workflow runtime portion is
triggered by an outside event (not via a command) of course I get the
"cannot modify xxx without write transaction..." exception. If I wrap
the trigger in a command the workflow executes fine but I don't get
notified of any of the changes until the current transaction commits (so
they all happen at once).
Optimally I'd like to be able to have a mode where the workflow runtime
is allowed to modify the EObjects without a transaction and still have
the notification events sent to my edit parts so they get updated in
real time.
I guess another option would be to have some kind of custom transaction
that auto-commits after each change or something but I'm not sure where
to begin or if what I'm trying to do is within the realm of reasonable
possibility.
Any ideas would be greatly appreciated!
Zac
Re: Modifying EObjects without transactions? [message #172896 is a reply to message #172874] Tue, 19 February 2008 04:58 Go to previous messageGo to next message
Originally posted by: jan.herriger.gmx.de
Hi Zac,
my first thought was: why don't you put each workflow step into a single
command and execute them one after another? But this thought may not be
elaborated well ;-)
> transaction?
> step.
> real time.
> possibility.
> Zac
Re: Modifying EObjects without transactions? [message #172972 is a reply to message #172896] Tue, 19 February 2008 10:59 Go to previous messageGo to next message
Thanks Jan,
That's a good thought but the problem is that I use the same model
project for the actual runtime version of the workflow engine, outside
of the editor. I suppose I could overload each of the steps to accept
an EditingDomain and create and execute a command there but, if
possible, I'd like to keep that portion of the application as decoupled
from the design-time code as possible.
Jan Herriger wrote:
> Hi Zac,
> elaborated well ;-)
>> a transaction?
>> trigger the workflow (from some external event on a separate thread)
>> and step through the workflow with some visual cue indicating the
>> active workflow step.
>> (so they all happen at once).
>> runtime is allowed to modify the EObjects without a transaction and
>> still have the notification events sent to my edit parts so they get
>> updated in real time.
>> transaction that auto-commits after each change or something but I'm
>> not sure where to begin or if what I'm trying to do is within the
>> realm of reasonable possibility.
>> Thanks,
>> Zac
Re: Modifying EObjects without transactions? SOLVED! [message #172986 is a reply to message #172972] Tue, 19 February 2008 12:41 Go to previous messageGo to next message
I've got it working now simply by making my own
TransactionalEditingDomain which is just a cut-and-paste from
org.eclipse.gmf.runtime.diagram.core.DiagramEditingDomainFac tory$DiagramEditingDomain
except that the ChangeRecorder I return doesn't check for read/write
transactions when in debug mode:
protected TransactionChangeRecorder
createChangeRecorder(ResourceSet rset) {
return new TransactionChangeRecorder(this, rset) {
protected void assertWriting() {
if (!debugFile) super.assertWriting();
Everything seems to be working now and I get real-time updates in the
designer as the workflow is executing.
Zac Woof wrote:
> Thanks Jan,
> Jan Herriger wrote:
>> Hi Zac,
>> single command and execute them one after another? But this thought
>> may not be elaborated well ;-)
>>> without a transaction?
>>> is triggered by an outside event (not via a command) of course I get
>>> the "cannot modify xxx without write transaction..." exception. If I
>>> wrap the trigger in a command the workflow executes fine but I don't
>>> get notified of any of the changes until the current transaction
>>> commits (so they all happen at once).
>>> Thanks,
>>> Zac
Re: Modifying EObjects without transactions? SOLVED! [message #173001 is a reply to message #172986] Tue, 19 February 2008 13:24 Go to previous messageGo to next message
Originally posted by: trommas.yahoo.com
How did you make your code use this new TransactionalEditingDomain ?
I'd also like to modify my EObjects without a transaction :)
Tomas
> protected TransactionChangeRecorder createChangeRecorder(ResourceSet
> rset) {
> @Override
> Zac Woof wrote:
>> Thanks Jan,
>> decoupled from the design-time code as possible.
>> Jan Herriger wrote:
>>> Hi Zac,
>>>> a workflow. I'd like to build in a visual debugger where you can
>>>> I wrap the trigger in a command the workflow executes fine but I
>>>> don't get notified of any of the changes until the current
>>>> transaction commits (so they all happen at once).
>>>> Thanks,
>>>> Zac
Re: Modifying EObjects without transactions? SOLVED! [message #173027 is a reply to message #173001] Tue, 19 February 2008 16:05 Go to previous messageGo to next message
In my diagram project I have an auto-generated class called
XXXDocumentProvider and I modified the createEditingDomain() to use my
own TransactionEditingDomain:
* @generated NOT
private TransactionalEditingDomain createEditingDomain() {
TransactionalEditingDomain editingDomain =
MyNewDiagramEditingDomainFactory.getInstance()
.createEditingDomain();
That was the only meaningful change I had to make. What I don't know
is, what kind of things are going to get out of sync now that I've
disabled the assertWrite() check in ChangeRecorder. So far so good but,
since I don't completely understand EMF transactions yet, I can't vouch
for this as a good solution.
Hope that helps!
> Tomas
>> @Override
>> Zac Woof wrote:
>>> Thanks Jan,
>>> outside of the editor. I suppose I could overload each of the steps
>>> to accept an EditingDomain and create and execute a command there
>>> but, if possible, I'd like to keep that portion of the application as
>>> Jan Herriger wrote:
>>>> Hi Zac,
>>>>> thread) and step through the workflow with some visual cue
>>>>> indicating the active workflow step.
>>>>> get the "cannot modify xxx without write transaction..."
>>>>> exception. If I wrap the trigger in a command the workflow
>>>>> executes fine but I don't get notified of any of the changes until
>>>>> the current transaction commits (so they all happen at once).
>>>>> get updated in real time.
>>>>> I'm not sure where to begin or if what I'm trying to do is within
>>>>> the realm of reasonable possibility.
>>>>> Thanks,
>>>>> Zac
Re: Modifying EObjects without transactions? SOLVED! [message #173042 is a reply to message #173001] Tue, 19 February 2008 17:29 Go to previous message
* @generated NOT
Hope that helps!
> Tomas
>> @Override
>> Zac Woof wrote:
>>> Thanks Jan,
>>> Jan Herriger wrote:
>>>> Hi Zac,
>>>>> Thanks,
>>>>> Zac
Previous Topic:Save Location of gmf diagram
Next Topic:Automatic Save of Top Level Node - Digram Partitoning
Current Time: Thu Nov 06 22:37:13 EST 2025
Powered by FUDForum. Page generated in 0.25080 seconds
