Home » Newcomers » Newcomers » Reviving an old project(How to get information about eclipse version and plugins used on a project)
Reviving an old project [message #1699701] Thu, 25 June 2015 22:48 Go to next message
There is a procedure of how to know what version of eclipse and what plugins were used on a project?
I have an old project eclipse (to be deployed on Apache Tomcat (my only reference)) and I need to know which version of eclipse was used and what plugins in order to revive it.
[Updated on: Thu, 25 June 2015 22:48] by Moderator
Re: Reviving an old project [message #1699839 is a reply to message #1699701] Sat, 27 June 2015 00:09 Go to previous messageGo to next message
> reference)) and I need to know wich version of eclised was used and what
Is there a reason for being so "historical"? Why not just bring it up in
the latest Eclipse and one of the later Tomcats? The only way that won't
work is if the application was specifically tapping into Tomcat
internals that have changed since it was done. In my experience, it's
unlikely that this would have been the case and equally unlikely that
Tomcat would be the reason it won't work using "modern" tools.
Or, did you try and already know it won't work?
Re: Reviving an old project [message #1700034 is a reply to message #1699839] Mon, 29 June 2015 14:38 Go to previous messageGo to next message
The application is on production since 2007. I just did what you suggested, but i get so many errors that make me think if may be is more simple replicate the scenario were the code was made.
Re: Reviving an old project [message #1700069 is a reply to message #1700034] Mon, 29 June 2015 19:24 Go to previous messageGo to next message
List a few of those errors here for us. You mean missing symbol errors,
right?
Re: Reviving an old project [message #1700190 is a reply to message #1700069] Tue, 30 June 2015 10:50 Go to previous messageGo to next message
Attached an image of some of the erros:
index.php/fa/22358/0/
  • Attachment: errors.PNG
    (Size: 52.01KB, Downloaded 193 times)
Re: Reviving an old project [message #1700228 is a reply to message #1700190] Tue, 30 June 2015 23:21 Go to previous messageGo to next message
I'm unfamiliar with these APIs, but I can confidently state that they
have nothing to do with Tomcat. Tomcat-Eclipse is not your problem.
You're simply missing some other library, likely a sort of presentation API.
Your old project should contain some clues. I'm not seeing enough of the
error messages to know what the package names are so I've been unable to
ascertain what library is missing.
Re: Reviving an old project [message #1700329 is a reply to message #1700228] Wed, 01 July 2015 17:44 Go to previous message
You are right, the errors presented are from a library specific to the project.
I went through the code and most of the errors are missing references to STRUCT.
I'm trying to follow the path of using the latest eclipse to compile the project. I'll try to keep posting progress.
Previous Topic:svn subclipse password issue
Next Topic:"gcc" program could not be found
Current Time: Fri Jul 25 21:52:49 EDT 2025
Powered by FUDForum. Page generated in 0.52805 seconds
