Home » Eclipse Projects » GEF » Javadoc failure when Running a headless build locally(setup environment for GEF contribution but failing when generating Xtext sources by performing headless build)
Javadoc failure when Running a headless build locally [message #1725094] Mon, 29 February 2016 12:15 Go to next message
I've spent the better part of a week trying to setup eclipse so I can execute the GEF4 examples and learn the platform. I setup my environment several times now based on the contributors guide but have continually got stuck at the point where I need to generate Xtext sources by performing a headless build.
I see I can also download the xtext sdk and built that, but didn't want to giveup on the headless build without at least asking the community.
I'm confused where to go from here as the error is ambiguous (Caused by: C:\dev\git\org.eclipse.gef4\org.eclipse.gef4.releng\scripts\generateJavadoc.xml:49: exec returned: 1). Any suggestions? I've been through the setup a few times and verified each of the steps. I'm using the current mars release, fresh gef4 clone, jdk 1.8.0_73, running on windows 7 64bit
      [ant] Exiting C:\dev\git\org.eclipse.gef4\org.eclipse.gef4.releng\scripts\generateJavadoc.xml.
[INFO] ------------------------------------------------------------------------
[INFO] Reactor Summary:
[INFO]
[INFO] org.eclipse.gef4.releng ............................ SUCCESS [  0.977 s]
[INFO] org.eclipse.gef4.target ............................ SUCCESS [  0.649 s]
[INFO] org.eclipse.gef4.common ............................ SUCCESS [ 10.483 s]
[INFO] org.eclipse.gef4.common ............................ SUCCESS [  0.751 s]
[INFO] org.eclipse.gef4.common.tests ...................... SUCCESS [ 10.609 s]
[INFO] org.eclipse.gef4.common.doc ........................ FAILURE [ 26.754 s]
[INFO] org.eclipse.gef4.common.doc ........................ SKIPPED
[INFO] org.eclipse.gef4.common.sdk ........................ SKIPPED
[INFO] org.eclipse.gef4.geometry .......................... SKIPPED
[INFO] org.eclipse.gef4.geometry.convert.swt .............. SKIPPED
[INFO] org.eclipse.gef4.geometry.convert.fx ............... SKIPPED
[INFO] org.eclipse.gef4.geometry.tests .................... SKIPPED
[INFO] org.eclipse.gef4.geometry.tests.convert.swt ........ SKIPPED
[INFO] org.eclipse.gef4.geometry.tests.convert.fx ......... SKIPPED
[INFO] org.eclipse.gef4.geometry.doc ...................... SKIPPED
[INFO] org.eclipse.gef4.geometry.sdk ...................... SKIPPED
[INFO] org.eclipse.gef4.fx ................................ SKIPPED
[INFO] org.eclipse.gef4.fx.swt ............................ SKIPPED
[INFO] org.eclipse.gef4.fx.jface .......................... SKIPPED
[INFO] org.eclipse.gef4.fx.tests .......................... SKIPPED
[INFO] org.eclipse.gef4.fx.doc ............................ SKIPPED
[INFO] org.eclipse.gef4.fx.sdk ............................ SKIPPED
[INFO] org.eclipse.gef4.fx.compatibility.equinox .......... SKIPPED
[INFO] org.eclipse.gef4.mvc ............................... SKIPPED
[INFO] org.eclipse.gef4.mvc.ui ............................ SKIPPED
[INFO] org.eclipse.gef4.mvc.fx ............................ SKIPPED
[INFO] org.eclipse.gef4.mvc.fx.ui ......................... SKIPPED
[INFO] org.eclipse.gef4.mvc.tests ......................... SKIPPED
[INFO] org.eclipse.gef4.mvc.tests.fx ...................... SKIPPED
[INFO] org.eclipse.gef4.mvc.doc ........................... SKIPPED
[INFO] org.eclipse.gef4.mvc.sdk ........................... SKIPPED
[INFO] org.eclipse.gef4.mvc.examples ...................... SKIPPED
[INFO] org.eclipse.gef4.mvc.examples.logo ................. SKIPPED
[INFO] org.eclipse.gef4.mvc.examples.logo.ui .............. SKIPPED
[INFO] org.eclipse.gef4.mvc.examples.logo.web ............. SKIPPED
[INFO] org.eclipse.gef4.mvc.examples.logo.web.repository .. SKIPPED
[INFO] org.eclipse.gef4.mvc.compatibility.equinox ......... SKIPPED
[INFO] org.eclipse.gef4.mvc.fx.compatibility.equinox ...... SKIPPED
[INFO] org.eclipse.gef4.cloudio.ui ........................ SKIPPED
[INFO] org.eclipse.gef4.cloudio.tests.ui .................. SKIPPED
[INFO] org.eclipse.gef4.cloudio.doc ....................... SKIPPED
[INFO] org.eclipse.gef4.cloudio.doc.user .................. SKIPPED
[INFO] org.eclipse.gef4.cloudio.sdk ....................... SKIPPED
[INFO] org.eclipse.gef4.graph ............................. SKIPPED
[INFO] org.eclipse.gef4.graph.tests ....................... SKIPPED
[INFO] org.eclipse.gef4.graph.doc ......................... SKIPPED
[INFO] org.eclipse.gef4.graph.sdk ......................... SKIPPED
[INFO] org.eclipse.gef4.dot ............................... SKIPPED
[INFO] org.eclipse.gef4.layout ............................ SKIPPED
[INFO] org.eclipse.gef4.zest.fx ........................... SKIPPED
[INFO] org.eclipse.gef4.zest.fx.ui ........................ SKIPPED
[INFO] org.eclipse.gef4.dot.ui ............................ SKIPPED
[INFO] org.eclipse.gef4.dot.tests ......................... SKIPPED
[INFO] org.eclipse.gef4.layout.doc ........................ SKIPPED
[INFO] org.eclipse.gef4.zest.doc .......................... SKIPPED
[INFO] org.eclipse.gef4.dot.doc ........................... SKIPPED
[INFO] org.eclipse.gef4.dot.doc.user ...................... SKIPPED
[INFO] org.eclipse.gef4.layout.sdk ........................ SKIPPED
[INFO] org.eclipse.gef4.zest.fx.jface ..................... SKIPPED
[INFO] org.eclipse.gef4.zest.sdk .......................... SKIPPED
[INFO] org.eclipse.gef4.dot.sdk ........................... SKIPPED
[INFO] org.eclipse.gef4.layout.tests ...................... SKIPPED
[INFO] org.eclipse.gef4.zest.tests.fx ..................... SKIPPED
[INFO] org.eclipse.gef4.zest.tests.fx.jface ............... SKIPPED
[INFO] org.eclipse.gef4.zest.examples ..................... SKIPPED
[INFO] org.eclipse.gef4.zest.examples.graph ............... SKIPPED
[INFO] org.eclipse.gef4.zest.examples.graph.ui ............ SKIPPED
[INFO] org.eclipse.gef4.zest.fx.compatibility.equinox ..... SKIPPED
[INFO] org.eclipse.gef4.repository ........................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 04:56 min
[INFO] Finished at: 2016-02-29T11:16:41-05:00
[INFO] Final Memory: 185M/776M
[WARNING] The requested profile "Mars.target" could not be activated because it does not exist.
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-antrun-plugin:1.7:run (generate-doc) on project org.eclipse.gef4.common.doc: An Ant BuildException has occured: The following error occurred while executing this line:
[ERROR] C:\dev\git\org.eclipse.gef4\org.eclipse.gef4.releng\scripts\generateJavadoc.xml:49: exec returned: 1
[ERROR] around Ant part ...<ant antfile="C:\dev\git\org.eclipse.gef4\org.eclipse.gef4.common.doc/../org.eclipse.gef4.releng/scripts/generateJavadoc.xml" inheritRefs="true"/>... @ 14:153 in C:\dev\git\org.eclipse.gef4\org.eclipse.gef4.common.doc\target\antrun\build-main.xml
[ERROR] -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-antrun-plugin:1.7:run (generate-doc) on project org.eclipse.gef4.common.doc: An Ant BuildException has occured: The following error occurred while executing this line:
	at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:216)
	at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
	at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
	at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
	at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
	at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
	at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
	at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
	at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
	at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
	at org.apache.maven.cli.MavenCli.execute(MavenCli.java:862)
	at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:286)
	at org.apache.maven.cli.MavenCli.main(MavenCli.java:197)
	at java.lang.reflect.Method.invoke(Method.java:497)
	at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
	at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
	at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
	at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
Caused by: org.apache.maven.plugin.MojoExecutionException: An Ant BuildException has occured: The following error occurred while executing this line:
	at org.apache.maven.plugin.antrun.AntRunMojo.execute(AntRunMojo.java:355)
	at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134)
	at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:208)
	... 20 more
Caused by: C:\dev\git\org.eclipse.gef4\org.eclipse.gef4.common.doc\target\antrun\build-main.xml:14: The following error occurred while executing this line:
	at org.apache.tools.ant.ProjectHelper.addLocationToBuildException(ProjectHelper.java:551)
	at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:444)
	at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:291)
	at sun.reflect.GeneratedMethodAccessor15.invoke(Unknown Source)
	at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106)
	at org.apache.tools.ant.Task.perform(Task.java:348)
	at org.apache.tools.ant.taskdefs.Sequential.execute(Sequential.java:68)
	at net.sf.antcontrib.logic.IfTask.execute(Unknown Source)
	at sun.reflect.GeneratedMethodAccessor22.invoke(Unknown Source)
	at org.apache.tools.ant.TaskAdapter.execute(TaskAdapter.java:154)
	at org.apache.tools.ant.Target.execute(Target.java:390)
	at org.apache.tools.ant.Target.performTasks(Target.java:411)
	at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1399)
	at org.apache.tools.ant.Project.executeTarget(Project.java:1368)
	at org.apache.maven.plugin.antrun.AntRunMojo.execute(AntRunMojo.java:327)
	... 22 more
	at org.apache.tools.ant.taskdefs.ExecTask.runExecute(ExecTask.java:646)
	at org.apache.tools.ant.taskdefs.ExecTask.runExec(ExecTask.java:672)
	at org.apache.tools.ant.taskdefs.ExecTask.execute(ExecTask.java:498)
	at org.apache.tools.ant.helper.SingleCheckExecutor.executeTargets(SingleCheckExecutor.java:38)
	at org.apache.tools.ant.Project.executeTargets(Project.java:1251)
	at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:442)
	... 52 more
[ERROR]
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] ht://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] After correcting the problems, you can resume the build with the command
[ERROR]   mvn <goals> -rf :org.eclipse.gef4.common.doc
Re: Javadoc failure when Running a headless build locally [message #1725211 is a reply to message #1725094] Tue, 01 March 2016 12:45 Go to previous messageGo to next message
A doc.bin.log file should be located in the root folder of the common.doc bundle after the build has run. Can you please take a look inside and check whether there are any errors?
Re: Javadoc failure when Running a headless build locally [message #1725465 is a reply to message #1725211] Thu, 03 March 2016 11:35 Go to previous messageGo to next message
Yeah, I'm seeing lots errors about missing google packages. The full file is attached, but below are the first errors to occur in the log.
Constructing Javadoc information...
javadoc: warning - No source files for package org.eclipse.gef4.common.notify
..\org.eclipse.gef4.common\src\org\eclipse\gef4\common\adapt\AdaptableSupport.java:28: error: package com.google.common.reflect does not exist
import com.google.common.reflect.TypeToken;
..\org.eclipse.gef4.common\src\org\eclipse\gef4\common\adapt\IAdaptable.java:17: error: package com.google.common.reflect does not exist
..\org.eclipse.gef4.common\src\org\eclipse\gef4\common\adapt\AdapterKey.java:16: error: package com.google.common.reflect does not exist
..\org.eclipse.gef4.common\src\org\eclipse\gef4\common\adapt\AdaptableSupport.java:169: error: cannot find symbol
	public <T> T getAdapter(TypeToken<T> key) {
  symbol:   class TypeToken
  where A is a type-variable:
    A extends IAdaptable declared in class AdaptableSupport
..\org.eclipse.gef4.common\src\org\eclipse\gef4\common\adapt\AdaptableSupport.java:246: error: cannot find symbol
			TypeToken<? super T> key) {
..\org.eclipse.gef4.common\src\org\eclipse\gef4\common\adapt\AdaptableSupport.java:263: error: cannot find symbol
			TypeToken<? super T> typeKey, String role) {
..\org.eclipse.gef4.common\src\org\eclipse\gef4\common\adapt\AdaptableSupport.java:286: error: cannot find symbol
	private <T> boolean isRawType(TypeToken<? super T> typeKey) {
..\org.eclipse.gef4.common\src\org\eclipse\gef4\common\adapt\AdaptableSupport.java:355: error: cannot find symbol
	public <T> void setAdapter(TypeToken<T> adapterType, T adapter) {
..\org.eclipse.gef4.common\src\org\eclipse\gef4\common\adapt\AdaptableSupport.java:376: error: cannot find symbol
	public <T> void setAdapter(TypeToken<T> adapterType, T adapter,
  • Attachment: doc.bin.log
    (Size: 96.31KB, Downloaded 234 times)
Re: Javadoc failure when Running a headless build locally [message #1725471 is a reply to message #1725465] Thu, 03 March 2016 11:56 Go to previous messageGo to next message
That looks like downloading the context library libs has failed. Can you please check the contents of the api-context-libs folder that should have been created inside the common.doc folder? It should contain: com.google.guava.jar, com.google.inject.jar, com.google.inject.multibindings.jar, and javax.inject.jar.
Re: Javadoc failure when Running a headless build locally [message #1725574 is a reply to message #1725471] Fri, 04 March 2016 09:07 Go to previous messageGo to next message
Yes I do see those jars.
Directory of C:\dev\git\org.eclipse.gef4\org.eclipse.gef4.common.doc\api-context-libs
02/29/2016 10:08 AM <DIR> .
02/29/2016 10:08 AM <DIR> ..
02/29/2016 10:08 AM 2,263,565 com.google.guava.jar
02/29/2016 10:08 AM 520,001 com.google.inject.jar
02/29/2016 10:08 AM 41,887 com.google.inject.multibindings.jar
02/29/2016 10:08 AM 17,604 javax.inject.jar
4 File(s) 2,843,057 bytes
2 Dir(s) 61,457,960,960 bytes free
I noticed I did not see the folder in eclipse, so refreshed incase that had anything to do with it but the build still failed. I've attached the output log with debug enabled incase that gives any hints.
Also thank you for taking your time to help me, I really want to be able to use this framework
[Updated on: Fri, 04 March 2016 09:22] by Moderator
Re: Javadoc failure when Running a headless build locally [message #1725577 is a reply to message #1725574] Fri, 04 March 2016 09:35 Go to previous messageGo to next message
The context-libs look good. Could you please attach the javadocOptions.txt file as well?
[Updated on: Fri, 04 March 2016 09:37] by Moderator
Re: Javadoc failure when Running a headless build locally [message #1725588 is a reply to message #1725577] Fri, 04 March 2016 10:05 Go to previous messageGo to next message
And please try to remove the ${bootclasspath} entry from org.eclipse.gef4.releng/scripts/generateJavadoc.xml, so that the respective line looks as follows:
<replace file="${basedir}/javadocOptions.txt" token="@rt@" value="${java.home}/lib/jfxrt.jar${args.list.delimiter}${java.home}/lib/jfxswt.jar" />
Re: Javadoc failure when Running a headless build locally [message #1725604 is a reply to message #1725588] Fri, 04 March 2016 14:21 Go to previous messageGo to next message
The javadocOptions.txt file is the one that came with the project, but I've attached it after making the alterations you suggested. Building resulting in errors again. Diffed the doc.bin.log and basically looked the same.
Re: Javadoc failure when Running a headless build locally [message #1725607 is a reply to message #1725604] Fri, 04 March 2016 15:21 Go to previous messageGo to next message
The bootclasspath entry is still reflected in the javadocOptions.txt file. Please replace it with the original template file before executing the build (with the altered generateJavadoc.xml.
Re: Javadoc failure when Running a headless build locally [message #1725631 is a reply to message #1725607] Sat, 05 March 2016 06:21 Go to previous messageGo to next message
I can reproduce this problem on Windows 7 with JDK 8 (while with JDK 7 everything seems to work fine), and have opened https://bugs.eclipse.org/bugs/show_bug.cgi?id=489072 to keep track of it.
Re: Javadoc failure when Running a headless build locally [message #1725648 is a reply to message #1725631] Sat, 05 March 2016 14:05 Go to previous messageGo to next message
I resolved the issue, it should work now. Please update your sources to the current HEAD state and give it another try.
Re: Javadoc failure when Running a headless build locally [message #1725798 is a reply to message #1725648] Mon, 07 March 2016 12:27 Go to previous message
Awesome! Was able to build successfully. Thanks for all your support!
Previous Topic:Problems saving Figure to PNG
Next Topic:[Zest] How to add an DoubleClickListener to the ZestContentViewer?
Current Time: Sun Jul 27 11:36:08 EDT 2025
Powered by FUDForum. Page generated in 0.30663 seconds
