Re: Variable warnings no longer showing (again) - pdt-extensions. [message #1698198 is a reply to message #1698149] |
Fri, 12 June 2015 02:24   |
Dawid Pakula wrote on Thu, 11 June 2015 15:24Latest Core-Plugin require minimum PDT 3.5 (current nightly, will be released together with mars). Both, 3.5 and DLT 5.2 are available in http://p2-dev.pdt-extensions.org/., so please also select category "PHP Development Tools", and "contact all sites during update".
If I select "PHP Development Tools (PDT)" and I make sure I have "Contact all update...", I get the following,
Your original request has been modified.
"PHP Development Tools (PDT)" is already installed, so an update will be performed instead.
Cannot complete the install because one or more required items could not be found.
Software being installed: PHP Development Tools (PDT) 3.5.0.201506101836 (org.eclipse.php.feature.group 3.5.0.201506101836)
Missing requirement: PHP Development Tools (PDT) 3.5.0.201506101836 (org.eclipse.php.feature.group 3.5.0.201506101836) requires 'org.eclipse.dltk.core.feature.group 5.2.0' but it could not be found
It says, "...update will be performed instead...", But I cannot install anything.
if I chose "PDT Extensions", (and "Contact all update...") by itself, I get
Cannot complete the install because of a conflicting dependency.
Software being installed: PDT Extensions 0.21.0.201505272153 (org.pdtextensions.feature.feature.group 0.21.0.201505272153)
Software currently installed: PHP Development Tools (PDT) 3.3.0.201406110111 (org.eclipse.php.feature.group 3.3.0.201406110111)
Only one of the following can be installed at once:
PDT Core Plug-in 3.4.0.201502171754 (org.eclipse.php.core 3.4.0.201502171754)
PDT Core Plug-in 3.3.0.201406110111 (org.eclipse.php.core 3.3.0.201406110111)
PDT Core Plug-in 3.3.1.201409161013 (org.eclipse.php.core 3.3.1.201409161013)
PDT Core Plug-in 3.5.0.201506101836 (org.eclipse.php.core 3.5.0.201506101836)
Cannot satisfy dependency:
From: PHP Development Tools (PDT) 3.3.0.201406110111 (org.eclipse.php.feature.group 3.3.0.201406110111)
To: org.eclipse.php.core [3.3.0.201406110111]
From: PDT Extensions Core Plugin 0.21.0.201505272153 (org.pdtextensions.core 0.21.0.201505272153)
To: bundle org.eclipse.php.core 3.5.0
From: PDT Extensions 0.21.0.201505272153 (org.pdtextensions.feature.feature.group 0.21.0.201505272153)
To: org.pdtextensions.core [0.21.0.201505272153]
I am doing a clean install, maybe I should get eclipse without PDT?
S.
FUDForum. Page generated in 0.04636 seconds
