Home » Eclipse Projects » Oomph » installation error
installation error [message #1716481] |
Fri, 04 December 2015 05:17  |
when installing eclipse with the installer version 1.3.0 Build 1995 i get following error
How do I correct this ?
I attach a screenshot of my P2 Director task , since it fails there.
An error was detected while performing the engine operation and the changes are being rolled back. See the log for details.
ERROR: org.eclipse.equinox.p2.engine code=4 An error occurred while collecting items to be installed
at org.eclipse.oomph.util.OomphPlugin.coreException(OomphPlugin.java:280)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl$3.commit(ProfileTransactionImpl.java:523)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl.commit(ProfileTransactionImpl.java:328)
at org.eclipse.oomph.setup.p2.impl.P2TaskImpl.perform(P2TaskImpl.java:710)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:3025)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:2954)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:2935)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:2829)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$9.run(ProgressPage.java:552)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$11$1.run(ProgressPage.java:671)
ERROR: org.eclipse.equinox.p2.engine code=0 session context was:(profile=C__Users_EMAKMEL_Desktop_Test2Eclipse_lhs-git-main-master2_eclipse, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.egit,4.1.1.201511131810-r
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.egit.core,4.1.1.201511131810-r
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.egit.doc,4.1.1.201511131810-r
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.egit,4.1.1.201511131810-r
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.egit.mylyn,4.1.1.201511131810-r
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.egit.mylyn.ui,4.1.1.201511131810-r
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.egit.ui,4.1.1.201511131810-r
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jgit,4.1.1.201511131810-r
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jgit.archive,4.1.1.201511131810-r
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.jgit,4.1.1.201511131810-r
Took 9 seconds.
There are failed tasks.
Attachment: Captsure.PNG
(Size: 63.33KB, Downloaded 1234 times)
Attachment: Caspture.PNG
(Size: 62.99KB, Downloaded 1043 times)
[Updated on: Fri, 04 December 2015 05:59] by Moderator
Re: installation error [message #1716493 is a reply to message #1716481] |
Fri, 04 December 2015 06:45   |
Hi Maksim,
It's possible that that was a temporary problem with http://download.eclipse.org/egit/updates (most likely non-atomic
repo modifications) . Can you please try it again and tell us if the problem persists?
Cheers
/Eike
http://www.esc-net.de
Am 04.12.2015 um 11:17 schrieb Maksim Melnik:
> Hello,
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> Took 9 seconds.
Re: installation error [message #1764751 is a reply to message #1756316] |
Fri, 02 June 2017 01:50   |
Hi Ed,
I am also facing same issue and also mirrored following sites. if we need to mirror more so please suggest.
1. http://download.eclipse.org/technology/epp/packages/neon
2. http://download.eclipse.org/releases/neon/201705151400.
error logs :-
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl$3.commit(ProfileTransactionImpl.java:547)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl.commit(ProfileTransactionImpl.java:340)
at org.eclipse.oomph.setup.p2.impl.P2TaskImpl.perform(P2TaskImpl.java:729)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.doPerformNeededSetupTasks(SetupTaskPerformer.java:3324)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performNeededSetupTasks(SetupTaskPerformer.java:3252)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.performTriggeredSetupTasks(SetupTaskPerformer.java:3233)
at org.eclipse.oomph.setup.internal.core.SetupTaskPerformer.perform(SetupTaskPerformer.java:3133)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$9.run(ProgressPage.java:567)
at org.eclipse.oomph.setup.ui.wizards.ProgressPage$11$1.run(ProgressPage.java:693)
ERROR: org.eclipse.equinox.p2.engine code=0 session context was:(profile=C__fis_ide_fisgui_v1, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,com.google.gson,2.2.4.v201311231704
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,com.google.guava,15.0.0.v201403281430
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,com.google.inject,3.0.0.v201605172100
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,com.ibm.icu,56.1.0.v201601250100
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,com.ibm.icu.source,56.1.0.v201601250100
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,com.jcraft.jsch,0.1.54.v20170116-1932
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,com.jcraft.jsch.source,0.1.54.v20170116-1932
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,com.sun.el,2.2.0.v201303151357
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,com.sun.el.source,2.2.0.v201303151357
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: binary,epp.package.rcp.executable.win32.win32.x86_64,4.6.3.20170314-1500
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,javax.annotation,1.2.0.v201602091430
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,javax.annotation.source,1.2.0.v201602091430
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,javax.el,2.2.0.v201303151357
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,javax.el.source,2.2.0.v201303151357
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,javax.servlet,3.1.0.v201410161800
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,javax.servlet.jsp,2.2.0.v201112011158
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,javax.servlet.jsp.source,2.2.0.v201112011158
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,javax.servlet.source,3.1.0.v201410161800
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.apache.ant,1.9.6.v201510161327
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.apache.ant.source,1.9.6.v201510161327
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.apache.commons.cli,1.2.0.v201404270220
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.apache.commons.io,2.2.0.v201405211200
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.apache.commons.lang,2.6.0.v201404270220
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.apache.commons.lang3,3.1.0.v201403281430
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.apache.felix.gogo.command,0.10.0.v201209301215
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.apache.felix.gogo.command.source,0.10.0.v201209301215
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.apache.felix.gogo.runtime,0.10.0.v201209301036
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.apache.felix.gogo.runtime.source,0.10.0.v201209301036
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.apache.felix.gogo.shell,0.10.0.v201212101605
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.apache.felix.gogo.shell.source,0.10.0.v201212101605
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.apache.jasper.glassfish,2.2.2.v201501141630
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.apache.jasper.glassfish.source,2.2.2.v201501141630
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.apache.lucene.analysis,3.5.0.v20120725-1805
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.apache.lucene.analysis.source,3.5.0.v20120725-1805
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.apache.lucene.core,3.5.0.v20120725-1805
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.apache.lucene.core.source,3.5.0.v20120725-1805
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.ant.core,3.4.100.v20160505-0642
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.ant.core.source,3.4.100.v20160505-0642
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.ant.launching,1.1.201.v20161115-1135
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.ant.ui,3.6.201.v20161115-1135
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.compare,3.7.1.v20170103-1805
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.compare.core,3.6.0.v20160418-1534
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.compare.core.source,3.6.0.v20160418-1534
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.compare.source,3.7.1.v20170103-1805
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.compare.win32,1.1.0.v20160418-1534
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.compare.win32.source,1.1.0.v20160418-1534
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.commands,3.8.1.v20161221-1651
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.commands.source,3.8.1.v20161221-1651
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.contenttype,3.5.100.v20160418-1621
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.contenttype.source,3.5.100.v20160418-1621
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.databinding,1.6.0.v20160412-0910
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.databinding.beans,1.3.100.v20160509-1025
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.databinding.beans.source,1.3.100.v20160509-1025
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.databinding.observable,1.6.0.v20160511-1747
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.databinding.observable.source,1.6.0.v20160511-1747
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.databinding.property,1.6.0.v20160427-0852
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.databinding.property.source,1.6.0.v20160427-0852
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.databinding.source,1.6.0.v20160412-0910
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.expressions,3.5.100.v20160418-1621
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.expressions.source,3.5.100.v20160418-1621
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.externaltools,1.0.400.v20160509-1057
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.externaltools.source,1.0.400.v20160509-1057
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.filebuffers,3.6.0.v20160503-1849
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.filebuffers.source,3.6.0.v20160503-1849
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.filesystem,1.6.1.v20161113-2349
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.filesystem.source,1.6.1.v20161113-2349
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.filesystem.win32.x86_64,1.4.0.v20140124-1940
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.jobs,3.8.0.v20160509-0411
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.jobs.source,3.8.0.v20160509-0411
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.net,1.3.0.v20160418-1534
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.net.source,1.3.0.v20160418-1534
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.net.win32.x86_64,1.1.0.v20160323-1650
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.resources,3.11.1.v20161107-2032
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.resources.source,3.11.1.v20161107-2032
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.resources.win32.x86_64,3.5.0.v20140124-1940
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.runtime,3.12.0.v20160606-1342
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.runtime.source,3.12.0.v20160606-1342
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.variables,3.3.0.v20160419-1720
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.core.variables.source,3.3.0.v20160419-1720
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.debug.core,3.10.100.v20160419-1720
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.debug.core.source,3.10.100.v20160419-1720
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.debug.ui,3.11.202.v20161114-0338
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.debug.ui.source,3.11.202.v20161114-0338
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.core.commands,0.11.100.v20160506-0804
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.core.commands.source,0.11.100.v20160506-0804
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.core.contexts,1.5.1.v20170203-1100
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.core.contexts.source,1.5.1.v20170203-1100
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.core.di,1.6.1.v20160712-0927
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.core.di.annotations,1.5.0.v20151127-1241
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.core.di.annotations.source,1.5.0.v20151127-1241
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.core.di.extensions,0.14.0.v20160211-1614
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.core.di.extensions.source,0.14.0.v20160211-1614
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.core.di.source,1.6.1.v20160712-0927
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.core.services,2.0.100.v20160509-1032
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.core.services.source,2.0.100.v20160509-1032
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.emf.xpath,0.1.200.v20160506-0804
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.emf.xpath.source,0.1.200.v20160506-0804
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.e4.rcp,1.5.3.v20170228-0512
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.e4.rcp.source,1.5.3.v20170228-0512
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.ui.bindings,0.11.100.v20160509-1025
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.ui.bindings.source,0.11.100.v20160509-1025
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.ui.css.core,0.12.1.v20161114-0210
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.ui.css.core.source,0.12.1.v20161114-0210
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.ui.css.swt,0.12.100.v20160517-1505
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.ui.css.swt.source,0.12.100.v20160517-1505
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.ui.css.swt.theme,0.10.100.v20160523-0836
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.ui.css.swt.theme.source,0.10.100.v20160523-0836
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.ui.di,1.1.100.v20160506-0759
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.ui.di.source,1.1.100.v20160506-0759
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.ui.dialogs,1.1.0.v20151127-1218
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.ui.dialogs.source,1.1.0.v20151127-1218
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.ui.model.workbench,1.2.0.v20160229-1459
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.ui.model.workbench.source,1.2.0.v20160229-1459
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.ui.services,1.2.100.v20160506-0759
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.ui.services.source,1.2.100.v20160506-0759
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.ui.widgets,1.1.100.v20160506-0759
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.ui.widgets.source,1.1.100.v20160506-0759
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.ui.workbench,1.4.0.v20160517-1624
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.ui.workbench.addons.swt,1.2.101.v20170206-1129
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.ui.workbench.addons.swt.source,1.2.101.v20170206-1129
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.ui.workbench.renderers.swt,0.14.1.v20170117-1415
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.ui.workbench.renderers.swt.source,0.14.1.v20170117-1415
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.ui.workbench.source,1.4.0.v20160517-1624
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.ui.workbench.swt,0.14.1.v20160829-0832
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.ui.workbench.swt.source,0.14.1.v20160829-0832
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.ui.workbench3,0.13.100.v20160506-0759
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.e4.ui.workbench3.source,0.13.100.v20160506-0759
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.ecf,3.8.0.v20160823-2221
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.ecf.core.feature,1.3.0.v20160823-2221
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.ecf.core.ssl.feature,1.1.0.v20160823-2221
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.ecf.filetransfer,5.0.0.v20160823-2221
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.ecf.filetransfer.feature,3.13.2.v20160823-2221
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.ecf.filetransfer.httpclient4.feature,3.13.2.v20160823-2221
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.ecf.filetransfer.httpclient4.ssl.feature,1.1.0.v20160823-2221
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.ecf.filetransfer.ssl.feature,1.1.0.v20160823-2221
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.ecf.identity,3.7.0.v20160823-2221
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.ecf.provider.filetransfer,3.2.200.v20160823-2221
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.ecf.provider.filetransfer.httpclient4,1.1.100.v20160823-2221
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.ecf.provider.filetransfer.httpclient4.ssl,1.1.0.v20160823-2221
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.ecf.provider.filetransfer.ssl,1.0.0.v20160823-2221
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.ecf.ssl,1.2.0.v20160823-2221
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.emf.codegen,2.11.0.v20160526-0356
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.emf.codegen.ecore,2.12.0.v20160526-0356
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.emf.common,2.12.0.v20160420-0247
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.emf.common,2.12.0.v20160420-0247
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.emf.common.ui,2.11.0.v20160526-0356
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.emf.databinding,1.3.0.v20160526-0356
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.emf.ecore,2.12.0.v20160420-0247
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.emf.ecore.change,2.11.0.v20160420-0247
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.emf.ecore.edit,2.9.0.v20160526-0356
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.emf.ecore.editor,2.12.0.v20160526-0356
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.emf.ecore,2.12.0.v20160420-0247
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.emf.ecore.xmi,2.12.0.v20160420-0247
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.emf.edit,2.12.0.v20160526-0356
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.emf.edit.ui,2.12.0.v20160526-0356
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.emf.mwe.core,1.3.20.v201605261103
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.emf.mwe.utils,1.3.20.v201605261103
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.emf.mwe2.lib,2.9.0.v201605261103
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.emf.mwe2.runtime,2.9.0.v201605261103
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.epp.logging.aeri.core,2.0.4.v20170307-1435
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.epp.logging.aeri.feature,2.0.4.v20170307-1435
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.epp.logging.aeri.ide,2.0.4.v20170307-1435
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.epp.mpc.core,1.5.4.v20170222-1921
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.epp.mpc,1.5.4.v20170222-1941
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.epp.mpc.help.ui,1.5.4.v20170201-1845
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.epp.mpc.ui,1.5.4.v20170222-1941
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.epp.package.rcp,4.6.3.20170314-1500
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.app,1.3.400.v20150715-1528
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.app.source,1.3.400.v20150715-1528
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.bidi,1.0.0.v20160307-1318
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.bidi.source,1.0.0.v20160307-1318
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.common,3.8.0.v20160509-1230
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.common.source,3.8.0.v20160509-1230
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.concurrent,1.1.0.v20130327-1442
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.console,1.1.200.v20150929-1405
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.console.source,1.1.200.v20150929-1405
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.ds,1.4.400.v20160226-2036
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.ds.source,1.4.400.v20160226-2036
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.event,1.3.200.v20160324-1850
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.event.source,1.3.200.v20160324-1850
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.frameworkadmin,2.0.300.v20160504-1450
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.frameworkadmin.equinox,1.0.700.v20160102-2223
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.frameworkadmin.equinox.source,1.0.700.v20160102-2223
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.frameworkadmin.source,2.0.300.v20160504-1450
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.http.jetty,3.3.0.v20160324-1850
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.http.jetty.source,3.3.0.v20160324-1850
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.http.registry,1.1.400.v20150715-1528
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.http.registry.source,1.1.400.v20150715-1528
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.http.servlet,1.3.1.v20160808-1329
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.http.servlet.source,1.3.1.v20160808-1329
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.jsp.jasper,1.0.500.v20150119-1358
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.jsp.jasper.registry,1.0.300.v20130327-1442
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.jsp.jasper.registry.source,1.0.300.v20130327-1442
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.jsp.jasper.source,1.0.500.v20150119-1358
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.launcher,1.3.201.v20161025-1711
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.launcher.source,1.3.201.v20161025-1711
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.launcher.win32.win32.x86_64,1.1.401.v20161122-1740
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.artifact.repository,1.1.500.v20160419-0834
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.artifact.repository.source,1.1.500.v20160419-0834
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.console,1.0.500.v20160504-1450
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.console.source,1.0.500.v20160504-1450
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.core,2.4.100.v20160419-0834
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.equinox.p2.core.feature,1.3.203.v20170131-1444
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.equinox.p2.core.feature.source,1.3.203.v20170131-1444
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.core.source,2.4.100.v20160419-0834
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.director,2.3.300.v20160504-1450
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.director.app,1.0.500.v20160419-0834
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.director.app.source,1.0.500.v20160419-0834
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.director.source,2.3.300.v20160504-1450
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.directorywatcher,1.1.100.v20150423-1455
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.directorywatcher.source,1.1.100.v20150423-1455
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.discovery,1.0.400.v20160504-1450
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.discovery.compatibility,1.0.200.v20131211-1531
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.equinox.p2.discovery.feature,1.0.401.v20160901-1335
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.engine,2.4.100.v20160419-0834
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.engine.source,2.4.100.v20160419-0834
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.extensionlocation,1.2.300.v20160419-0834
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.extensionlocation.source,1.2.300.v20160419-0834
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.equinox.p2.extras.feature,1.2.203.v20170131-1444
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.equinox.p2.extras.feature.source,1.2.203.v20170131-1444
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.garbagecollector,1.0.300.v20160504-1450
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.garbagecollector.source,1.0.300.v20160504-1450
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.jarprocessor,1.0.500.v20160504-1450
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.jarprocessor.source,1.0.500.v20160504-1450
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.metadata,2.3.100.v20160427-2220
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.metadata.repository,1.2.300.v20160419-0834
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.metadata.repository.source,1.2.300.v20160419-0834
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.metadata.source,2.3.100.v20160427-2220
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.operations,2.4.200.v20160504-1450
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.operations.source,2.4.200.v20160504-1450
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.publisher,1.4.100.v20160504-1450
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.publisher.eclipse,1.2.100.v20160504-1450
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.publisher.eclipse.source,1.2.100.v20160504-1450
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.publisher.source,1.4.100.v20160504-1450
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.equinox.p2.rcp.feature,1.2.203.v20170131-1444
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.equinox.p2.rcp.feature.source,1.2.203.v20170131-1444
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.reconciler.dropins,1.1.400.v20160504-1450
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.reconciler.dropins.source,1.1.400.v20160504-1450
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.repository,2.3.200.v20160421-0324
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.repository.source,2.3.200.v20160421-0324
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.repository.tools,2.1.300.v20160421-0324
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.repository.tools.source,2.1.300.v20160421-0324
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.touchpoint.eclipse,2.1.400.v20160419-0834
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.touchpoint.eclipse.source,2.1.400.v20160419-0834
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.touchpoint.natives,1.2.100.v20160419-0834
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.touchpoint.natives.source,1.2.100.v20160419-0834
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.transport.ecf,1.1.201.v20161115-1927
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.transport.ecf.source,1.1.201.v20161115-1927
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.ui,2.4.100.v20160419-0834
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.ui.discovery,1.0.201.v20160901-1335
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.ui.importexport,1.1.200.v20160521-1138
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.ui.importexport.source,1.1.200.v20160521-1138
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.ui.sdk,1.0.400.v20150423-1455
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.ui.sdk.scheduler,1.3.0.v20161124-1529
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.ui.sdk.scheduler.source,1.3.0.v20161124-1529
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.ui.sdk.source,1.0.400.v20150423-1455
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.ui.source,2.4.100.v20160419-0834
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.updatechecker,1.1.300.v20161124-1529
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.updatechecker.source,1.1.300.v20161124-1529
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.updatesite,1.0.600.v20160504-1450
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.p2.updatesite.source,1.0.600.v20160504-1450
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.equinox.p2.user.ui,2.2.203.v20170131-1444
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.equinox.p2.user.ui.source,2.2.203.v20170131-1444
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.preferences,3.6.1.v20160815-1406
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.preferences.source,3.6.1.v20160815-1406
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.registry,3.6.100.v20160223-2218
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.registry.source,3.6.100.v20160223-2218
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.security,1.2.200.v20150715-1528
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.security.source,1.2.200.v20150715-1528
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.security.ui,1.1.300.v20150803-1225
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.security.ui.source,1.1.300.v20150803-1225
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.security.win32.x86_64,1.0.100.v20130327-1442
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.security.win32.x86_64.source,1.0.100.v20130327-1442
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.simpleconfigurator,1.1.200.v20160504-1450
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.simpleconfigurator.manipulator,2.0.200.v20160504-1450
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.simpleconfigurator.manipulator.source,2.0.200.v20160504-1450
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.simpleconfigurator.source,1.1.200.v20160504-1450
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.util,1.0.500.v20130404-1337
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.equinox.util.source,1.0.500.v20130404-1337
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.help,3.7.0.v20160602-1307
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.help.base,4.1.2.v20170301-0400
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.help.base.source,4.1.2.v20170301-0400
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.help,2.2.2.v20170301-0400
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.help.source,3.7.0.v20160602-1307
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.help.source,2.2.2.v20170301-0400
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.help.ui,4.0.200.v20160510-0758
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.help.ui.source,4.0.200.v20160510-0758
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.help.webapp,3.8.0.v20160504-0839
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.help.webapp.source,3.8.0.v20160504-0839
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jdt,3.12.3.v20170301-0400
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jdt.annotation,1.1.100.v20160418-1457
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jdt.annotation,2.1.0.v20160418-1457
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jdt.apt.core,3.4.100.v20160525-0952
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jdt.apt.pluggable.core,1.1.100.v20160418-1457
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jdt.apt.ui,3.4.100.v20160418-1457
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jdt.compiler.apt,1.2.100.v20160418-1457
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jdt.compiler.tool,1.1.100.v20160418-1457
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jdt.core,3.12.3.v20170228-1205
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jdt.core.manipulation,1.7.0.v20160419-0705
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jdt.debug,3.10.1.v20160811-0441
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jdt.debug.ui,3.7.201.v20160811-0450
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jdt.doc.user,3.12.1.v20160727-2009
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.jdt,3.12.3.v20170301-0400
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jdt.junit,3.9.0.v20160421-1701
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jdt.junit.core,3.8.0.v20160421-1701
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jdt.junit.runtime,3.4.600.v20160505-0715
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jdt.junit4.runtime,1.1.600.v20160505-0715
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jdt.launching,3.8.101.v20161111-2014
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jdt.ui,3.12.2.v20160929-0804
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jetty.continuation,9.3.9.v20160517
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jetty.continuation.source,9.3.9.v20160517
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jetty.http,9.3.9.v20160517
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jetty.http.source,9.3.9.v20160517
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jetty.io,9.3.9.v20160517
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jetty.io.source,9.3.9.v20160517
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jetty.security,9.3.9.v20160517
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jetty.security.source,9.3.9.v20160517
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jetty.server,9.3.9.v20160517
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jetty.server.source,9.3.9.v20160517
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jetty.servlet,9.3.9.v20160517
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jetty.servlet.source,9.3.9.v20160517
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jetty.util,9.3.9.v20160517
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jetty.util.source,9.3.9.v20160517
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jface,3.12.2.v20170113-2113
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jface.databinding,1.8.1.v20161026-1531
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jface.databinding.source,1.8.1.v20161026-1531
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jface.source,3.12.2.v20170113-2113
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jface.text,3.11.2.v20170220-1911
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jface.text.source,3.11.2.v20170220-1911
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jsch.core,1.3.0.v20160422-1917
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jsch.core.source,1.3.0.v20160422-1917
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jsch.ui,1.3.0.v20160323-1650
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.jsch.ui.source,1.3.0.v20160323-1650
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.ltk.core.refactoring,3.7.0.v20160419-0705
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.ltk.core.refactoring.source,3.7.0.v20160419-0705
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.ltk.ui.refactoring,3.8.0.v20160518-1817
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.ltk.ui.refactoring.source,3.8.0.v20160518-1817
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.mylyn.commons.core,3.21.0.v20160707-1856
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.mylyn.commons.notifications.core,1.13.0.v20160630-1702
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.mylyn.commons.notifications.ui,1.13.0.v20160630-1702
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.mylyn.commons.screenshots,3.21.0.v20160630-1702
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.mylyn.commons.ui,3.21.0.v20160630-1702
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.mylyn.commons.workbench,3.21.0.v20160630-1702
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.osgi,3.11.3.v20170209-1843
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.osgi.compatibility.state,1.0.200.v20160504-1419
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.osgi.compatibility.state.source,1.0.200.v20160504-1419
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.osgi.services,3.5.100.v20160504-1419
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.osgi.services.source,3.5.100.v20160504-1419
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.osgi.source,3.11.3.v20170209-1843
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.osgi.util,3.3.100.v20150423-1351
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.osgi.util.source,3.3.100.v20150423-1351
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.pde,3.12.3.v20170301-0400
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.pde.api.tools,1.1.2.v20161115-0549
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.pde.api.tools.annotations,1.0.100.v20160418-1724
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.pde.api.tools.ui,1.1.0.v20160519-0701
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.pde.build,3.9.200.v20160204-0642
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.pde.core,3.11.1.v20161115-1951
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.pde.doc.user,3.12.2.v20170221-1001
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.pde.ds.annotations,1.0.0.v20160525-1437
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.pde.ds.core,1.1.0.v20151201-1325
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.pde.ds.ui,1.1.0.v20160518-1843
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.pde,3.12.3.v20170301-0400
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.pde.junit.runtime,3.5.0.v20151013-0625
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.pde.launching,3.6.401.v20161115-0549
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.pde.runtime,3.5.0.v20160418-1724
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.pde.ua.core,1.0.500.v20160204-0642
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.pde.ua.ui,1.1.0.v20160518-1843
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.pde.ui,3.9.100.v20161102-0517
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.pde.ui.templates,3.6.0.v20160424-1948
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.platform,4.6.3.v20170301-0400
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.platform.doc.isv,4.6.2.v20170221-1001
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.platform.doc.user,4.6.1.v20160727-2009
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.platform,4.6.3.v20170301-0400
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: binary,org.eclipse.platform.ide.executable.win32.win32.x86_64,4.6.3.M20170301-0400
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.platform.source,4.6.3.v20170301-0400
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.platform.source,4.6.3.v20170301-0400
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: binary,org.eclipse.platform_root,4.6.3.v20170301-0400
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.rcp,4.6.3.v20170301-0400
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.rcp,4.6.3.v20170301-0400
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: org.eclipse.update.feature,org.eclipse.rcp.source,4.6.3.v20170301-0400
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: binary,org.eclipse.rcp_root,4.6.3.v20170301-0400
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.search,3.11.1.v20161113-1700
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.search.source,3.11.1.v20161113-1700
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.swt,3.105.3.v20170228-0512
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.swt.win32.win32.x86_64,3.105.3.v20170228-0512
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.swt.win32.win32.x86_64.source,3.105.3.v20170228-0512
ERROR: org.eclipse.equinox.p2.artifact.repository code=0 No repository found containing: osgi.bundle,org.eclipse.team.core,3.8.0.v20160418-1534
Re: Eclipse IDE installation error [message #1861508 is a reply to message #1852739] |
Tue, 17 October 2023 01:12   |
I am also facing the issue which details as below in Eclipse IDE for Eclipse Committers (includes Incubating components) while trying to check for updates
Version: 2023-09 (4.29.0)
Build id: 20230907-1323
An error occurred while collecting items to be installed
session context was:(profile=C__Users_lpt5kor_platform-master_2023_12_eclipse, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
No repository found containing: osgi.bundle,org.eclipse.jdt,3.19.300.v20231004-1800
No repository found containing: osgi.bundle,org.eclipse.jdt.core,3.36.0.v20231002-0333
No repository found containing: osgi.bundle,org.eclipse.jdt.core.compiler.batch,3.36.0.v20231004-1230
No repository found containing: osgi.bundle,org.eclipse.jdt.core.compiler.batch.source,3.36.0.v20231004-1230
No repository found containing: osgi.bundle,org.eclipse.jdt.core.manipulation,1.20.0.v20231003-0001
No repository found containing: osgi.bundle,org.eclipse.jdt.core.manipulation.source,1.20.0.v20231003-0001
No repository found containing: osgi.bundle,org.eclipse.jdt.core.source,3.36.0.v20231002-0333
No repository found containing: osgi.bundle,org.eclipse.jdt.ui,3.31.0.v20230928-0021
No repository found containing: osgi.bundle,org.eclipse.jdt.ui.source,3.31.0.v20230928-0021
No repository found containing: osgi.bundle,org.eclipse.m2e.jdt,2.3.3.20231002-0712
No repository found containing: osgi.bundle,org.eclipse.pde,3.13.2500.v20231004-1800
No repository found containing: osgi.bundle,org.eclipse.pde.ui,3.15.0.v20230929-1451
No repository found containing: osgi.bundle,org.eclipse.pde.ui.source,3.15.0.v20230929-1451
No repository found containing: org.eclipse.update.feature,org.eclipse.jdt,3.19.300.v20231004-1800
No repository found containing: org.eclipse.update.feature,org.eclipse.jdt.source,3.19.300.v20231004-1800
No repository found containing: org.eclipse.update.feature,org.eclipse.m2e.feature,2.4.200.20231002-0712
No repository found containing: org.eclipse.update.feature,org.eclipse.pde,3.15.200.v20231004-1800
No repository found containing: org.eclipse.update.feature,org.eclipse.pde.source,3.15.200.v20231004-1800
Also I get below error when I try to do help > perform setup tasks
Fetching content.xml from https://download.eclipse.org/eclipse/updates/4.30-I-builds/I20231015-1800/
Fetching p2.index from https://download.eclipse.org/eclipse/updates/4.30-I-builds/I20231016-1800/ (172B)
ERROR: org.eclipse.equinox.p2.metadata.repository code=1000 No repository found at https://download.eclipse.org/webtools/CI/3.31.0/I-latest/repository.
at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.fail(AbstractRepositoryManager.java:405)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:77)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:568)
at org.eclipse.oomph.util.ReflectUtil.invokeMethod(ReflectUtil.java:119)
at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager.fail(CachingRepositoryManager.java:388)
at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager.loadRepository(CachingRepositoryManager.java:279)
at org.eclipse.oomph.p2.internal.core.CachingRepositoryManager$Metadata.loadRepository(CachingRepositoryManager.java:520)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:110)
at org.eclipse.equinox.internal.p2.metadata.repository.MetadataRepositoryManager.loadRepository(MetadataRepositoryManager.java:105)
at org.eclipse.oomph.p2.internal.core.ProfileTransactionImpl$RepositoryLoader$Worker.perform(ProfileTransactionImpl.java:1759)
at org.eclipse.oomph.util.WorkerPool$Worker.run(WorkerPool.java:437)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:63)
Took 15 seconds.
There are failed tasks.
Press Back to choose different settings or Cancel to abort.
[Updated on: Tue, 17 October 2023 01:19] by Moderator
Re: Eclipse IDE installation error [message #1861514 is a reply to message #1861508] |
Tue, 17 October 2023 02:52  |
Make sure you do a pull on all the Git repositories. the second failure is fixed in the Git repository, but you have an other state in that Git repositories. Try using Window -> Preferences -> Oomph -> Bundle Pools -> Clear Cache... and then do Help -> Perform Setup Tasks again.
Current Time: Sat Aug 30 20:24:33 EDT 2025
Powered by FUDForum. Page generated in 0.13069 seconds
