Home » Eclipse Projects » Remote Application Platform (RAP) » RAP and Nebula: Impressive!
| RAP and Nebula: Impressive! [message #1721558] |
Thu, 28 January 2016 05:09  |
the last days I tried to get several Nebula widgets working in RAP. After importing draw2d from GEF incubation and a wild java error weeding party (20k to 0 ) solving the following main problems:
* The Nebula widget's manifests reference bundles instead of packages, which needed to be changed
* missing constants in the SWT class (most were in draw2d)
* missing RTL constants and functions (but going to be fixed in RAP 3.1 )
* disable functionality which RAP doesn't have
most of the things are working
* FormattedText: no problem
* Oscilloscope: Needs functionality to get a GC from a image instead of a canvas. Should be quite easy for the most usecases, because this can be done on the servers side. But luckily, it is only used for writing upright diagramm labels, so I just disabled it. Works very smooth, even animations.
* Visualisation (I tried xygraph, tank, temperature, speed view etc.): works, but flickers on update. Perhaps this could be optimized using a double buffer strategy on the client side with a default transparent picture. Interactions are working. The flickering could be tolerable for some usecases.
* Gant charts: I needed to disable a redraw() call (else I got a stack overflow). Static view is working, dynamic changes are suffering from missing MouseEvents I think. Perhaps at least sending MousePress(Up/Down) Events would be nice (and don't need so much more bandwith, because MouseClick events are fired anyway and I don't think that a user do so many clicks per second (move is another story). But even the static view is very, very useful!
I was quite impressed how easy it was and how many things are working. As Nebula mentions also compatibility with RAP: Are there any collaborations?
Attachment: BarChart.png
(Size: 58.12KB, Downloaded 1731 times)
Attachment: Gauge.png
(Size: 64.09KB, Downloaded 1628 times)
Attachment: Oscilloscop.png
(Size: 61.14KB, Downloaded 1569 times)
| Re: RAP and Nebula: Impressive! [message #1723180 is a reply to message #1723169] |
Fri, 12 February 2016 06:27   |
Its the (a bit adapted, ie converted to a RCP-View) GantChartScopeView:
public void createPartControl(Composite parent) {
// Create a chart
GanttChart ganttChart = new GanttChart(parent, SWT.NONE);
// Create a scope
GanttEvent scopeEvent = new GanttEvent(ganttChart, "Scope of 3 events");
// Create some calendars
Calendar sdEventOne = Calendar.getInstance();
Calendar edEventOne = Calendar.getInstance();
edEventOne.add(Calendar.DATE, 10);
Calendar sdEventTwo = Calendar.getInstance();
Calendar edEventTwo = Calendar.getInstance();
sdEventTwo.add(Calendar.DATE, 11);
edEventTwo.add(Calendar.DATE, 15);
Calendar cpDate = Calendar.getInstance();
cpDate.add(Calendar.DATE, 16);
// Create events
GanttEvent eventOne = new GanttEvent(ganttChart, "Scope Event 1");
GanttEvent eventTwo = new GanttEvent(ganttChart, "Scope Event 2", sdEventTwo, edEventTwo, 10);
GanttEvent eventThree = new GanttEvent(ganttChart, "Checkpoint", cpDate, cpDate, 75);
eventThree.setCheckpoint(true);
// Add events to scope
scopeEvent.addScopeEvent(eventOne);
scopeEvent.addScopeEvent(eventTwo);
scopeEvent.addScopeEvent(eventThree);
eventOne.addScopeEvent(eventTwo);
eventOne.addScopeEvent(eventThree);
// Show chart
//shell.open();
while (!shell.isDisposed ()) {
if (!display.readAndDispatch ()) display.sleep ();
display.dispose ();
The interesting thing is that if I remove all but
I get the error mentioned in the attachment.
Attachment: log2.txt
(Size: 56.44KB, Downloaded 242 times)
| Repaint issue with xygraph [message #1745397 is a reply to message #1725157] |
Mon, 10 October 2016 06:30   |
After some experiments with the xygraph, it seems to have severe repaint issues.
I'm using current RAP 3.1.1 + draw2d.* from GEF incubator.
If I use the attached code without the block marked with [repaint] the graph disapperas after 1 or 2 clicks on the toolbar. After resizing the browser window it is redrawn again. If I enable the marked code it disappears after a second. It is reddrawn correctly after a resize, but after a second it disapperas again. So there seems to be a severe problem with the repaint functionality on the LightweightSystem component. Perhaps it is coupled with the massive flicker problem when using e.g. the GaugeFigure?
I've bundled all relevant packages and files in the packages.zip.
[code]
package de.zft.kommunikationsframework_gui_nebula_template.views;
import java.util.concurrent.Executors;
import java.util.concurrent.ScheduledExecutorService;
import java.util.concurrent.ScheduledFuture;
import java.util.concurrent.TimeUnit;
import org.eclipse.draw2d.LightweightSystem;
import org.eclipse.nebula.visualization.xygraph.dataprovider.CircularBufferDataProvider;
import org.eclipse.nebula.visualization.xygraph.figures.ToolbarArmedXYGraph;
import org.eclipse.nebula.visualization.xygraph.figures.Trace;
import org.eclipse.nebula.visualization.xygraph.figures.Trace.PointStyle;
import org.eclipse.nebula.visualization.xygraph.figures.XYGraph;
import org.eclipse.swt.SWT;
import org.eclipse.swt.layout.FillLayout;
import org.eclipse.swt.widgets.Canvas;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.ui.part.ViewPart;
public class XYGraphView extends ViewPart {
public static final String ID = XYGraphView.class.getName();
public void createPartControl(final Composite parent) {
//FormattedText tf = new FormattedText(parent, SWT.None);
//tf.setFormatter(new NumberFormatter());
parent.setLayout(new FillLayout());
//final Shell shell = new Shell();
//shell.setSize(800, 600);
//Oscilloscope scope = new Oscilloscope(parent, SWT.NONE);
//scope.getDispatcher(0).dispatch();
//use LightweightSystem to create the bridge between SWT and draw2D
//final LightweightSystem lws = new LightweightSystem(shell);
final LightweightSystem lws = new LightweightSystem(new Canvas(parent, SWT.NONE));
//create a new XY Graph.
XYGraph xyGraph = new XYGraph();
xyGraph.setTitle("Simple Example");
final ToolbarArmedXYGraph toolbarArmedXYGraph = new ToolbarArmedXYGraph(xyGraph);
//set it as the content of LightwightSystem
//lws.setContents(xyGraph);
lws.setContents(toolbarArmedXYGraph);
//create a trace data provider, which will provide the data to the trace.
CircularBufferDataProvider traceDataProvider = new CircularBufferDataProvider(false);
traceDataProvider.setBufferSize(100);
traceDataProvider.setCurrentXDataArray(new double[]{10, 23, 34, 45, 56, 78, 88, 99});
traceDataProvider.setCurrentYDataArray(new double[]{11, 44, 55, 45, 88, 98, 52, 23});
ScheduledExecutorService scheduler = Executors.newScheduledThreadPool(1);
ScheduledFuture<?> future = scheduler.scheduleAtFixedRate(new Runnable() {
public void run() {
parent.getDisplay().asyncExec(new Runnable() {
public void run() {
lws.getUpdateManager().addDirtyRegion(toolbarArmedXYGraph, 0, 0, 1000, 1000);
lws.getUpdateManager().performUpdate();
}, 1000, 1000, TimeUnit.MILLISECONDS);
[/repaint]
//create the trace
Trace trace = new Trace("Trace1-XY Plot",
xyGraph.primaryXAxis, xyGraph.primaryYAxis, traceDataProvider);
//set trace property
trace.setPointStyle(PointStyle.XCROSS);
//add the trace to xyGraph
xyGraph.addTrace(trace);
//shell.open();
//shell.layout();
public void setFocus() {
// TODO Auto-generated method stub
[code]
Attachment: packages.zip
(Size: 2.58MB, Downloaded 205 times)
Current Time: Mon Nov 10 05:47:59 EST 2025
Powered by FUDForum. Page generated in 0.07684 seconds
