Home » Eclipse Projects » Subversive » Installing Specific versions of SVNKit Client Adapter(SVNkit)
Installing Specific versions of SVNKit Client Adapter [message #1706699] Fri, 28 August 2015 15:27 Go to next message
Hello all, very new here and trying to set up a dev environment that matches someone remotely and they have been no help. I have added Subclipse and need to match their SVNkit Client Adapter and SVNkit Library. Can anyone point me in the correct direction on how to do so.
Need SVNkit Client Adapter 1.7.9.2 and SVNkit Library 1.7.9r9659_v20130411_2013
Thanks.
Re: Installing Specific versions of SVNKit Client Adapter [message #1706759 is a reply to message #1706699] Sun, 30 August 2015 07:38 Go to previous message
I think it would be better to ask on Subclipse's forum, but if you actually need to replace SVN Kit only I can suggest the following actions (as one way of many, since I know nothing of Subclipse versions):
1) download required SVNKit version (if you didn't do it yet)
2) replace the SVNKit's jar within eclipse/plugins folder with this downloaded one
3) run eclipse with -clean parameter (otherwise it wouldn't use the substituted jar file).
P.S.
If it is not what you want, try asking Subclipse team, they'll definitely be able to help you .
Alexander Gurov,
Subversive Team.
[Updated on: Sun, 30 August 2015 07:39] by Moderator
Previous Topic:How to install a connector once connectors dialog is closed?
Next Topic:Comitting Derived Resources
Current Time: Thu Oct 16 19:19:17 EDT 2025
Powered by FUDForum. Page generated in 0.03716 seconds
