Home » Newcomers » Newcomers » Install Eclipse 32bit AND Eclipse 64Bit on same Computer?
Install Eclipse 32bit AND Eclipse 64Bit on same Computer? [message #1691615] Wed, 08 April 2015 09:50 Go to next message
I have Eclipse 64 bit and MinGW 64bit setup on my win 8.1 64 bit computer. All runs correctly
If I download the Eclipse 32 bit it requires MinGW 32 bit. However MinGW 32 bit overwrites the MinGW 64 bit files if I install the MinGW32 bit into the MinGW directory that has the MinGW 64 bit files. Since both Eclipse 64 bit and Eclipse 32 bit require the C:\MinGW directory, how can I run Eclipse for 32bit and 64bit on the same computer?
Re: Install Eclipse 32bit AND Eclipse 64Bit on same Computer? [message #1691676 is a reply to message #1691615] Wed, 08 April 2015 21:41 Go to previous messageGo to next message
First, I don't do C/C++ on Eclipse. You should ask about such issues in
the Eclipse CDT forum.
This said, there is no problem __running__ both versions of Eclipse on
the same host even at the same time as long as you wire them each to an
appropriately bitted JRE.
Hope this helps.
Re: Install Eclipse 32bit AND Eclipse 64Bit on same Computer? [message #1691807 is a reply to message #1691615] Thu, 09 April 2015 16:24 Go to previous messageGo to next message
Are you unable to prevent that?
Re: Install Eclipse 32bit AND Eclipse 64Bit on same Computer? [message #1691821 is a reply to message #1691807] Thu, 09 April 2015 19:12 Go to previous messageGo to next message
No I'm not able to prevent MinGW 32bit ffrom overwriting MinGW 64bit in the C:\MinGW directory. Since both Eclipse 32 and Eclipse 64 look for the C:\MinGW there is no way to have separate MinGW 32bit and MinGW 64bit directories. Right now I have Eclipse 32 on one computer and Eclipse 64 on another computer.
Am I missing something here? Is there a version of MinGW that will install both 32bit and 64 bit files so that both Eclipse 32bit and Eclipse 64 bit can find them in the C:\MinGW directory?
Re: Install Eclipse 32bit AND Eclipse 64Bit on same Computer? [message #1691822 is a reply to message #1691676] Thu, 09 April 2015 19:15 Go to previous message
I have asked in the C++ CDT forum.
I have both 32bit and 64bit Java and yes without MinGW Eclipse 32bit and Eclipse 64bit run fine. MinGW is needed for C++, C, etc
Previous Topic:Where is plug-in wizard in Eclipse Luna
Next Topic:error while opening eclipse
Current Time: Mon Jun 16 04:45:59 EDT 2025
Powered by FUDForum. Page generated in 0.63951 seconds
