Setting up Tomcat with eclipse anf CATALINA_HOME setup [message #1694157] |
Fri, 01 May 2015 01:34  |
1) I have downloaded Apache Tomcat zip file in "C:\Users\sonij3\Desktop\Apache Tomcat\" When I extracted files from it , new dir structure where binary and lib files are is
"C:\Users\sonij3\Desktop\Apache Tomcat\apache-tomcat-6.0.43-windows-x64\apache-tomcat-6.0.43\lib"
Then I clicked on WIndows Service Installer and Tomcat got installed in "C:\Program Files\Apache Software Foundation\". what should be CATALINA_HOME ?
2) Is it required to download Apache Tomcat zip file (8 MB size) OR can I directly use Windows Service Installer from ''https://tomcat.apache.org/download-60.cgi" website to install Tomcat without downloading it ?
When I am trying to setup eclipse wuth Tomcat Installation Dir as "C:\Program Files\Apache Software Foundation\Tomcat 6.0\lib" OR "C:\Users\sonij3\Desktop\Apache Tomcat\apache-tomcat-6.0.43-windows-x64\apache-tomcat-6.0.43\lib", I ma getting error message "The Tomcat installation directory is not valid. It is missing expected file or folder lib/jasper-el.jar" While jasper~el jar is available in both locations.
Why am I getting such an error ? How do I set up correct path here ?
3) I have setup CATALINA_HOME as "C:\Program Files\Apache Software Foundation"
Then I am trying to check version of Tomcat as
Quote:"C:\Users\nirjari>"Desktop\Apache Tomcat\apache-tomcat-6.0.43-windows-x64\apache-tomcat-6.0.43\bin\version.bat"
The CATALINA_HOME environment variable is not defined correctlyThis environment variable is needed to run this program
I don't see version.bat in Tomcat Installation path "C:\Program Files\Apache Software Foundation\Tomcat 6.0\bin"
Then I also tried setting CATALINA_HOME as "C:\Users\nirjari\Desktop\Apache Tomcat\apache-tomcat-6.0.43-windows-x64\apache-tomcat-6.0.4", "C:\Users\nirjari\Desktop\Apache Tomcat\apache-tomcat-6.0.43-windows-x64" AND "C:\Users\nirjari\Desktop\Apache Tomcat", But I am getting same error.
So whats wrong with CATALINA_HOME in here ? What should be correct CATlALINA_HOME ?
Re: Setting up Tomcat with eclipse anf CATALINA_HOME setup [message #1694202 is a reply to message #1694157] |
Fri, 01 May 2015 22:31  |
> CATALINA_HOME ?
> Foundation" Then I am trying to check version of Tomcat as
> Quote:
> CATlALINA_HOME ?
Unless you're planning on really serving up Java pages from your Windows
desktop, you don't need to install Tomcat. Just point Eclipse at it
(Window -> Preferences -> Server -> Runtime Environment -> Add -> Apache
Tomcat v6.0 -> Next -> Browse to
C:\Users\sonij3\wherever-you-decide-to-keep-it.
Then just launch your web application, to run or to debug, and Eclipse
will launch Tomcat for you.
You do not need to touch CATALINA_HOME.
FUDForum. Page generated in 0.09217 seconds
