Home » Eclipse Projects » SWTBot » Integrate SWTBOT test cases with Jenkins
Integrate SWTBOT test cases with Jenkins [message #1703968] Thu, 06 August 2015 05:40 Go to next message
I am trying to integrate SWTBOT test cases with Jenkins. For that I have added anew Job of my RCP project with SWTBOT test cases in Jenkins. We are using the Maven to build the project. But the SWTBOT test cases are not invoking. I want any example or the detailed procedure how to integrate it with Jenkins.
Please help me for the above problem.
Thanks in advance.
Re: Integrate SWTBOT test cases with Jenkins [message #1704009 is a reply to message #1703968] Thu, 06 August 2015 11:37 Go to previous messageGo to next message
On 06/08/2015 11:40, Chetana Barhate wrote:
> Hello,
> Please help me for the above problem. Thanks in advance.
in the SWTBot Wiki there's a section about that.
cheers
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: Integrate SWTBOT test cases with Jenkins [message #1704964 is a reply to message #1704009] Tue, 11 August 2015 03:19 Go to previous messageGo to next message
I have added below code to pom.xml:
<plugin>
<groupId>org.eclipse.tycho</groupId>
<artifactId>target-platform-configuration</artifactId>
<version>${tycho-version}</version>
<configuration>
<dependency-resolution>
<extraRequirements>
<requirement>
<type>eclipse-plugin</type>
<id>com.cmp.proj.client.gui.ui</id>
<versionRange>6.0.0</versionRange>
</requirement>
</extraRequirements>
</dependency-resolution>
</configuration>
</plugin>
<plugin>
<artifactId>tycho-surefire-plugin</artifactId>
<configuration>
<useUIHarness>true</useUIHarness>
<useUIThread>false</useUIThread>
<application>com.cmp.proj.client.gui.ui.application</application>-->
<dependencies>
<dependency>
<artifactId>com.cmp.proj.client.gui.ui</artifactId>
<version>6.0.0</version>
</dependency>
</dependencies>
</configuration>
</plugin>
after running the pom.xml in Jenkins the below error is showing:
[ERROR] Failed to execute goal org.eclipse.tycho:tycho-surefire-plugin:0.22.0:test (default-test) on project com.cmp.pro.client.gui.swtbot.test: Could not find application "com.cmp.proj.client.gui.ui.application" in the test runtime. Make sure that the test runtime includes the bundle which defines this application.
Here I am not able to understand the meaning of "test runtime includes the bundle which defines this application". What more need to include in the pom.xml so that the my application will lunch and test cases will executed.
Please help.
Re: Integrate SWTBOT test cases with Jenkins [message #1706094 is a reply to message #1704964] Sat, 22 August 2015 08:24 Go to previous message
On 11/08/2015 09:19, Chetana Barhate wrote:
> Hello,
> <plugin>
> <configuration>
> <extraRequirements>
> <requirement>
> </requirement>
> </configuration>
> </plugin>
> <plugin>
> <configuration>
> <dependencies>
> <dependency>
> </dependency> </dependencies>
> </configuration>
> </plugin>
> executed.
> Please help.
I think that you should only specify the dependency in the
target-platform-configuration not in the tycho-surefire-plugin
Xtext Book:
Previous Topic:NPE in HandledContributionItem when testing application on eclipse 4.5
Next Topic:auto compile plugin
Current Time: Sun Jul 27 14:11:53 EDT 2025
Powered by FUDForum. Page generated in 0.51796 seconds
