Home » Newcomers » Newcomers » The deployment lifecycle
The deployment lifecycle [message #1699752] Fri, 26 June 2015 07:00 Go to next message
Hello!
I am trying deploy a lifecycle on jetty 9 (jetty-9.2.10.v20150310) and want to use my extended AppLifeCycle class - app.jls.AppLifeCycle. My class belongs to AppLib.jar (in directory $(jetty.base)/lib).
In $(jetty.base)/etc/jetty-deploy.xml i have copied file from $(jetty.home)/etc/jetty-deploy.xml. Then i added records:
<!-- Add a customize step to the deployment lifecycle -->
<!-- uncomment and replace DebugBinding with your extended AppLifeCycle.Binding class -->
<Call name="insertLifeCycleNode">
<Arg>deployed</Arg>
<Arg>starting</Arg>
<Arg>customise</Arg>
</Call>
<Call name="addLifeCycleBinding">
<Arg>
<New class="app.jls.AppLifeCycle">
</New>
</Arg>
</Call>
By starting jetty throws an exception, that caused by java.lang.ClassNotFoundException: app.jls.AppLifeCycle and then jetty stop.
I am new in Jetty. Help me start my Lifecycle.
Many thanks in advance.
P.S. My application contains two parts: app.jls.AppLifeCycle (in directory $(jetty.base)/lib/AppLib.jar) and WebServerApp.war that is in directory $(jetty.base)/webapps.
The second part (WebServerApp.war) deploy fine.
Re: The deployment lifecycle [message #1699841 is a reply to message #1699752] Sat, 27 June 2015 00:12 Go to previous messageGo to next message
On 06/26/2015 08:53 AM, Mihail Sidorov wrote:
> Hello!
> <Arg>deployed</Arg>
> <Arg>starting</Arg>
> </Call>
> <Arg>
> </New>
> </Arg>
> </Call>
Eclipse web tools platform has its own forum (Eclipse WTP). Check it out.
Re: The deployment lifecycle [message #1699954 is a reply to message #1699841] Mon, 29 June 2015 09:00 Go to previous message
Jetty has a users mailing list that they use primarily instead of these forums: https://dev.eclipse.org/mailman/listinfo/jetty-users
Previous Topic: Macbook air os x c++ installation and setup
Next Topic:Unable to install Saros plugin
Current Time: Sun Jun 15 07:28:46 EDT 2025
Powered by FUDForum. Page generated in 0.09684 seconds
