Home » Language IDEs » Java Development Tools (JDT) » Is there a way to import tasks?
Is there a way to import tasks? [message #16707] Wed, 07 May 2003 14:43 Go to next message
Originally posted by: pchen3.jhmi.edu
Hey All,
Is there a way I can import the tasks associated to a particular .java
file when I import the file into
another project? Thanks for any help.
Re: Is there a way to import tasks? [message #16730 is a reply to message #16707] Wed, 07 May 2003 15:48 Go to previous messageGo to next message
Peter Chen wrote:
>Hey All,
In 2.1 there were some tags you put in java file in comments and then
they were converted to tasks. I use WSAD so haven't been able to get
that far yet, but I have seen my friend use put TODO: in his java files
and they become tasks. So if you use 2.1 you should have this ability
already.
Also there was some team task plugin in
http://eclipse-plugins.2y.net/eclipse/index.jsp
Don't know how it works.
Jari Kujansuu
HUT / INIT
+358 9 451 5679
Re: Is there a way to import tasks? [message #16901 is a reply to message #16730] Wed, 07 May 2003 17:44 Go to previous messageGo to next message
Jari Kujansuu wrote:
Thanks for the reply.
Unfortunately, all my tasks were not added using the TODO tag. I simply
went to the "edit" menu
and chose to add a new task.
Any ideas on how to recover those tasks?
> Peter Chen wrote:
> >Hey All,
> already.
> Jari Kujansuu
> HUT / INIT
> +358 9 451 5679
Re: Is there a way to import tasks? [message #17016 is a reply to message #16901] Thu, 08 May 2003 01:20 Go to previous messageGo to next message
If you want to export tasks you already have ...well I think you can't
:( Was thinking more how to make new ones that can be moved around.
Jari Kujansuu
HUT / INIT
+358 9 451 5679
Re: Is there a way to import tasks? [message #17220 is a reply to message #16901] Thu, 08 May 2003 09:14 Go to previous messageGo to next message
Originally posted by: mccull1.does.not.like.spam.us.ibm.com
Peter,
Try the tasks-export plugin here:
http://sourceforge.net/projects/lunar-eclipse
As a shameless plug, you might want to switch over to Insectivore to keep
your tasks:
http://www.zclipse.org/projects/insectivore/
-Andrew
"Peter Chen" <pchen3@jhmi.edu> wrote in message
news:b9bun1$s8f$1@rogue.oti.com...
> > Peter Chen wrote:
> > >Hey All,
> > already.
> > Jari Kujansuu
> > HUT / INIT
> > +358 9 451 5679
Re: Is there a way to import tasks? [message #17772 is a reply to message #17220] Thu, 08 May 2003 13:07 Go to previous messageGo to next message
Dear Andrew and Jari,
Thank you both for our replies. Much appreciated. I'm still on my search
for a strong IDE for me
to write my Java code in and I was really frustrated to see that the tasks
were not exported and
imported back in when I started a new project.
I checked out the zclipse.org site. Some interesting software you guys
have going. I'll definitely
try some of the plugins, especially the TabNavigator so I can have token
completion like in emacs
and Sun ONE Studio.
Thanks again for the replies.
Andrew McCullough wrote:
> Peter,
> your tasks:
> -Andrew
> > > Peter Chen wrote:
> > > >Hey All,
> > > already.
> > > Jari Kujansuu
> > > HUT / INIT
> > > +358 9 451 5679
Re: Is there a way to import tasks? [message #18157 is a reply to message #17220] Fri, 09 May 2003 06:19 Go to previous message
> Peter,
The plugin should work well with Eclipse 2.0. However, I didn't give
much attention to this plugin lately, so if you have a particular
problem with it, just email me directly.
Genady
> your tasks:
> -Andrew
>>>Peter Chen wrote:
>>>>Hey All,
>>>already.
>>> Jari Kujansuu
>>> HUT / INIT
>>> +358 9 451 5679
Previous Topic:XMLBuddy service interruption
Next Topic:Where can i find - Tomcat plugin for eclipse 2.x ?
Current Time: Wed Nov 05 12:02:18 EST 2025
Powered by FUDForum. Page generated in 0.03834 seconds
