Home » Language IDEs » C / C++ IDE (CDT) » "Updating project..." is killing me
"Updating project..." is killing me [message #165335] |
Tue, 07 March 2006 11:06  |
Every time I build, I have to wait 40 seconds while Eclipse says it is
updating project. Even if the build immediately fails with only a couple
of lines of output, I still have this delay.
I have all binary parsers turned off, indexing is off.
If I wanted to try to hack CDT to disable this - could someone point me
in the right direction?
Re: "Updating project..." is killing me [message #165359 is a reply to message #165351] |
Tue, 07 March 2006 17:22   |
Originally posted by: maarten.bodewes.gmail.com
Keath Milligan wrote:
> arne anka wrote:
>> look into your project's properties->builders and disable the
>> "scanner configuration builder" -- maybe it helps?
>> On Tue, 07 Mar 2006 17:06:38 +0100, Keath Milligan
>>> is updating project. Even if the build immediately fails with only a
>>> couple of lines of output, I still have this delay.
>>> me in the right direction?
> Yeah, I have that off too. Doesn't make a difference.
> It's a large project and it looks like Eclipse wants to walk through the
> entire tree every time you build for some reason.
I have the same problem. Especially if you even change the smallest
setting, for which an entire build is unnecessary it will rebuild all
the stuff. If I change 1 file, rebuild. Hopeless. Maybe I've gotten lazy
with Java, but even Visual Studio 6 seems to do a better job (on this).
Hopefully there is an answer, because I like this IDE (add-on) a lot. I
am trying to debug some C++ libraries for use in my Java binary usenet
reader (par2 & unrar libraries), but debugging them with the CDT proves
to be a lot harder than I had hoped for.
Maarten
Re: "Updating project..." is killing me [message #165408 is a reply to message #165359] |
Tue, 07 March 2006 23:52   |
>>>> a couple of lines of output, I still have this delay.
>> the entire tree every time you build for some reason.
> Maarten
That sounds like it might be a different problem. I'm using a standard
make project and it's not rebuilding everything - the build itself is
completing quickly - but Eclipse is going through a long process of
refreshing the entire project tree - In my case, this means walking
through hundreds of directories and stat'ing thousands of files.
I now have a hack that bypasses this refresh, but it is a hack, and
depending on your project, it may cause other problems for you. In my
case, I don't care about the files the build produces (at least, I don't
want Eclipse to care that is), so not refreshing the project every time
I build isn't a problem. I can manually force a refresh if I need to.
Here is the hack:
* You'll probably need the SDK version of the CDT installed for this.
I'm using version 3.0.2.
* Switch to Plug-in Development Perspective.
* In the Plug-Ins list, right click on org.eclipse.cdt.make.core and
select Import | As Source Project
* Now switch to the Package Explorer and locate MakeBuilder.java under
src-cdtmakecore/org.eclipse.cdt.make.core/
* Down around line 230, find the lines:
monitor.subTask(MakeMessages.getString("MakeBuilder.Updating_project "));
//$NON-NLS-1$
try {
// Do not allow the cancel of the refresh, since the builder is external
// to Eclipse, files may have been created/modified and we will be
out-of-sync.
// The caveat is for hugue projects, it may take sometimes at every
build.
currProject.refreshLocal(IResource.DEPTH_INFINITE, null);
} catch (CoreException e) {
* Comment these lines out. As you can see, it looks like the developer
considered the impact of this operation on large projects.
* Click on the project name and Build All
* You can test your changes now if you like by using Run As | Eclipse
Application
* To export the new version of the plug-in, select Export... |Deployable
plug-ins and fragments
* Select "Directory" as the Export Destination and choose a temporary
directory to save the exported plug-in in and click Finish. This will
leave the new plugin in <dir>/plugins/org.eclipse.cdt.make.core
* Shut down Eclipse
Now you can replace the plugins/org.eclipse.cdt.make.core folder in your
Eclipse directory with the one you just created. Save the old one away
first though in case something doesn't work.
Like I said, this is a hack and it may cause you other issues depending
on how your project is structured. No warranties, your mileage may vary,
don't run with scissors and all that...
Re: "Updating project..." is killing me [message #166784 is a reply to message #165408] |
Wed, 29 March 2006 12:53  |
Me too!
Filed a bug at https://bugs.eclipse.org/bugs/show_bug.cgi?id=133881
Aleks
>>>>> point me in the right direction?
>> lazy with Java, but even Visual Studio 6 seems to do a better job (on
>> this).
>> I am trying to debug some C++ libraries for use in my Java binary
>> usenet reader (par2 & unrar libraries), but debugging them with the
>> CDT proves to be a lot harder than I had hoped for.
>> Maarten
> Here is the hack:
> //$NON-NLS-1$
> try {
> out-of-sync.
> build.
> Application
> * Shut down Eclipse
Current Time: Thu Sep 18 10:25:08 EDT 2025
Powered by FUDForum. Page generated in 0.04700 seconds
