Home » Newcomers » Newcomers » Getting Error message while starting Eclipse.(Error message exit code = 13)
Getting Error message while starting Eclipse. [message #1693494] Fri, 24 April 2015 10:24 Go to next message
Hi All,
I went through the post here but still could not find myself comfortable.
I installed an eclipse i.e eclipse-java-luna-SR2-win32-x86_64
Java versions:
I have multiple versions installed.
1. jdk1.8.0_45
2. jre1.8.0_40
3. jre1.8.0_45
I tried adding the -vm into eclipse.ini file but still no help.
My eclipse.ini file looks like this:
-startup
plugins/org.eclipse.equinox.launcher_1.3.0.v20140415-2008.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.200.v20150204-1316
-product
org.eclipse.epp.package.java.product
--launcher.defaultAction
openFile
--launcher.XXMaxPermSize
256M
-showsplash
org.eclipse.platform
256m
openFile
--launcher.appendVmargs
-vm
C:/Program Files (x86)/Java/jdk1.8.0_45/bin/javaw.exe
-vmargs
-Dosgi.requiredJavaVersion=1.6
-Xms40m
-Xmx512m
Error message that I am getting is:
Java is installed is installed in following part:
C:\Program Files (x86)\Java
Eclipse is in F:\ {drive}
Please help me guys. I am noob here.
I am trying to learn Selenium automation testing. This is my requiremet.
  • Attachment: Error_Msg.png
    (Size: 19.73KB, Downloaded 170 times)
Re: Getting Error message while starting Eclipse. [message #1693499 is a reply to message #1693494] Fri, 24 April 2015 10:43 Go to previous messageGo to next message
You have a 64-bit Eclipse with 32-bit versions of Java. They have to match. It's also mentioned in https://www.eclipse.org/forums/index.php/t/198527/ .
Re: Getting Error message while starting Eclipse. [message #1693553 is a reply to message #1693494] Sat, 25 April 2015 00:40 Go to previous message
On 04/24/2015 08:42 AM, Somen Singh wrote:
> Hi All,
> Java versions:
> 1. jdk1.8.0_45
> 2. jre1.8.0_40
> 3. jre1.8.0_45
> -startup
> --launcher.library
> -product
> openFile
> 256M
> -showsplash
> 256m
> openFile
> -vm
> -vmargs
> -Xms40m
> -Xmx512m
Why would you try to run a 64-bit Eclipse using a 32-bit JRE?
Previous Topic:Custom Look and Feel
Next Topic:Glassfish 4 on Eclipse
Current Time: Sat Jul 26 16:55:25 EDT 2025
Powered by FUDForum. Page generated in 0.07950 seconds
