Home » Modeling » VIATRA » [model obfuscator] error while saving obfuscated model
[model obfuscator] error while saving obfuscated model [message #1632973] Tue, 24 February 2015 10:51 Go to next message
i'm trying the model obfuscator on some examples and get this error[1].
i'm using eclipse 3.8.2, emf 2.9 .
thanks !
[1]
eclipse.buildId=201412121920
java.version=1.7.0_40
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Command-line arguments: -os win32 -ws win32 -arch x86_64
Error
Tue Feb 24 16:47:21 CET 2015
Unhandled event loop exception
java.lang.NoClassDefFoundError: com/google/common/io/BaseEncoding
at org.eclipse.viatra.modelobfuscator.util.StringObfuscator.obfuscateData(StringObfuscator.java:44)
at org.eclipse.viatra.modelobfuscator.emf.simple.SimpleEMFModelObfuscator.modifyData(SimpleEMFModelObfuscator.java:172)
at org.eclipse.viatra.modelobfuscator.emf.simple.SimpleEMFModelObfuscator$2$1$2.apply(SimpleEMFModelObfuscator.java:148)
at org.eclipse.viatra.modelobfuscator.emf.simple.SimpleEMFModelObfuscator$2$1$2.apply(SimpleEMFModelObfuscator.java:1)
at org.eclipse.xtext.xbase.lib.IterableExtensions.forEach(IterableExtensions.java:399)
at org.eclipse.viatra.modelobfuscator.emf.simple.SimpleEMFModelObfuscator$2$1.apply(SimpleEMFModelObfuscator.java:153)
at org.eclipse.viatra.modelobfuscator.emf.simple.SimpleEMFModelObfuscator$2$1.apply(SimpleEMFModelObfuscator.java:1)
at org.eclipse.xtext.xbase.lib.IteratorExtensions.forEach(IteratorExtensions.java:354)
at org.eclipse.viatra.modelobfuscator.emf.simple.SimpleEMFModelObfuscator$2.apply(SimpleEMFModelObfuscator.java:156)
at org.eclipse.viatra.modelobfuscator.emf.simple.SimpleEMFModelObfuscator$2.apply(SimpleEMFModelObfuscator.java:1)
at org.eclipse.viatra.modelobfuscator.emf.simple.SimpleEMFModelObfuscator.modifyModel(SimpleEMFModelObfuscator.java:159)
at org.eclipse.viatra.modelobfuscator.emf.simple.SimpleEMFModelObfuscator.obfuscate(SimpleEMFModelObfuscator.java:62)
at org.eclipse.viatra.modelobfuscator.ui.handlers.EMFModelObfuscatorHandler$2.execute(EMFModelObfuscatorHandler.java:91)
at org.eclipse.emf.common.command.BasicCommandStack.execute(BasicCommandStack.java:78)
at org.eclipse.viatra.modelobfuscator.ui.handlers.EMFModelObfuscatorHandler.execute(EMFModelObfuscatorHandler.java:100)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:290)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:499)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(CommandContributionItem.java:829)
at org.eclipse.ui.menus.CommandContributionItem.access$19(CommandContributionItem.java:815)
at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(CommandContributionItem.java:805)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at Application.start(Application.java:70)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:606)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
Caused by: java.lang.ClassNotFoundException: com.google.common.io.BaseEncoding
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
... 50 more
Re: [model obfuscator] error while saving obfuscated model [message #1634288 is a reply to message #1632973] Wed, 25 February 2015 02:34 Go to previous messageGo to next message
can you check if you have Google Guava as a plug-in in the Help -> Installation Details -> Plug-ins window? If you have, what version is it?
If you don't have, install for example the Xtend SDK, that should include it.
Did you install from the update site or run from source?
Re: [model obfuscator] error while saving obfuscated model [message #1634423 is a reply to message #1634288] Wed, 25 February 2015 04:01 Go to previous messageGo to next message
hi,
yes, i have guava installed, version 10.0.1.v201203051515
I've installed with the update site directly from hudson :
https://hudson.eclipse.org/viatra/job/viatra-modelobfuscator-master/lastSuccessfulBuild/artifact/releng/org.eclipse.viatra.modelobfuscator.update/target/repository/
Re: [model obfuscator] error while saving obfuscated model [message #1636527 is a reply to message #1634423] Thu, 26 February 2015 03:27 Go to previous messageGo to next message
Thanks for the catch! BaseEncoding was only added to Guava from 14.0 (see https://code.google.com/p/guava-libraries/source/browse/guava/src/com/google/common/io/BaseEncoding.java#129 )
I have updated the version requirement (see http://git.eclipse.org/c/viatra/org.eclipse.viatra.modelobfuscator.git/commit/?id=e7d0ef9cda4d6102cd77b1f3db9f01739b490adb )
You should be able to install the new build ( https://hudson.eclipse.org/viatra/job/viatra-modelobfuscator-master-maven/12/ ) from the update site.
Re: [model obfuscator] error while saving obfuscated model [message #1636684 is a reply to message #1636527] Thu, 26 February 2015 05:15 Go to previous message
Thanks, it worked !
i had only to add the xtext repo ( http://download.eclipse.org/modeling/tmf/xtext/updates/composite/releases) to get the correct guava version.
Previous Topic:Attribute problem
Next Topic:Application of GTRULE
Current Time: Mon Nov 17 09:25:12 EST 2025
Powered by FUDForum. Page generated in 0.05174 seconds
