Javadoc failure when Running a headless build locally [message #1725094] |
Mon, 29 February 2016 12:15  |
I've spent the better part of a week trying to setup eclipse so I can execute the GEF4 examples and learn the platform. I setup my environment several times now based on the contributors guide but have continually got stuck at the point where I need to generate Xtext sources by performing a headless build.
I see I can also download the xtext sdk and built that, but didn't want to giveup on the headless build without at least asking the community.
I'm confused where to go from here as the error is ambiguous (Caused by: C:\dev\git\org.eclipse.gef4\org.eclipse.gef4.releng\scripts\generateJavadoc.xml:49: exec returned: 1). Any suggestions? I've been through the setup a few times and verified each of the steps. I'm using the current mars release, fresh gef4 clone, jdk 1.8.0_73, running on windows 7 64bit
[ant] Exiting C:\dev\git\org.eclipse.gef4\org.eclipse.gef4.releng\scripts\generateJavadoc.xml.
[INFO] ------------------------------------------------------------------------
[INFO] Reactor Summary:
[INFO]
[INFO] org.eclipse.gef4.releng ............................ SUCCESS [ 0.977 s]
[INFO] org.eclipse.gef4.target ............................ SUCCESS [ 0.649 s]
[INFO] org.eclipse.gef4.common ............................ SUCCESS [ 10.483 s]
[INFO] org.eclipse.gef4.common ............................ SUCCESS [ 0.751 s]
[INFO] org.eclipse.gef4.common.tests ...................... SUCCESS [ 10.609 s]
[INFO] org.eclipse.gef4.common.doc ........................ FAILURE [ 26.754 s]
[INFO] org.eclipse.gef4.common.doc ........................ SKIPPED
[INFO] org.eclipse.gef4.common.sdk ........................ SKIPPED
[INFO] org.eclipse.gef4.geometry .......................... SKIPPED
[INFO] org.eclipse.gef4.geometry.convert.swt .............. SKIPPED
[INFO] org.eclipse.gef4.geometry.convert.fx ............... SKIPPED
[INFO] org.eclipse.gef4.geometry.tests .................... SKIPPED
[INFO] org.eclipse.gef4.geometry.tests.convert.swt ........ SKIPPED
[INFO] org.eclipse.gef4.geometry.tests.convert.fx ......... SKIPPED
[INFO] org.eclipse.gef4.geometry.doc ...................... SKIPPED
[INFO] org.eclipse.gef4.geometry.sdk ...................... SKIPPED
[INFO] org.eclipse.gef4.fx ................................ SKIPPED
[INFO] org.eclipse.gef4.fx.swt ............................ SKIPPED
[INFO] org.eclipse.gef4.fx.jface .......................... SKIPPED
[INFO] org.eclipse.gef4.fx.tests .......................... SKIPPED
[INFO] org.eclipse.gef4.fx.doc ............................ SKIPPED
[INFO] org.eclipse.gef4.fx.sdk ............................ SKIPPED
[INFO] org.eclipse.gef4.fx.compatibility.equinox .......... SKIPPED
[INFO] org.eclipse.gef4.mvc ............................... SKIPPED
[INFO] org.eclipse.gef4.mvc.ui ............................ SKIPPED
[INFO] org.eclipse.gef4.mvc.fx ............................ SKIPPED
[INFO] org.eclipse.gef4.mvc.fx.ui ......................... SKIPPED
[INFO] org.eclipse.gef4.mvc.tests ......................... SKIPPED
[INFO] org.eclipse.gef4.mvc.tests.fx ...................... SKIPPED
[INFO] org.eclipse.gef4.mvc.doc ........................... SKIPPED
[INFO] org.eclipse.gef4.mvc.sdk ........................... SKIPPED
[INFO] org.eclipse.gef4.mvc.examples ...................... SKIPPED
[INFO] org.eclipse.gef4.mvc.examples.logo ................. SKIPPED
[INFO] org.eclipse.gef4.mvc.examples.logo.ui .............. SKIPPED
[INFO] org.eclipse.gef4.mvc.examples.logo.web ............. SKIPPED
[INFO] org.eclipse.gef4.mvc.examples.logo.web.repository .. SKIPPED
[INFO] org.eclipse.gef4.mvc.compatibility.equinox ......... SKIPPED
[INFO] org.eclipse.gef4.mvc.fx.compatibility.equinox ...... SKIPPED
[INFO] org.eclipse.gef4.cloudio.ui ........................ SKIPPED
[INFO] org.eclipse.gef4.cloudio.tests.ui .................. SKIPPED
[INFO] org.eclipse.gef4.cloudio.doc ....................... SKIPPED
[INFO] org.eclipse.gef4.cloudio.doc.user .................. SKIPPED
[INFO] org.eclipse.gef4.cloudio.sdk ....................... SKIPPED
[INFO] org.eclipse.gef4.graph ............................. SKIPPED
[INFO] org.eclipse.gef4.graph.tests ....................... SKIPPED
[INFO] org.eclipse.gef4.graph.doc ......................... SKIPPED
[INFO] org.eclipse.gef4.graph.sdk ......................... SKIPPED
[INFO] org.eclipse.gef4.dot ............................... SKIPPED
[INFO] org.eclipse.gef4.layout ............................ SKIPPED
[INFO] org.eclipse.gef4.zest.fx ........................... SKIPPED
[INFO] org.eclipse.gef4.zest.fx.ui ........................ SKIPPED
[INFO] org.eclipse.gef4.dot.ui ............................ SKIPPED
[INFO] org.eclipse.gef4.dot.tests ......................... SKIPPED
[INFO] org.eclipse.gef4.layout.doc ........................ SKIPPED
[INFO] org.eclipse.gef4.zest.doc .......................... SKIPPED
[INFO] org.eclipse.gef4.dot.doc ........................... SKIPPED
[INFO] org.eclipse.gef4.dot.doc.user ...................... SKIPPED
[INFO] org.eclipse.gef4.layout.sdk ........................ SKIPPED
[INFO] org.eclipse.gef4.zest.fx.jface ..................... SKIPPED
[INFO] org.eclipse.gef4.zest.sdk .......................... SKIPPED
[INFO] org.eclipse.gef4.dot.sdk ........................... SKIPPED
[INFO] org.eclipse.gef4.layout.tests ...................... SKIPPED
[INFO] org.eclipse.gef4.zest.tests.fx ..................... SKIPPED
[INFO] org.eclipse.gef4.zest.tests.fx.jface ............... SKIPPED
[INFO] org.eclipse.gef4.zest.examples ..................... SKIPPED
[INFO] org.eclipse.gef4.zest.examples.graph ............... SKIPPED
[INFO] org.eclipse.gef4.zest.examples.graph.ui ............ SKIPPED
[INFO] org.eclipse.gef4.zest.fx.compatibility.equinox ..... SKIPPED
[INFO] org.eclipse.gef4.repository ........................ SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 04:56 min
[INFO] Finished at: 2016-02-29T11:16:41-05:00
[INFO] Final Memory: 185M/776M
[WARNING] The requested profile "Mars.target" could not be activated because it does not exist.
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-antrun-plugin:1.7:run (generate-doc) on project org.eclipse.gef4.common.doc: An Ant BuildException has occured: The following error occurred while executing this line:
[ERROR] C:\dev\git\org.eclipse.gef4\org.eclipse.gef4.releng\scripts\generateJavadoc.xml:49: exec returned: 1
[ERROR] around Ant part ...<ant antfile="C:\dev\git\org.eclipse.gef4\org.eclipse.gef4.common.doc/../org.eclipse.gef4.releng/scripts/generateJavadoc.xml" inheritRefs="true"/>... @ 14:153 in C:\dev\git\org.eclipse.gef4\org.eclipse.gef4.common.doc\target\antrun\build-main.xml
[ERROR] -> [Help 1]
org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-antrun-plugin:1.7:run (generate-doc) on project org.eclipse.gef4.common.doc: An Ant BuildException has occured: The following error occurred while executing this line:
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:216)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:153)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:145)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:116)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProject(LifecycleModuleBuilder.java:80)
at org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder.build(SingleThreadedBuilder.java:51)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(LifecycleStarter.java:128)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:307)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:193)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:106)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:862)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:286)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:197)
at java.lang.reflect.Method.invoke(Method.java:497)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
Caused by: org.apache.maven.plugin.MojoExecutionException: An Ant BuildException has occured: The following error occurred while executing this line:
at org.apache.maven.plugin.antrun.AntRunMojo.execute(AntRunMojo.java:355)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(DefaultBuildPluginManager.java:134)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor.java:208)
... 20 more
Caused by: C:\dev\git\org.eclipse.gef4\org.eclipse.gef4.common.doc\target\antrun\build-main.xml:14: The following error occurred while executing this line:
at org.apache.tools.ant.ProjectHelper.addLocationToBuildException(ProjectHelper.java:551)
at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:444)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:291)
at sun.reflect.GeneratedMethodAccessor15.invoke(Unknown Source)
at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:106)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.taskdefs.Sequential.execute(Sequential.java:68)
at net.sf.antcontrib.logic.IfTask.execute(Unknown Source)
at sun.reflect.GeneratedMethodAccessor22.invoke(Unknown Source)
at org.apache.tools.ant.TaskAdapter.execute(TaskAdapter.java:154)
at org.apache.tools.ant.Target.execute(Target.java:390)
at org.apache.tools.ant.Target.performTasks(Target.java:411)
at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1399)
at org.apache.tools.ant.Project.executeTarget(Project.java:1368)
at org.apache.maven.plugin.antrun.AntRunMojo.execute(AntRunMojo.java:327)
... 22 more
at org.apache.tools.ant.taskdefs.ExecTask.runExecute(ExecTask.java:646)
at org.apache.tools.ant.taskdefs.ExecTask.runExec(ExecTask.java:672)
at org.apache.tools.ant.taskdefs.ExecTask.execute(ExecTask.java:498)
at org.apache.tools.ant.helper.SingleCheckExecutor.executeTargets(SingleCheckExecutor.java:38)
at org.apache.tools.ant.Project.executeTargets(Project.java:1251)
at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:442)
... 52 more
[ERROR]
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] ht://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] After correcting the problems, you can resume the build with the command
[ERROR] mvn <goals> -rf :org.eclipse.gef4.common.doc
Re: Javadoc failure when Running a headless build locally [message #1725574 is a reply to message #1725471] |
Fri, 04 March 2016 09:07   |
Yes I do see those jars.
Directory of C:\dev\git\org.eclipse.gef4\org.eclipse.gef4.common.doc\api-context-libs
02/29/2016 10:08 AM <DIR> .
02/29/2016 10:08 AM <DIR> ..
02/29/2016 10:08 AM 2,263,565 com.google.guava.jar
02/29/2016 10:08 AM 520,001 com.google.inject.jar
02/29/2016 10:08 AM 41,887 com.google.inject.multibindings.jar
02/29/2016 10:08 AM 17,604 javax.inject.jar
4 File(s) 2,843,057 bytes
2 Dir(s) 61,457,960,960 bytes free
I noticed I did not see the folder in eclipse, so refreshed incase that had anything to do with it but the build still failed. I've attached the output log with debug enabled incase that gives any hints.
Also thank you for taking your time to help me, I really want to be able to use this framework
[Updated on: Fri, 04 March 2016 09:22] by Moderator
FUDForum. Page generated in 0.11879 seconds
