Home » Newcomers » Newcomers » Trouble deploying Thym to Android Device(java.lang.ClassNotFoundException)
Trouble deploying Thym to Android Device [message #1697353] Wed, 03 June 2015 06:54 Go to next message
Hi there,
I'm trying out different IDE's for Cordova to assure compatibility with my plugin. I'm now trying out Eclipse and the Thym addon. All installed great and I created a new project, went to run it on my device which is connected, I just get the following error,
BUILD FAILED
Unable to instantiate specified input handler class org.eclipse.ant.internal.ui.antsupport.inputhandler.AntInputHandler : java.lang.ClassNotFoundException
Total time: 23888806 minutes 49 seconds
Any ideas what that means?
Re: Trouble deploying Thym to Android Device [message #1697433 is a reply to message #1697353] Wed, 03 June 2015 17:15 Go to previous messageGo to next message
Which download of Eclipse is it (the exact filename)? Are you missing the Java tools?
Re: Trouble deploying Thym to Android Device [message #1697604 is a reply to message #1697433] Fri, 05 June 2015 06:16 Go to previous message
Thanks! Silly me, I had installed the C/C++ version instead. Might be good if the Thym addon notified you that you are using the wrong version.
Previous Topic:Eclipse isn't working after themes installed
Next Topic:Looking for a Tool Combination for Big Data Programming
Current Time: Sun Jul 20 15:52:48 EDT 2025
Powered by FUDForum. Page generated in 0.08985 seconds
