Home » Modeling » MoDisco » Converting Java POJOs to EMF model
Converting Java POJOs to EMF model [message #1715081] Thu, 19 November 2015 00:03 Go to next message
I have about 47 java classes in EGerrit (http://git.eclipse.org/c/egerrit/org.eclipse.egerrit.git/tree/org.eclipse.egerrit.core/src/org/eclipse/egerrit/core/rest) that are mostly data structures (no logic).
Now I am at a point where I regret my choice of POJOs and want to replace those by an EMF model and the corresponding generated classes.
I've started playing with Modisco in the hope to get help from this and it looks promising. After running the Java project discoverer, I have an EMF model that represents the code in great details which includes everything and more.
My question is now, given this model how to I get a "standard" EMF model that would only include the structural information of my program?
Pascal
[Updated on: Thu, 19 November 2015 00:10] by Moderator
Re: Converting Java POJOs to EMF model [message #1715110 is a reply to message #1715081] Thu, 19 November 2015 05:41 Go to previous messageGo to next message
Thanks for testing MoDisco.
The model that you obtain from initial discovery conforms to a full Java metamodel defined in Ecore.
We already have automated transformations to UML Class (via KDM in MoDisco, or direct Java-to-UMLClass from https://bugs.eclipse.org/bugs/show_bug.cgi?id=477598).
Could this correspond to what you need?
EMF Ecore has been initially designed to represent domain and/or data models.
In Java code, and thus in Java models, you usually have many (or at least some) classes that are technical/implementation ones.
As a consequence, producing a coherent Ecore model from a Java model is not so trivial in the general case: that's why we don't have such a generic transformation available so far.
But of course, it is always possible to hard-code a specific transformation for a given case(s) such as yours.
A UML-to-Ecore transformation filtering the required classes could be used to this intent.
Kind regards,
Re: Converting Java POJOs to EMF model [message #1715147 is a reply to message #1715081] Thu, 19 November 2015 10:33 Go to previous messageGo to next message
Thanks Hugo. It now feels like I'm one step closer, but not there yet Smile
Using the Java-to-UML converter you provided, I've been able to get a class diagram.
Now, how should I proceed on run the UML-to-Ecore transform?
Sorry, if this is a stupid question, but I'm really new to Modisco (installed it for the first time less than 12h ago Smile) and model transforms but it really feels like it can help me.
Note that even if there was nothing that I could reuse, I would be happy to write code to produce my new model.
Thanks in advance,
Pascal
Re: Converting Java POJOs to EMF model [message #1715166 is a reply to message #1715147] Thu, 19 November 2015 12:40 Go to previous messageGo to next message
There are no stupid questions, just questions Smile
We don't have
There are actually several ways for you to implement your transformation:
  • Try the UML2EcoreConverter from the UML2 project (but I don't really know how it behaves in the general case)
  • Use a model-to-model transformation language such as ATL (https://eclipse.org/atl/).
  • Use plain Java code via the EMF API for Ecore and the UML2-specific API (please refer to these Eclipse projects for more details).
I hope this helps.
Re: Converting Java POJOs to EMF model [message #1715190 is a reply to message #1715166] Thu, 19 November 2015 20:29 Go to previous messageGo to next message
Thanks, I'll give it a try and report on what I ended up doing.
Re: Converting Java POJOs to EMF model [message #1717288 is a reply to message #1715190] Fri, 11 December 2015 08:05 Go to previous messageGo to next message
I cna now declare success on this Smile
Here is what I've done:
- Use Modisco model discovery to extract a Java Model from the source code. This was trivial to do. Right click on the Java project from which I wanted to extract the source, configure, done. At this point I have a model of my Java program, but this is not following the ecore metamodel but a Java metamodel provided by modisco
- Use Modisco model discovery to extract a UML model from the Java model previously generated.
With this last model, I wrote a little bit of code that created an ecore based model. The code is relatively simple, it goes through all the classes listed in my UML model, and create EClasses from those. I managed to generate all but one attribute of my model, so I'm fairly happy.
I did not try ATL. This was mostly because it seemed more complex to comprehend.
Finally another solution that I came across but did not try is to generate an EMF model from a Json document.
HTH
Re: Converting Java POJOs to EMF model [message #1717322 is a reply to message #1717288] Fri, 11 December 2015 11:42 Go to previous message
Thanks a lot for the feedback.
Don't hesitate to tell us more about your experiments if any other Smile
Previous Topic:AM3 project code whereabouts
Next Topic:XML Discoverer - standalone
Current Time: Tue Jun 17 15:07:33 EDT 2025
Powered by FUDForum. Page generated in 0.06731 seconds
