Home » Eclipse Projects » Sirius » CPN editor creation with sirius
CPN editor creation with sirius [message #1701351] |
Sun, 12 July 2015 08:36  |
Hello.
I am a master student within software development, and I have a thesis regarding the creation of an editor for Coloured Petri Nets (CPN) and originally I was planning on using EMF + GMF to do this, but I stumbled upon Sirius as I was researching, and in the little I've seen it seems like a great tool.
What I am wondering is this: To any of you with knowledge of CPN and Sirius, is this tool powerful enough to create a CPN editor? I don't have unlimited time, so before I decide to switch over to Sirius ( which my guidance councelor knows nothing about ) I'd like to know that it's at least possible.
Re: CPN editor creation with sirius [message #1701724 is a reply to message #1701351] |
Wed, 15 July 2015 05:18   |
I do not really have knowledge on Coloured Petri Nets but if I am right
it should be a diagram displaying rectangle (transition?) or ellipse
(Step?) shapes that are connected to describe some kind of cinematic?
The coloured part is, I guess, a coloration of these shapes depending on
the value of a property or the result of an expression. If this sounds
right then this I think using Sirius is a good idea. Maybe you can find
in the gallery[1] an example that is close to the result you expect.
Steve
[1] https://www.eclipse.org/sirius/gallery.html
Le 13/07/2015 16:31, Erlend Rommetveit a écrit :
> Hello.
> like a great tool.
> at least possible.
> Thanks
Steve Monnier - Obeo
Need professional services for Sirius?
Re: CPN editor creation with sirius [message #1702153 is a reply to message #1701724] |
Mon, 20 July 2015 07:29   |
Hello.
You are not totally off the money. CPN consists of places, transitions and arcs between these. Transitions act like events, and places represent the states a system can have when combined with "tokens". Tokens have a type(or a colour), the same type the corresponding place has. So when a transition fires, some expressions on the connected arcs are computed, and tokens can move from one place to another to simulate another state in the system.
So I'm wondering if it's possible to get some graphical representation of the simulation of this "token game" where they move around on the model based on arc expressions. The current CPN editor uses CPN ML (based on Standard ML) for the inscriptions. But I would like this to be flexible.
The closest thing I found in the gallery was the Cinematic Designer by Obeo I think, given that it's based on events and a flow. But it wasn't exactly what I had in mind.
Thanks in advance
Steve Monnier wrote on Wed, 15 July 2015 09:18Hello,
in the gallery an example that is close to the result you expect.
Steve
Re: CPN editor creation with sirius [message #1702165 is a reply to message #1702153] |
Mon, 20 July 2015 08:41   |
The mapping representing your places will require a conditional style[1]
or a style customization[2] that will display the proper color depending
on the token type.
For the simulation, I have to admit that I vizualise some pachinko game,
where you drop a token from the top and it falls through the system and
rebounds on pins (transition). Do you require only an action at the
"root" and it "goes through the transitions" or is it a step by step
process where you need actions at each transition? Anyway, you will need
the algorithm that modifies the semantic model when you
"add/consume/move a token". I do not know if CPN editor provides some
APIs to process this "token game". In your VSM (odesign file) you would
only need to add a tool, like an action/popup menu tool or a double
click tool that execute the algorithm. As the model would be modified,
the places where the token type change will be updated automaticaly and
display the new color, thanks to the conditional style[1] or style
customization[2].
Steve
[1]
https://www.eclipse.org/sirius/doc/specifier/diagrams/Diagrams.html#conditional_styles
[2]
https://www.eclipse.org/sirius/doc/specifier/diagrams/Diagrams.html#customization
Le 20/07/2015 13:29, Erlend Rommetveit a écrit :
> Hello.
> flexible.
> Thanks in advance
>> Hello,
>> right it should be a diagram displaying rectangle (transition?) or
>> ellipse (Step?) shapes that are connected to describe some kind of
>> cinematic? The coloured part is, I guess, a coloration of these shapes
>> depending on the value of a property or the result of an expression.
>> If this sounds right then this I think using Sirius is a good idea.
>> Maybe you can find in the gallery an example that is close to the
>> result you expect.
>> Regards,
>> Steve
Re: CPN editor creation with sirius [message #1702585 is a reply to message #1702165] |
Thu, 23 July 2015 08:11   |
Instead of picturing a token going from the root through the graph, imagine a net where the initial state can have tokens on all places where they are needed, and no root node is apparent. A transition can take a token from an input place and consume it, and produce one or more tokens (not necessarily with the same colour/type) on one or more output places. The tokens consumed and produced are dependent on the expressions on the input and output arcs. So there would be a step by step process.
I guess my initial question has been answered, so I will be using Sirius in my thesis. Thank you very much for your help, and expect that I will be back for another conundrum in the near future
Erlend
Steve Monnier wrote on Mon, 20 July 2015 12:41Hello,
on the token type.
customization[2].
Steve
[1]
[2]
Re: CPN editor creation with sirius [message #1702589 is a reply to message #1702585] |
Thu, 23 July 2015 08:27  |
Ok I see more clearly the process, this is interesting. Good luck for
your thesis. The Sirius team will be ready for your next challenge.
Steve
> step process.
> be back for another conundrum in the near future :)
> Regards
> Erlend
>> Hello,
>> style[1] or a style customization[2] that will display the proper
>> color depending on the token type.
>> game, where you drop a token from the top and it falls through the
>> system and rebounds on pins (transition). Do you require only an
>> action at the "root" and it "goes through the transitions" or is it a
>> step by step process where you need actions at each transition?
>> Anyway, you will need the algorithm that modifies the semantic model
>> when you "add/consume/move a token". I do not know if CPN editor
>> provides some APIs to process this "token game". In your VSM (odesign
>> file) you would only need to add a tool, like an action/popup menu
>> tool or a double click tool that execute the algorithm. As the model
>> would be modified, the places where the token type change will be
>> updated automaticaly and display the new color, thanks to the
>> conditional style[1] or style customization[2].
>> Regards,
>> Steve
>> [1]
>> [2]
Current Time: Wed Jun 18 04:37:37 EDT 2025
Powered by FUDForum. Page generated in 0.05493 seconds
