Home » Language IDEs » AspectJ » SVN checkout not working in Eclipse(Checkout, Sync and Comit problem)
SVN checkout not working in Eclipse [message #1690939] Wed, 01 April 2015 02:06 Go to next message
I am not able to checkout from my office. It hangup and also while syncronizing it hang up at 40%. But when i am checking out the other repo from same server i am able to checkout. And, i am able to checkout from outer network but from office network it hung up. Does SVN Server stores the client information? This has been from past 20 days. Still i didn't get the solution of this.
It hung up at "Get Repository of Children". Please help me. I am in big trouble.
Eclipse Platform
Version: 3.7.2
Build id: M20120208-0800
Subversive Revision Graph (Optional) (Incubation) 0.7.9.I20120210-1700
Subversive SVN Connectors 2.3.0.I20120413-1700
Subversive SVN Integration for the Mylyn Project (Optional) I20110602-1700
Subversive SVN JDT Ignore Extensions (Optional) (Incubation) 0.7.9.I20111119-1700
Subversive SVN Team Provider (Incubation) 0.7.9.I20120520-1700
Subversive SVN Team Provider Localization (Optional) (Incubation) 0.7.9.I20120316-1700
Subversive SVN Team Provider Sources (Incubation) 0.7.9.I20120417-1700
SVNKit 1.3.7 Implementation (Optional) 2.3.0.I20120413-1700
SVNKit 1.7.4 Implementation (Optional) 2.3.0.I20120413-1700
Re: SVN checkout not working in Eclipse [message #1691023 is a reply to message #1690939] Wed, 01 April 2015 11:45 Go to previous messageGo to next message
It's hard to know without more information, but it looks like a network/firewall situation. I'd recommend having a chat with your sysadmin and seeing if there is a blocked port.
Re: SVN checkout not working in Eclipse [message #1691026 is a reply to message #1691023] Wed, 01 April 2015 12:01 Go to previous messageGo to next message
Hello I am system admin. There is no block port. I have checked and there is no issue of firewall/iptables/seliniux because all are disabled. I am able to commit via svn command line but from eclipse it hang up and on the same side i am able to checkout from the same server by eclipse in different network.
Is eclipse handles some network config file?
Re: SVN checkout not working in Eclipse [message #1691031 is a reply to message #1691026] Wed, 01 April 2015 12:51 Go to previous messageGo to next message
Eclipse does not use the standard network settings of your machine. You need to specify network settings in the eclipse preferences page. Go to Preferences -> General -> Network Connections. You might find an answer there.
Re: SVN checkout not working in Eclipse [message #1691062 is a reply to message #1691031] Thu, 02 April 2015 00:58 Go to previous message
But i didn't find the answer that y i am not able to checkout via eclipse. By using coomand line i am able to checkout.
Previous Topic:How many methods does a pointcut add?
Next Topic:How does aspectj support performance optimization?
Current Time: Sat Jun 14 12:42:46 EDT 2025
Powered by FUDForum. Page generated in 0.03061 seconds
