Home » Eclipse Projects » SWTBot » SWTBot on RCP (Trying to use SWTBot test on my RCP application)
SWTBot on RCP [message #1647179] Tue, 03 March 2015 04:42
Razz Hi, I am trying to impart SWTbot on my RCP application , tried to add required plugins on the run configuration and when i run the test the following error comes up ,
!ENTRY org.eclipse.emf.ecp.emfstore.core 1 0 2015-03-03 00:39:53.317
!MESSAGE EMFStoreProvider received CREATE for ECPRepositoryImpl test server fusemaster
!ENTRY org.eclipse.osgi 4 0 2015-03-03 00:39:54.382
!MESSAGE Application error
!STACK 1
org.eclipse.swt.SWTError: Not implemented [multiple displays]
at org.eclipse.swt.SWT.error(SWT.java:4423)
at org.eclipse.swt.widgets.Display.checkDisplay(Display.java:767)
at org.eclipse.swt.widgets.Display.create(Display.java:908)
at org.eclipse.swt.graphics.Device.<init>(Device.java:156)
at org.eclipse.swt.widgets.Display.<init>(Display.java:507)
at org.eclipse.swt.widgets.Display.<init>(Display.java:498)
at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.java:695)
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:162)
at com.qualcomm.qti.qsip.rcp.Application.start(Application.java:96)
at org.eclipse.swtbot.eclipse.core.UITestApplication.start(UITestApplication.java:54)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Previous Topic:An error occurred while automatically activating bundle uitest
Next Topic:Robotframework tool using SWTBot
Current Time: Tue Jun 17 03:47:28 EDT 2025
Powered by FUDForum. Page generated in 0.06830 seconds
