Home » Proposals » OSGi Enterprise Tools » OSGI Services- java.util.ServiceLoader problem(OSGI Services- java.util.ServiceLoader problem)
OSGI Services- java.util.ServiceLoader problem [message #1708448] Wed, 16 September 2015 11:05 Go to next message
You know Hibernate 4 event system is based on services. The Event class is defined in META-INF/services/org.hibernate.integrator.spi.Integrator.
We created OSGI project on Eclipse Mars. And created org.hibernate.integrator.spi.Integrator in META-INF/services. But I see OSGI cannot see services folder. java.util.ServiceLoader not loaded service in services folder.
What is the OSGI solution for this issue.
Thank You
Cenk
Re: OSGI Services- java.util.ServiceLoader problem [message #1708567 is a reply to message #1708448] Thu, 17 September 2015 09:58 Go to previous messageGo to next message
We solved the problem. The problem solved by Hibernate. we upgraded Hibernate 5.0.1 and we used hibenate.osgi 5.0.1
Re: OSGI Services- java.util.ServiceLoader problem [message #1816139 is a reply to message #1708567] Tue, 22 October 2019 03:45 Go to previous message
I also creating this type of problem, But I will try through your answer thanks for the answer it will be helpful for me.
Previous Topic:exception while starting bundle "org.eclipse.gemini.web.tomcat_1.1.0.RELEASE"
Next Topic:LinkageError: loader constraint violation
Current Time: Fri Oct 31 13:57:27 EDT 2025
Powered by FUDForum. Page generated in 0.04067 seconds
