Edit semantic model programmatically [message #1697780] |
Mon, 08 June 2015 09:03  |
I need to edit some features of some model objects via plugin eclipse.
My method to set "devicename" property of "SystemMode" object is defined like below :
public void setDevicenameofSystem(){
System.out.println(s.getSemanticResources().iterator().next());
XMIResourceImpl xmiressourceImpl = (XMIResourceImpl) s.getSemanticResources().iterator().next();
final SystemModeImpl var = (SystemModeImpl) xmiressourceImpl.getContents().get(0);
System.out.println(var.toString());
final ModelAccessor ma = s.getModelAccessor();
System.out.println("can edit device name : " +ma.getPermissionAuthority().canEditFeature(var, "devicename"));
try {
TransactionalEditingDomain ted = s.getTransactionalEditingDomain();
CommandStack stack = ted.getCommandStack();
System.out.println(ted.getResourceSet());
RecordingCommand cmd = new RecordingCommand(ted) {
protected void doExecute() {
var.setDevicename("Test");
stack.execute(cmd);
catch (ServiceException e) {
e.printStackTrace();
I get as results :
ExternalJavaActionModelAnalysis
Work Session :Local Session: representations.aird
org.eclipse.emf.ecore.xmi.impl.XMIResourceImpl@10412e2 uri='platform:/resource/Demo/My.modemodeling'
modemodeling.impl.SystemModeImpl@f508fb (devicename: SystemMode)
can edit device name : true
!ENTRY org.eclipse.equinox.registry 4 1 2015-06-08 12:32:51.363
!MESSAGE Plug-in "xxx.modelanalysis" was unable to instantiate class "xxx.modelanalysis.ExternalJavaActionModelAnalysis".
!STACK 0
java.lang.IllegalStateException: Cannot activate read/write transaction in read-only transaction context
at org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.acquire(TransactionalEditingDomainImpl.java:576)
at org.eclipse.emf.transaction.impl.TransactionalEditingDomainImpl.activate(TransactionalEditingDomainImpl.java:508)
at org.eclipse.emf.transaction.impl.TransactionImpl.start(TransactionImpl.java:204)
I read documentation about "TransactionalEditingDomain", "Session", "ModelAccessor" and "PermissionAuthority" but I don't find a clear example for my requirement.
Thank you.
Re: Edit semantic model programmatically [message #1697820 is a reply to message #1697819] |
Mon, 08 June 2015 11:59   |
I forgot to add, if you use this code in a Java Service, executed from a
tool with a set operation, you should have the context (change context
operation) on your SystemMode element. In your java service, you should
have a SystemMode as first parameter (public void
setDevicenameofSystem(SystemMode systemMode){). Then in your expression
you can directly call it [setDevicenameofSystem()/] as the first
parameter will use the current context.
Steve
Le 08/06/2015 17:49, Steve Monnier a écrit :
> Hello,
> Executing a recording command using the command stack of the
> Transactional Editing domain is the proper way.
> How do you call this method? As there is no parameter I guess this is
> not a Java Service[1], called from a Sirius Tool operation[2]. Maybe it
> would work better this way.
> Regards,
> Steve
> [1]
> https://www.eclipse.org/sirius/doc/specifier/general/Writing_Queries.html#service_methods
> [2]
> https://www.eclipse.org/sirius/doc/specifier/general/Model_Operations.html#extensions
> Le 08/06/2015 16:08, Yassine BEN ATITALLAH a écrit :
>> Hello,
>> like below :
>> try {
>> @Override
>> stack.execute(cmd);
>> I get as results :
>> !STACK 0
>> at
>> at
>> at
>> Thank you.
Steve Monnier - Obeo
Need professional services for Sirius?
Re: Edit semantic model programmatically [message #1698044 is a reply to message #1698000] |
Wed, 10 June 2015 10:59  |
I am glad you resolved the problem.
Ok you were using an External Java Action. I am surprised of the
read/write transaction exception. However, the External Java Action is
already executed in a transaction so in that case you did not need a
RecordingCommand executed on the command stack. This embedded execution
probably caused this issue, but this should be reproduced on our side to
verify.
Steve
Le 10/06/2015 10:47, Yassine BEN ATITALLAH a écrit :
> Hello,
> Thank you. I resolved the problem to edit model elements via java method.
> In the first time, I call my method via Viewpoint Specification with an
> External Java Action in a Double Click to edit element. My Java class is
> defined in plug in extension point
> "org.eclipse.sirius.externalJavaAction". I use Session service to get
> TransactionalEditingDomain. But in my test i get an error message
> "Cannot activate read/write transaction in read-only transaction context".
> In the second time, I call my method via Viewpoint Specification with a
> Java Services following your steps detailed in your last message. And I
> use the same implementation with Session service and
> TransactionalEditingDomain and finally i can edit the element of the
> model via my method.
> Thank you.
> Yassine.
FUDForum. Page generated in 0.05887 seconds
