Target platform not materializing [message #1725152] |
Tue, 01 March 2016 04:45  |
I am creating a simple Xtext project with the wizard and add the Buckminster build support, also from the wizard, as outlined in http://www.lorenzobettini.it/2012/11/building-xtext-projects-with-buckminster/ and as I did many times before.
The only local change is that we have a local mirror of the eclipse repositories (and no internet access). The problem in this case is that the target platform remains empty, no matter what I do, both when running headless and from the IDE. The 'resolve' command succeeds (bundles are found in the p2 catalog), but then the build fails because the target is empty.
I tried <cq:advisorNode namePattern=".*" useTargetPlatform="false"/> and most of the other values (just to make sure).
This is with Mars and Bucky 1.7.0.
I think i tried all alternatives, to no avail. Either I am missing a silly obvious detail, or something is wrong somewhere...
best regards,
Vlad
Re: Target platform not materializing [message #1725256 is a reply to message #1725152] |
Wed, 02 March 2016 02:47   |
On 01/03/2016 10:45, Vlad Dumitrescu wrote:
Do you get any specific error/warning during target resolution?
could you please increase the log level just to have an idea of why it
is not resolving anything?
cheers
Lorenzo
Prof. Lorenzo Bettini, Computer Science, DISIA, Univ. Firenze
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: Target platform not materializing [message #1725547 is a reply to message #1725542] |
Fri, 04 March 2016 04:57  |
I have exposed the local eclipse catalog as a web site with a simple web server and the only files requested are contents.jar and artifacts.jar, so it looks like buckminster stops trying early. The feeling I get is that useTargetPlatform="false" is ignored...
[Updated on: Fri, 04 March 2016 05:14] by Moderator
FUDForum. Page generated in 0.05373 seconds
