Home » Eclipse Projects » Sirius » Edit Representations.aird(Add new DRepresentationElement)
Edit Representations.aird [message #1696198] Fri, 22 May 2015 16:36 Go to next message
Hi all guys,
i want to edit file Representations.aird. At the moment i have retrieved DAnalysis, DRepresentation of the current Session, and created a new DEdge. But i have a problem when i want to add that DRepresentationElement(here is DEdge) to DRepresentation. Some example code is below:
IFile file = ResourcesPlugin.getWorkspace().getRoot().getFile(iPath);
IFile airdFile = null;
IContainer container = file.getParent();
if (container instanceof IProject){
airdFile = ((IProject)container).getFile("representations.aird");
} else if (container instanceof IFolder){
airdFile = ((IFolder)container).getFile("representations.aird");
//Get URI of the representations file
URI representationsFileURI = URI.createPlatformResourceURI(airdFile
.getFullPath().toOSString(), true);
URI fFileURI = URI.createPlatformResourceURI(file.getFullPath()
//Get session of the representations
SessionCreationOperation sessionCreating = new DefaultLocalSessionCreationOperation(representationsFileURI, new NullProgressMonitor());
try {
sessionCreating.execute();
} catch (CoreException e) {
e.printStackTrace();
Session session = sessionCreating.getCreatedSession();
// Get the representation of the current session
DAnalysis root = (DAnalysis) session.getSessionResource()
.getContents().get(0);
EList<DView> views = root.getOwnedViews();
EList<DRepresentation> representations = new BasicEList<DRepresentation>();
for(DView view : views){
representations.addAll(view.getOwnedRepresentations());
DRepresentation representation = null;
EObject rootObject = null;
for (DRepresentation currentRep : representations) {
if (currentRep instanceof DSemanticDiagramSpec) {
rootObject = ((DSemanticDiagramSpec) currentRep)
.getTarget();
Resource eResource = rootObject.eResource();
URI eUri = eResource.getURI();
if (eUri.equals(fFileURI)) {
representation = currentRep;
break;
DEdge mesEdge = DiagramFactoryImpl.eINSTANCE.createDEdge();
EList<DRepresentationElement> dREs = new BasicEList<DRepresentationElement>();
dREs.addAll(dR.getOwnedRepresentationElements());
((DDiagramImpl)dR).eSet(6, dREs);
All the time problems has been occured:
!ENTRY org.eclipse.jface 4 2 2015-05-22 22:34:12.257
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.jface".
!STACK 0
java.lang.IllegalStateException: Cannot modify resource set without a write transaction
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.assertWriting(TransactionChangeRecorder.java:348)
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.appendNotification(TransactionChangeRecorder.java:302)
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.processObjectNotification(TransactionChangeRecorder.java:284)
at org.eclipse.emf.transaction.impl.TransactionChangeRecorder.notifyChanged(TransactionChangeRecorder.java:240)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.emf.ecore.util.EcoreEList.dispatchNotification(EcoreEList.java:249)
at org.eclipse.emf.common.notify.impl.NotifyingListImpl.clear(NotifyingListImpl.java:1090)
at org.eclipse.sirius.diagram.impl.DDiagramImpl.eSet(DDiagramImpl.java:791)
at org.eclipse.sirius.diagram.impl.DSemanticDiagramImpl.eSet(DSemanticDiagramImpl.java:133)
at org.scenariotools.msd.simulation.ui.views.MSDModalMessageEventSelectionView.displayLastMessageEvent(MSDModalMessageEventSelectionView.java:410)
at org.scenariotools.msd.simulation.ui.views.MSDModalMessageEventSelectionView.objectDoubleClicked(MSDModalMessageEventSelectionView.java:320)
at org.scenariotools.msd.simulation.ui.views.AbstractMSDModalMessageEventsView$2.run(AbstractMSDModalMessageEventsView.java:550)
at org.scenariotools.msd.simulation.ui.views.AbstractMSDModalMessageEventsView$3.doubleClick(AbstractMSDModalMessageEventsView.java:562)
at org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredViewer.java:831)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:50)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:178)
at org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(StructuredViewer.java:828)
at org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSelect(AbstractTreeViewer.java:1472)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSelected(StructuredViewer.java:1237)
at org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEvent(OpenStrategy.java:252)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.java:249)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:311)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4188)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1467)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1490)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1475)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1279)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4031)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3658)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1151)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1032)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:148)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:636)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:135)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:380)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:235)
at java.lang.reflect.Method.invoke(Method.java:483)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
It say : "Cannot modify resource set without a write transaction". Can anyone help me with this situation? Thanks so much!
Re: Edit Representations.aird [message #1696464 is a reply to message #1696198] Tue, 26 May 2015 10:50 Go to previous message
Hi Minh Hiep,
Sirius is based on EMF Transaction framework [1]. Consequently you
should use EMF Command to update the model.
[1]
http://www.linuxtopia.org/online_books/eclipse_documentation/eclipse_emf_model_transaction_developer_guide/topic/org.eclipse.emf.transaction.doc/references/overview/eclipse_emf_model_transaction_creating.html
Best Regards.
Le 22/05/2015 22:36, Minh Hiep Pham a écrit :
> Hi all guys,
> code is below:
> IFile file =
> airdFile =
> airdFile =
> try {
> .getTarget();
> break;
> !STACK 0
> write transaction
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> at
> at
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
> at
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
> at
> at
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
Esteban Dugueperoux - Obeo
Need professional services for Sirius?
Previous Topic:Use EMF's node Any in Sirius
Next Topic:Is it possible to create a diagram similar to class diagram with Sirius?
Current Time: Sun Jun 15 02:41:18 EDT 2025
Powered by FUDForum. Page generated in 0.03476 seconds
