Home » Newcomers » Newcomers » Downloading Eclipse(Eclipse Not Downloading)
Downloading Eclipse [message #1693114] Tue, 21 April 2015 16:34 Go to next message
Trying to set up Eclipse to learn Python and Java. Managed to download Python 3.2.3 and Java SE Development Kit 8 okay. But when I download Eclipse 3.7.2, extract files and try opening the Eclipse interface the opening window flashes up then disappears - no ability to run it at all.
Any ideas what I might be doing wrong. I've made sure that all downloads are 32 bit in line with my OS - Windows 7.
Appreciate any help.
Re: Downloading Eclipse [message #1693124 is a reply to message #1693114] Tue, 21 April 2015 19:26 Go to previous messageGo to next message
You'll find current releases at http://download.eclipse.org/ . I suggest trying a 32-bit download from there first.
Re: Downloading Eclipse [message #1693129 is a reply to message #1693114] Tue, 21 April 2015 20:12 Go to previous messageGo to next message
Understand that you'll need:
1) A JDK to use to learn and use Java, and also to run Eclipse.
2) Python, which you've downloaded an installed.
3) Your choice of Eclipse IDE (as Nitin points out).
4) Last, after launching Eclipse, go to Help -> Eclipse Marketplace,
search for and download PyDev. When you configure PyDev, you'll be
telling it where to get Python from.
PyDev isn't supported by these Eclipse forums. You'll do better at
stackoverflow.com for problems arising using PyDev.
You may or may not find these notes useful:
http://www.javahotchocolate.com/notes/pydev.html
Re: Downloading Eclipse [message #1693222 is a reply to message #1693129] Wed, 22 April 2015 09:09 Go to previous message
Also make sure you've read and understand the forum Announcement (at the top of this forum) named "Eclipse won't start? READ THIS FIRST"
Previous Topic:hyrbid mobile tool installation problem
Next Topic:i have flash builder but do I use eclipse normally?
Current Time: Thu Oct 16 01:04:26 EDT 2025
Powered by FUDForum. Page generated in 0.10409 seconds
