Home » Archived » EPF » couldn't find org.eclipse.epf.rcp.beacon(epf run)
couldn't find org.eclipse.epf.rcp.beacon [message #509644] Sat, 23 January 2010 17:56 Go to next message
I am a newcomer and i need assitence about compiling source code of the epf.
i have done everything in the following written in the EPF Composer Development Guide: http://www.eclipse.org/epf/composer_dev_guide/dev_env.php
downloaded and extracted into the eclipse folder and also everything seems ok...
Eclipse SDK 3.3.2
EMF 2.3.2
GEF 3.3.2
GMF 2.0.2
EMFT OCL 1.1.2
EMFT Query 1.1.1
EMFT Transaction 1.1.2
EMFT Validation 1.1.1
UML2 2.1.1
I have checked out code from /cvsroot/technology/org.eclipse.epf/composer/1.5/
I have downloaded and extracted eclipse-RCP-3.3.2-delta-pack
After all this. i started eclipse and make run and debug settings which is written in the Run and debug settings
http://www.eclipse.org/epf/composer_dev_guide/run_debug.php
but in the run configurations dialog i couldnt find org.eclipse.epf.rcp.beacon in the run a product drop down box
Someone could assist me in this issue?
Re: couldn't find org.eclipse.epf.rcp.beacon [message #518121 is a reply to message #509644] Wed, 03 March 2010 02:43 Go to previous messageGo to next message
Well, I'm using the entry org.eclipse.epf.rcp.ui.composer, which is working.
However, I get some errors (please refer to my latest post) - did you get them, too?
Gerhard
Re: couldn't find org.eclipse.epf.rcp.beacon [message #1717895 is a reply to message #509644] Thu, 17 December 2015 09:30 Go to previous message
efe can kalkandelen wrote on Sat, 23 January 2010 22:56
Hi:
I'm having the same problem. Did you fix it?
Previous Topic:Obtain SPEM2 metamodel
Next Topic:Custom Categories Assign not working
Current Time: Fri Jul 25 23:50:43 EDT 2025
Powered by FUDForum. Page generated in 0.03833 seconds
